Old 05-23-2017, 11:38 AM   #15
Originally Posted by trippinbillies40 View Post
Problem solved. Too many miles for how old the car is.
There is a mileage requirement? So the system is weighted to benefit the dealer but presented as if to be best for the costumer?
Old 05-23-2017, 11:38 AM   #16
Da Brz
Drives: 2016 Subaru BRZ
Their website still says this though:
"For vehicles exceeding the above maximum mileage limits and not disallowed by the Vehicle Exclusions or the Vehicle Condition Criteria outlined in the Program Guidelines, the GTP Value offered to the customer must be reduced by $0.20 for each mile over the maximum mileage allowance. This is the only allowed reduction of the GTP Value."
Come to about a $1,500 hit for me. But I still don't know what Subaru values my car at though.
Da Brz is offline   Reply With Quote
Old 05-23-2017, 11:40 AM   #17
Da Brz
Originally Posted by jasonojordan View Post
$320 just for a oil change?!
I just called to ask since I've got my 30k mile service coming up.
$330 plus tax for an oil change, tire rotation and "brake fluid flush and top engine clean."
Old 05-23-2017, 11:41 AM   #18
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Yes there is a mileage requirement, no it is not weighted to benefit the dealer. Just like leasing has mileage caps, the GTP program is a "bet" on the depreciated value of a car, and that is much much harder to be accurate on as mileage goes way up on younger cars, so Subaru caps mileage for GTP so they can accurately quote a trade in value that is good for both parties.
trippinbillies40 is offline   Reply With Quote
The Following User Says Thank You to trippinbillies40 For This Useful Post:
Tcoat (05-23-2017)
Old 05-23-2017, 11:41 AM   #19
Perfect. Thanks.
Old 05-23-2017, 11:46 AM   #20
trippinbillies40
Drives: '22 WRB
Give your retailer a shout and they'll quote you.
Old 05-23-2017, 12:01 PM   #21
2013dgmbrzdood
Drives: 13 brz limited
Well since my mileage had almost 30k more allowed I guess that means I get 30k x .20 added to my vehicle value.
I actually got really pist at subaru because in one month their trade-in value dropped by 4k. Total bs.
2013dgmbrzdood is offline   Reply With Quote
Old 05-23-2017, 12:04 PM   #22
trippinbillies40
Drives: '22 WRB
Just out of curiosity, what does fair market price have to do with Subaru? If you want the most money for your car, sell privately. More work, but always your best option, especially if you think black book values are wrong.
Old 05-23-2017, 12:15 PM   #23
Da Brz
That's hard to do if you still owe money though.
Old 05-23-2017, 12:18 PM   #24
trippinbillies40
Drives: '22 WRB
Not necessarily true, but also, one can't hold a manufacturer responsible for quoting fair market value from black book.
Old 05-23-2017, 06:37 PM   #25
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Let us know what a "top engine clean" is. I probably really need one of those whatever TF it is.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
Tcoat (05-23-2017)
Old 05-23-2017, 10:35 PM   #26
LOL You made me look it up!
Sounds like they pour some shit in your gas or something. Even though the manual clearly says "don't pour shit or something in your gas".
"Using a top engine cleaner can help:
Reduce stalling, hesitation, and pinging.
Make your engine idle smoother.
Improve your exhaust emissions and gas mileage.
Clean carbon deposits from inside the engine (decarbonize).
Clean the intake valves and pistons.
Clean the throttle body (a little)."
Old 05-23-2017, 10:41 PM   #27
They are ripping you off!
This is what the Subaru 30K service is supposed to include for around $300:
Major Subaru Recommended Service*
Perform at 30,000 Miles, 60,000 Miles, 90,000 Miles, etc
Replace engine oil, filter and drain plug washer
Inspect and adjust all drive belts to factory specifications
Inspect and ensure cooling fan is operating within factory specifications
Replace transmission fluid with Subaru High Performance Fluid
Check to ensure air conditioning and heating systems are operating within factory specifications
Rotate tires, inspect tread wear and check and adjust tire pressure as needed
Perform brake system inspection; pads and/or drums, lines, hoses and fluid
Inspect suspension system and steering components to ensure factory specifications
Service battery, clean terminals, install anti-corrosion pads and check battery condition
Inspect wiper blades and linkage operation
Lubricate all door, trunk and hood latches and hinges if needed
Inspect exhaust system and heat shields
Replace front and rear differential fluid
Inspect radiator and cooling system
Adjust emergency brake to within factory specifications if needed
Replace air filter element
Inspect steering operation, tie rod ends and steering rack guides per factory specifications
Inspect all engine and transmission mounts
Inspect and adjust all fluid levels as needed
Check all interior and exterior lighting operation
Replace brake fluid
Install premium fuel additive (dealer recommended)
Factory trained technician to conduct road test
Old 05-24-2017, 11:37 AM   #28
gravitylover
That's not too terrible. Full fluid and filter changes all the way around and full visual inspection too. Sure you can do it in under 2 hours (3 including getting the parts and supplies) yourself if you have the knowledge, the place to do it and the tools but at $300 I'd question if it's worth it.
Replace brake fluid
Subaru Guaranteed Trade-In Program White64Goat Off-Topic Lounge [WARNING: NO POLITICS] 5 03-21-2014 04:25 PM
BeSpoke trade in program jybrd Issues | Warranty | Recalls / TSB 23 07-22-2013 01:47 AM
Subaru VIP Program tranzformer BRZ First-Gen (2012+) — General Topics 203 07-17-2012 02:12 PM
Subaru Graduate Program Documents Motopythons BRZ First-Gen (2012+) — General Topics 5 06-03-2012 01:09 PM
have anyone join the Subaru VIP program? Xdragonxb0i BRZ First-Gen (2012+) — General Topics 7 01-01-2012 08:33 AM
