Old 05-25-2017, 08:19 AM   #1
mcrane
mcrane's Avatar
OEM Reverse Lockout Pin Stuck
Need some ideas...
Uninstalling the OEM Reverse Lockout. I used a 3/32 Punch and Hammer as per the procedure. With some firm taps, the pin came out the back slightly. Since then, no amount of hammering has moved it further. I grabbed the pin with a pair of pliers and attempted to remove it the rest of the way. No luck.
The pin will not budge in or out now. So, I am now stuck with the Pin a quarter of the way out.
Any ideas what to do at this point?
- Thanks
mcrane is offline   Reply With Quote
Old 05-25-2017, 08:39 AM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Maybe have a friend grab the other end with pliers and wiggle the pin while you try tapping it out again.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 05-25-2017, 08:39 AM   #3
StraightOuttaCanadaEh
Wes
I found it to be a two man procedure. I held the shifter steady while the other person hammered the pin out. Otherwise too much of the impact energy is lost in the shifter moving around.
Old 05-25-2017, 08:49 AM   #4
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Its recommended you put the shifter into reverse while doing this so you dont have to line it back up later. I think that also takes some lateral pressure off the pin. Are you doing that?
I always held the shifter firmly in reverse (pushing the gear shifter forward) while holding the pin in place with the same hand. Then just give the pin some really hard taps.
I was using a rubber mallet too because I was scared of damage, but turns out the rubber absorbed too much force. So thats another thing to consider.
The Following User Says Thank You to PandaSPUR For This Useful Post:
Tcoat (05-25-2017)
Old 05-25-2017, 09:16 AM   #5
mcrane
mcrane's Avatar
Yes, the shifter is in the Reverse position. I have held the pin and hammer in this fashion as well. I will keep at it.
Old 05-25-2017, 09:17 AM   #6
mcrane
mcrane's Avatar
Good idea. I will see if the girlfriend is down to help haha
Old 05-25-2017, 09:17 AM   #7
mcrane
mcrane's Avatar
I placed a covered 2x4 behind the shifter to restrict its motion. This allowed for firm applications with the hammer.
Old 05-25-2017, 09:18 AM   #8
mcrane
mcrane's Avatar
My main concern is that the pin got warped inside somehow, jamming it in place.
Old 05-25-2017, 04:48 PM   #9
Fabb
Drives: BRZ DGM
I swear to god that pin is pain in the ass to deal with.
Fabb is offline   Reply With Quote
Old 05-25-2017, 05:46 PM   #10
BRZdart17
Hi! new here first post Can you try locking vice grips on the exposed end of the pin, then use a screwdriver inbetween the vice grips, or in the vice grips and hammer the pin out. Think of it as pulling the pin, not pushing. Good luck
BRZdart17 is offline   Reply With Quote
Old 05-25-2017, 08:25 PM   #11
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
That pin i heard is 50/50 on keeping it. Some people drill it out, others have no problems. I haven't touched that part of my car yet, but i'll be buying a second pin before i do.
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Old 05-25-2017, 10:26 PM   #12
brzzy
@anthonysestito
brzzy's Avatar
Drives: 2013 Sterling Silver Metallic BRZ
I used pliers, and pulling the pliers towards you, turning the pliers around the actual lock out as leverage.....if that makes any sense
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO
brzzy is offline   Reply With Quote
Old 05-26-2017, 11:06 PM   #13
mcrane
mcrane's Avatar
UPDATE:
The pin would not budge. It appeared to be wedged somehow.
Gave up and took a dremel to the shift know. After cutting off the shift knob, the pin would still not come out.
Being left with half a pin stuck out, I slid the new lockout into place. I found a similar metal rod in the garage that I bent to fit. Once in place, I hammered it the rest of the way into the hole. VOIALA!
What you see is an entirely Macgyver built, brutally tested masterpiece.
Old 05-27-2017, 11:55 AM   #14
MurderousPandas
Originally Posted by mcrane View Post
UPDATE:
Doesn't truly work unless it can handle a burnout lol
Red Reverse Lockout dieseldan444 Interior Parts (Incl. Lighting) 4 09-28-2016 12:47 AM
WTB: OEM Reverse Lockout Ethereal05 Want-To-Buy Requests 2 07-18-2016 04:01 PM
wtb oem reverse lockout Vincenttam Want-To-Buy Requests 0 02-09-2015 05:41 AM
Reverse lockout? MrMarinakos Cosmetic Modification (Interior/Exterior/Lighting) 0 04-28-2014 08:47 PM
