| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 15' Limited BRZ
HELP! How to get rid of poke
Hi I have 17x9 +35 offset rpf1 and it's poking really bad, im on stock suspension and have tein flex a's waiting for install how do I get rid of the poke I didn't realize how ugly and serious it was as I'm not really a wheels guy. So would camber help?
#2 |
Drives: '24 GR86
Car runs almost no camber from factory. 4x4 ride height in stock form doesn't help the look either.
When the car is lowered, the suspension will naturally increase negative camber and will get you closer to the look you desire. When the coilovers come in, install those along with LCAs and get and alignment. You'll be set after that.
#3 | |
Edit; forgot to mention I'm lowering the car by an inch max. |
#4 |
Drives: FRS
may be able to get a way without LCA..
I'm on Tein StreetFlex and with the rears lowered at my height, without replacing LCA I had natural? camber at -2.2 i think they were which I'm okay with.. and toe are not out of whack either
'14 Scion FRS
Tein Flex TE37 |
#5 |
Thanks for the reply I really don't want to wait for the LCA anyway because I already have everything for install just need the LCA if it's necessary I might try it without the LCA
#6 | |
After you lower it, the poke will be reduced due to the added camber. The tops will be tucked in further, but the bottoms of the wheel will be about the same. The camber creates an illusion of what is vertical so it will look better. |
#7 |
Drives: 2015 BRZ Limited
what size tires are you running?
![]() (Unless you posted them and I just can't see... my work computer is picky when it comes to that sort of thing..) |
#8 | ||
Drives: '24 GR86
Lowering the vehicle will change the alignment, likely causing the left to be different from the right. It has nothing to do with zero'ing camber. It's about making sure both sides are the same. $200 SPCs and be done with it. Or spend $150 to get an alignment and find out theres a 1/2 degree difference, go buy LCAs, and then spend the money for an alignment again.
#9 | |
Drives: FRS
jokes. yeah if you have the means do it right!
'14 Scion FRS
Tein Flex TE37 |
#10 |
Drives: 2013 BRZ Limited
Who sold you the wrong wheels? This car has no business with 9" wide wheels unless it is a track car. You'll need to run greater than 2 degrees camber for them to "fit"
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523 Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car www.makesmodels.com www.camautomag.com |
#11 |
Thee O-ri-gi-na-tor
![]() ![]() 17x9 +35 245/40/17 all around lowered on swift springs only. |
| The Following User Says Thank You to VenomRush For This Useful Post: | Vic4uf (05-30-2017) |
#12 |
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
I've got 17x9 RPF1 +35s. Really the only way to eliminate poke completely is investing in coilovers and camber bolts and finding the right alignment, there is a very small sweet spot where the top of the tyre is tucked and there is no rubbing on full lock.
#13 |
Driver of Sweet Vehicles
Put in a spacer of around -15mm of width on each wheel and that should help even it out.
#14 |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
| How to fix wheel poke | tskaohu | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 06-10-2016 02:58 PM |
| Immobilizer - where is it? How can i poke at it? | im_topher | Engine, Exhaust, Transmission | 8 | 11-10-2015 12:29 PM |
| What can I do about poke? Don't know what I'm doing | rinnamon | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 04-05-2015 09:38 PM |
| Poke's BRZ build | Pokeguyjai | Member's Car Journals | 5 | 03-15-2014 11:10 AM |
| Help with poke on rear | Ash.B | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 28 | 11-23-2013 07:19 AM |
