Old 05-18-2017, 03:10 PM   #127
TN4thGen
TN4thGen's Avatar
Originally Posted by Anthonyc77 View Post
Bump, anyone have any updates/reviews?
I'm also interested in long term updates, has anyone had any major problems after running on the street for awhile?
TN4thGen is offline   Reply With Quote
Old 05-26-2017, 04:07 AM   #128
DeaconRoc
Drives: GT86
I ran mine for about a year. No problems but they're were pretty rusty when they came off. I do live in the UK though where the roads are salted a lot in the winter.
DeaconRoc is offline   Reply With Quote
Old 05-26-2017, 08:00 AM   #129
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
I've put 10K miles so far in mixed street/track and so far they have held up great.
Cartman is offline   Reply With Quote
Old 05-26-2017, 09:13 PM   #130
vintagemxer
vintagemxer's Avatar
Drives: 2016 BRZ Limited
Spring change
Curious DeaconRoc...Not sure if you did all 4 springs @ 7K, or just 2 fronts...Thanks
vintagemxer is offline   Reply With Quote
Old 05-30-2017, 04:26 PM   #131
DeaconRoc
Drives: GT86
I didn't change springs at all on the Tein Flex A's they were the standard 6kg front and rear.
Old 05-31-2017, 05:03 PM   #132
TN4thGen
TN4thGen's Avatar
Awesome! Thanks for the help. Are they better than stock at the track? Someone told me they were too soft for track use, but I only go to the track about once a year. I want something comfortable on the street with at least the same performance as the stock struts.
Old 05-31-2017, 05:32 PM   #133
Cartman
Cartman's Avatar
They are perfect for my local tracks, but they are low speed tracks
Old 06-06-2017, 04:04 AM   #134
IgamaS
Drives: 2015 Whiteout FRS
I just installed mine a few days ago, and must I say they are really nice. A big upgrade from stock suspension to Tien Flex A.
IgamaS is offline   Reply With Quote
Old 08-11-2017, 01:32 PM   #135
Anthonyc77
Drives: 2017 Toyota 86 Halo
How would you rate the comfort of them compared to stock?
Anthonyc77 is offline   Reply With Quote
Old 08-12-2017, 05:28 PM   #136
IgamaS
Sorry about the late reply*
Comfort wise, they are a lot better. Even at no adjustments they ride nice, though for me in my area were there's a bit more bumps and potholes, I did 6 clicks away from the softest setting and wow I'm impressed. My next plan is to get the pro active controller for it as it'll make adjustments not the fly while driving.
Old 04-11-2018, 08:40 PM   #137
EffaressNOOB
EffaressNOOB's Avatar
Drives: Halo 2016 Scion FR-S, 6MT
BUMP!
Curious to know what everyone’s “click” settings are for
AUTOCROSS:
Daily Driving:
Had my first Autocross run this past weekend. It was suggested to me that I try 7 clicks from stiff on all 4 corners. Car felt great except for the really tight turns, where my rears were losing contact. The following run I tightened all 4 corners to 5 clicks from stiff and I felt planted on soft corners and slaloms, but it felt like I was on ice on the hard corners.
Any suggestions would be much appreciated! Oh BTW, don’t drive through downtown Savannah, GA without softening your dampers.... I think I lost a filling!
Enkei TFR (Copper) 17x9+45 | Hankook Ventus V12 Evo2 245/40 | Tein Flex A
OFT Stage 2, E85 | Kraftwerks Skunk2 CAI
Open Flash Unequal Length Header
Invidia N1 CatBack
InstaGram: 49RJ
EffaressNOOB is offline   Reply With Quote
Old 04-12-2018, 01:56 AM   #138
churchx
churchx's Avatar
Drives: 2014 GT86
You should also mention your tires and alignment settings imho. Coilover dampening adjustment is not the only thing affecting handling.
strat61caster (04-12-2018)
Old 04-12-2018, 05:23 AM   #139
DeaconRoc
Drives: GT86
Originally Posted by EffaressNOOB View Post
BUMP!
AUTOCROSS:
Daily Driving:
On track I used to run mine 2 clicks from full stiff as I found the standard Flex A's to be very soft. On the road somewhere between 7-11 clicks from full stiff depending on whether I wanted wafty comfort or more fun.
Sent from my ONEPLUS A3003 using Tapatalk
The Following User Says Thank You to DeaconRoc For This Useful Post:
EffaressNOOB (04-12-2018)
Tein Flex A and Z!!! breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-24-2016 03:44 PM
Tein Flex Z Bigmaxy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-27-2015 03:22 AM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 03:12 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
FS: Tein Flex Coilover Jade 86 Brakes, Suspension, Chassis 43 06-15-2013 09:35 PM
