Old 05-18-2017, 02:26 PM   #29
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I've been driving manual for 2 years and still have no idea how to shift smoothly in this car from 1st to 2nd
I didn't feel like I had it down until I had 30k miles on the odometer, and that was with 25k and 2-3 years under my belt prior to buying this car.
I still blow a shift from time to time with nearly 60k miles on this car, 99% driven by me. No shame in it, hell I stalled it pulling into my driveway sometime in the past week, almost forgot it had happened.
ineedyourdiddly
spike021 (05-18-2017)
Old 05-18-2017, 02:30 PM   #30
That's a plus that comes with age ........
The Following 3 Users Say Thank You to humfrz For This Useful Post:
jcw99 (05-19-2017), spike021 (05-18-2017), strat61caster (05-18-2017)
Old 05-18-2017, 02:37 PM   #31
spike021
spike021's Avatar
Originally Posted by Xxyion View Post
haha i had the opposite. All my cars i learned in were MT and my first car was a MT. When i had to drive my friends AT i actually accidentally threw it into 1 and nearly blew up his car lol. Also had the issue where my clutch foot would accidentally hit the brake.
But after driving cars for 16 years now i can drive both just fine.
It's just so odd coming from AT. You need to learn to think quite differently. Like sometimes you'll be on a street and driving AT everything's great, but in a MT you realize "wait, this is actually a slight uphill?" because you stop and then to go into first you need to do a teeny bit more to get it going. Or you're on a slight uphill at a light but in an AT you wouldn't notice, so once you're in a MT and you start falling back a bit (because of being in neutral) you need to know how to handle it. Obviously once you're used to it it's nothing, but coming from AT you basically add at least an additional step for that kind of thing.
Different situations end up needing to be handled slightly differently. It's not a big deal after you've learned but while learning it can be a pain, or at least it was for me.
spike021 is offline   Reply With Quote
Old 05-18-2017, 02:47 PM   #32
StraightOuttaCanadaEh
Wes
lol I hear ya. It's like at some point I just went "ehhh that's good enough" and stopped trying to improve. Once in a while I get it right and the shifts are butter smooth, other times not so much. But then time goes by and I forget what I was doing right to get those shifts and fall into that same pattern. I also stall at the most unexpected times cause I stopped paying attention.
Old 05-18-2017, 07:51 PM   #33
churchx
churchx's Avatar
Drives: 2014 GT86
Was hard for me too to drive AT (w/o manual shift) after MT all life long. Simply didn't felt being in control. Clutch-heavy left foot braked too abruptly (which causes problem now too, when i'm learning left-foot braking for track use), no used-to engine braking to simplify keeping intervals in traffic, tranny unexpectedly down-shifting (or not) resulting in acceleration changes at unexpected times when floored. I'm sure, after some longer getting used to, i'd adjust my die-hard habits, learn left foot braking be less heavy, get in habits how accel work quickness correlates to down-shifts, but after that brief time, loved to get out of it and then feeling enlightenment drive honest-MT again. Humans are slaves to habits.
Old 05-18-2017, 08:07 PM   #34
stevesnj
stevesnj's Avatar
Didn't any of you guys power shift before? I have a few times in this car and was scary and fun at the same time. Here's a sample of someone else doing it. I think if you do it a few times it will be okay. Just be wary that a really bad mis shift can grenade the important parts of the tranny.
Go to 2:09
[ame="https://www.youtube.com/watch?v=jh7mwJoH7vY"]https://www.youtube.com/watch?v=jh7mwJoH7vY[/ame]
My 2016 Build thread
Old 05-18-2017, 08:17 PM   #35
stevesnj
stevesnj's Avatar
Originally Posted by TommyW View Post
Slamming your car into second from first is not a good idea, Slamming into any gear is not a good idea and causes no increase in performance. Learn to shift smoothly and efficiently.
Old 05-18-2017, 09:31 PM   #36
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Originally Posted by stevesnj View Post
You're laughing and your gearbox is crying really big tears
TommyW is offline   Reply With Quote
The Following 2 Users Say Thank You to TommyW For This Useful Post:
stevesnj (05-19-2017), Ultramaroon (05-18-2017)
Old 05-18-2017, 10:59 PM   #37
cjd
cjd's Avatar
Drives: 2017 BRZ
Heck, the goal is to time everything so perfectly you don't need the clutch. When I mess it up on course, I usually end up a wee bit sideways... So that slight lift on the accelerator always happens, it's just a question of when.
C
Old 05-19-2017, 08:18 AM   #38
stevesnj
stevesnj's Avatar
You're no fun
The Following User Says Thank You to stevesnj For This Useful Post:
Ultramaroon (05-20-2017)
Old 05-20-2017, 09:02 PM   #39
TheWhiteWizard13
TheWhiteWizard13's Avatar
Drives: 2013 Subaru BRZ with Invidia N1
Rev matching.
You said it so I don't have to... when your Rpms are dropping mid shift, leave it in neutral (double clutch) give it some gas while in neutral (rev match) and throw it In Gear. You'll notice the bite and smoother transition into gear, watch YouTube videos on rev matching and double clutching, the two are like the ying and yang the two go hand in hand. It's hard to explain double clutching and rev matching through text tho haha
Sent from my iPhone using Tapatalk Pro
TheWhiteWizard13 is offline   Reply With Quote
Old 05-20-2017, 09:22 PM   #40
You're no fun
I've heard it's good for it.
stevesnj (05-20-2017)
Old 05-20-2017, 09:57 PM   #41
stevesnj
stevesnj's Avatar
To some on here it seems as popular as Zika!
Old 05-21-2017, 03:37 AM   #42
JD001
JD001's Avatar
Drives: Subaru BRZ
Double de-clutching on non-synco gears. You don't need to double de-clutch on modern cars but you need to bring the revs up to match the gear hence race drivers brake and same blip throttle to ensure that the lower gear comes in without locking or upsetting the car balance.
Aggressive brz's ScoobySubie14 BRZ First-Gen (2012+) — General Topics 22 01-30-2016 06:05 PM
Mercedes E55 AMG...Fast..but not fast enough. gdrider77 FR-S / BRZ vs.... 18 08-28-2014 03:56 PM
What would you say is more aggressive? TomT2411 Engine, Exhaust, Transmission 16 05-08-2014 05:40 PM
Fast car Fast driver vinyl decal I need help francosolracer Cosmetic Modification (Interior/Exterior/Lighting) 18 10-20-2012 03:43 AM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 05:09 PM
