Old 05-24-2017, 08:05 PM   #1
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
12v center console adapter not charging.
The 12v fuse is good. Swapped it out with spare just in case.
How do I take it out?
I have good reason to believe it is somehow lose. It no longer charges...and imo seems loose.
This thing.
Pics above are from other members...
After further research it seems I must pullll EVERYYYYTHIIIINGGGGGGGGGG apart to access the final picture, right? FML if so.
Old 05-24-2017, 08:29 PM   #2
stevesnj
stevesnj's Avatar
Nope, just remove the parking brake cover. You may be able to get your hand in there to feel if the plug is on. It's tight though.
My 2016 Build thread
Old 05-24-2017, 08:59 PM   #3
So, how do you figure it's not charging .. ??
Did you try something else into the plug and see if it works..??
Bubba says to lick your finger and stick it in the outlet ...... see it tingles ......
Packofcrows (05-25-2017), Trust86 (05-24-2017)
Old 05-24-2017, 09:58 PM   #4
Trust86
Drives: 2016 Halo FRS
+1 for @humfrz
also are you sure you are checking the right fuse?
Trust86 is offline   Reply With Quote
The Following User Says Thank You to Trust86 For This Useful Post:
humfrz (05-24-2017)
Old 05-25-2017, 01:55 AM   #5
Packofcrows
Yep right fuse. In fact, checked both:
Tried 2 different devices, 2 different cables and 2 different adapters. Seems there is play in 12v adapter....urgh... i may just end up plugging it up and buying a dual 12v adapter for one in glove box. YARGH cheapo quality.
The Following User Says Thank You to Packofcrows For This Useful Post:
Trust86 (05-25-2017)
Old 05-25-2017, 02:22 AM   #6
alan.chalkley
Drives: 4wd zooks
A multimeter would be use full , to find any open circuits or shorts in wiring/plug/connectors.
alan.chalkley is offline   Reply With Quote
Old 05-25-2017, 02:56 AM   #7
Did you check the fuse in p/point No 1 (position #22) .......??
(I don't know which one is for the console plug, position #2 or position #22 ..... ?????)
Old 05-25-2017, 11:20 AM   #8
Packofcrows
p2 is console, p1 is glove. Done.
Oddly enough, my battery was drained this morning.... kinda got me angry and I pulled a idiot move, I kicked car into neutral, pushed out of garage, as it was rolling down driveway I turned it on... sigh so unsafe.
Hope I didnt kill a fuse yesterday as I pulled other 2 yesterday...
I did leave phone 12v adapter to USB plugged in that lights up in the console 12v so idk if that may have drained it? Maybe it kicks in here and there and turns on? No light showing its on though ;/
:b onk::bon k:
Old 05-25-2017, 11:28 AM   #9
:b onk::bon k:
I don't understand your second to last sentence .....??
Yes, I understand the s ......
I reckon you have a weak battery or a dead short somewhere (or both now).
I hope you get it fixed before you get stranded somewhere you're not supposed to be .......and YOU know where that is ......
Old 05-25-2017, 11:45 AM   #10
Packofcrows
Was saying maybe it only works when it wants [console 12v]. I left my (testing to see if it works) ac adapter phone charger plugged in overnight.
How I would know it is receiving power is when it lights up. Maybe it was turning on overnight? I know slow drains can kill batteries so I am thinking maybe it was going on and off all night yesterday.
Old 05-25-2017, 01:35 PM   #11
Well, Packofcrows, it would be highly unlikely that your cell phone could drain a car battery overnight ...... unless the battery was almost all the way drained to start with.
I'd suggest you have your battery load tested at a shop and recharged or replaced as appropriate.
Meanwhile, I'd pull the fuse for the p2 circuit, until you get the battery drain/short sorted out.
Old 05-25-2017, 06:25 PM   #12
Exrald
Exrald's Avatar
Drives: 2013 Scion FRS & 2022 GR86
So what's the solution for it? Cuz I bought mine without the 12v working...
2013 Scion FRS @theunforgottenfrs
2013 Scion FRS
2022 Toyota GR86
Exrald is offline   Reply With Quote
Old 05-25-2017, 07:12 PM   #13
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
Is the ignition in the run and or on positions......
IceFyre13th is offline   Reply With Quote
The Following 3 Users Say Thank You to IceFyre13th For This Useful Post:
craneom (01-10-2019), humfrz (05-25-2017), Tcoat (05-25-2017)
Old 05-25-2017, 09:08 PM   #14
Good point!
My idea for a center arm rest / console cover / center cup holder ravenblackfrs Cosmetic Modification (Interior/Exterior/Lighting) 67 02-13-2016 03:00 PM
Qi Wireless Charging in BRZ/FR-S/GT86 Center Console Deathalo DIY (Do-It-Yourself) Guides 34 11-21-2014 12:29 AM
need help on jpm center console Jhon19lopez Cosmetic Modification (Interior/Exterior/Lighting) 4 06-24-2013 07:57 PM
red center console? gusbarragan Cosmetic Modification (Interior/Exterior/Lighting) 13 02-19-2013 08:03 PM
Center Console help mbh1101 Cosmetic Modification (Interior/Exterior/Lighting) 2 08-22-2012 09:56 AM
