#57 | |
Drives: 2017 ISM PP BRZ
http://www.revvedmag.com/engine-tech...boxer-engines/ This is written more info-heavy, less of an advertisement- http://www.superstreetonline.com/how...-engines-work/ Last edited by JSube; 05-21-2017 at 09:56 AM. Reason: better info |
| The Following User Says Thank You to JSube For This Useful Post: | Tcoat (05-21-2017) |
#58 | |
It fails to mention that GM also developed their own boxer back in the 60s but dropped it partially because the North American buyers did not understand how it worked and didn't trust it.
#59 | |
Drives: 2013 Subaru BRZ
The latest Eaton Superchargers are very quiet and I was surprised at how quiet the Subaru engine actually is. The best way to eliminate the noise from the intake noise generator is to take it off completely. There are kits, or were, to plug the big hole in the intake bellows. Last edited by Gforce; 05-21-2017 at 02:48 PM. |
| The Following User Says Thank You to Gforce For This Useful Post: | Scrappydoo (05-22-2017) |
#60 | |
Here's a contemporaneous pr reference: http://australiancar.reviews/Subaru_EZ30R_Engine.php Last edited by Gforce; 05-21-2017 at 10:25 AM. |
#61 | |
Twin lobe Superchargers deliver linear intake pressures. Turbos produce pressures that curve higher as rpm rises. To a point in both cases. |
#62 | ||
#63 |
Here's link describing the spring rate changes:
10% increase front, 15% decrease rear. Other sources confirm that the rear roll bar is up 1 mm to 15 mm. The description of the new rate dampers is picturesque and suggests higher rates in both directions. https://www.motormag.com.au/reviews/...yota-86-review |
#64 | |
"Subaru's AVCS+ system was developed by Porsche and based on their own Vario Cam plus". Subaru's system is practically identical to Vario Cam and produces remarkably similar torque curves. If Porsche did not develop Subaru's system they would have sued for patent infringement. Vario Cam is ten years older than AVCS so, yes, Subaru not only needed help from Porsche they asked for it. As for understanding how positive displacement Superchargers work, yes I do. I have two. Your questions imply that you do not. Read up a bit and get back to me if you discover something new. Hint, PD "Superchargers" have been around since the 19 th century. Back then they were just air pumps used to ventilate coal mines. Engine builders in the early 20th century quickly discovered they worked well to pump air into engines. They don't compress. Boost pressure develops only in the intake manifold. Turbosuperchargers were first applied to engines in the Aero business and they compress the intake air, which is why they have a compressor. The air entering the intake manifold is therefore already compressed. The difference in how these two types of Supercharger work is obvious to the reasonably alert driver. Turbocharging variable rpm engines was unsatisfactory until SAAB developed computerized feedback boost control which everybody now uses. Even Superchargers have computer controlled bypass valves nowadays, instead of just dump valves. You know my shoes are still dry.... |
#65 |
Drives: '15 BRZ RA
#66 | |
Not sure where you cut and pasted the SC stuff from but boost is boost. The history lesson is worthless
| The Following User Says Thank You to Tcoat For This Useful Post: | Vic4uf (05-27-2017) |
#67 | |
Boost most definitely is not boost as you would know had you driven turbo and supercharged engines back to back, as I do on a daily basis. I've owned and driven turbo cars since 1984, my favourite drive ( though not owned!) was a 6.75 litre Bentley Turbo R. The most recent turbo engine I've driven (though not owned) is the Mclaren 12C twin turbo V8. I've also driven essentially the same engine in turbo and supercharged forms and the same turbo engine in both LPT (which is quite like a supercharged engine) and HOT tunes. Shoes still dry, how're yours holding up under the downpour? |
#68 |
Drives: hyper blue
I have the first version of the porsche Vario-cam and the first stateside version of Subarus ACVS parked in the driveway. The B9 has to think about what it's doing sometimes but both have a nice torque curve.
#69 | |||
My feet are not wet and yours can't possibly because they are buried in bullshit in everything you say. I give up. You are a waste of time and energy.
#70 |
Drives: Grrrr
I always thought that superchargers and turbochargers were both compressors. Both driven by the engine, one mechanically, one by waste gasses. The drive type gives them different characteristics.
Simples. |
| The Following User Says Thank You to Scrappydoo For This Useful Post: | new2subaru (05-22-2017) |
| 2017 BRZ Performance Package DD Build | mjanmohammad | Member's Car Journals | 230 | 11-01-2023 12:31 PM |
| 2017 BRZ w/ Performance Package Brake options | mjanmohammad | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 04-07-2017 08:12 PM |
| Impressions of the 2017 BRZ Performance Package | Var | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 03-20-2017 05:35 PM |
| WTB: OEM 2017 Performance package wheels | mjanmohammad | Want-To-Buy Requests | 1 | 03-03-2017 02:35 PM |
| Bristecom's 2017 Subaru BRZ Performance Package | Bristecom | Member's Car Journals | 16 | 01-26-2017 09:05 PM |
