Old 09-11-2012, 03:37 PM   #15
simpleisbest
Senior Citizen
Drives: Scion FR-S
Totally thinking about picking up a set of these!
Does any1 have the size for the clutch slave cylinder?
It would be nice to do that at the same time!
simpleisbest is offline   Reply With Quote
Old 09-11-2012, 07:52 PM   #16
CB762
CB762's Avatar
Drives: Scion FR-S
Originally Posted by yomny View Post
installed these too, awesome, work as advertised!! I have no pics, but its just a regular bleeder valve in the brake caliper. These are the ones you want. When installing make sure you screw all the way in, it'll have resistance due to the silicone applied to them but if not fully screwed in they will bleed.
Also available in stainless still, part number SB1010-SS.
CB762 is offline   Reply With Quote
Old 09-11-2012, 08:10 PM   #17
Steve35
Drives: Scion
Originally Posted by gmookher View Post
linkie?
http://www.speedbleeder.com/
Steve
Steve35 is offline   Reply With Quote
Old 10-03-2012, 04:26 AM   #18
Burn
Slack Bum
Burn's Avatar
Drives: FT86
How many bleeders we need roughly ?? one per caliper ?
Burn is offline   Reply With Quote
Old 10-03-2012, 09:55 AM   #19
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Do you have to take out all the fluid in the system before installing or just try to wipe all the leaking fluid that comes out?
F1point4 is offline   Reply With Quote
Old 10-03-2012, 11:13 AM   #20
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
No you dont need to take out all the fluid, just screw out the oem bleeder valve and some fluid will come out, screw the new one in, do the same for all wheels, then just do a quick bleed to try them out and make sure no air is in the system. To bleed simply unscrew the new bleeder valve out a 1/4 of a turn or maybe a bit more and pump away the brake pedal, then lock the valve.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 10-03-2012, 11:14 AM   #21
yomny
yomny's Avatar
Yep, one per caliper.
The Following User Says Thank You to yomny For This Useful Post:
Burn (10-03-2012)
Old 05-25-2017, 11:01 AM   #22
Scourge
Agent 86
Drives: 2017 Toyota 86
Also curious about the clutch slave. And while I'm in here, I might as well add some useful stuff...
I'm going to give the Earl's Solo-Bleed 280041ERL a try. I already spoke with a tech there over the phone and he said it was a nickel alloy. The design is a little different than the SB1010 (and SB1010-SS) but it should still remain a one man job.
The ones sold by Russell (part #639560 looks like a SB1010) appear to be identical to the Speed Bleeder dot com ones. I'm guessing they are the same? Looking at the bag and hose combo from both companies, they appear to be identical (same writing and font on bag). Unfortunately, Russell doesn't sell a stainless version. It looks like regular steel that may or may not have been galvanized. It's too bad because I can get Russell through my work, but I'm not interested in the regular steel version.
Scourge is offline   Reply With Quote
The Following User Says Thank You to Scourge For This Useful Post:
simpleisbest (05-25-2017)
Old 05-27-2017, 09:27 PM   #23
TruRace
TruRace's Avatar
Drives: FRS-Raven-MT
The size for the clutch slave is m7-1.0. And I think it's 32mm long.
TruRace is offline   Reply With Quote
The Following 2 Users Say Thank You to TruRace For This Useful Post:
Scourge (05-30-2017), simpleisbest (05-31-2017)
Old 06-06-2017, 01:29 AM   #24
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
I bought some of these, shipped them to Australia, went to install them, size was wrong..
(website i got them off listed them for my car)
so, they are in the bin, cost too much to ship them back..
good idea though!
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Old 06-24-2017, 05:29 PM   #25
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
Has anyone confirmed this sizing?
Speedbleeder.com has M7x1.0 in 30.22 length (SB7100S) and 35.15 length (SB7100).
Would it be better to order the longer, 35.15 length?
ApexEight is offline   Reply With Quote
Old 12-17-2020, 09:48 PM   #26
BaBaFlyingSheep
Drives: 2015 BRZ Ltd 6MT
Definitely not 32 mm. Bought one and it protruded out by a very noticeable amount.
Took mine out and measured ~24.5 mm overall length.
M7 - 1.0 is the correct thread though.
Another thread mentioned that the ~30 mm works well.
https://www.ft86club.com/forums/showthread.php?t=117198
BaBaFlyingSheep is offline   Reply With Quote
Old 12-25-2020, 12:33 PM   #27
FeRS
bruh
FeRS's Avatar
Drives: Raven 2015 FRS
I have speed bleeders on my car. They're longer than stock ones, but it fits the thread and when tightened they seal. Favorite mod next to the oil drain valve. The part is "SB1010-SS SB1010-SS / 9409, H9409, 9410, H9410, 9412, H9412 Speed Bleeder" on the site
<-- why is this an emote
FeRS is offline   Reply With Quote
Old 05-30-2022, 06:43 PM   #28
OfficeLinebacker
Drives: 2019 Toyota 86 Base AT
I searched the entire internet for the bleeder screw size for replacements and this is where I found out that the bleeder screw size for BRZ/Toyota 86/FRS is M10x1.0 front and rear.
When I went to the auto parts store or RockAuto they provide a list of a bunch of different sizes and repair kits. Now I can order the right size. Thanks.
OfficeLinebacker is offline   Reply With Quote
bleeder
Stock TPMS's with aftermarket valves/wheels? Phaedrus29 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-17-2012 01:18 PM
