Old 05-12-2017, 01:58 AM   #379
Exrald
Exrald's Avatar
Drives: 2013 Scion FRS & 2022 GR86
I've only done OE, there was a aftermarket that was supposed to be more durable but it was way more expensive and people still reported failures.
If there's an aftermarket that's cheaper or more durable post it up, I've only seen OE at around $105-$120.
I haven't seen any long term damage from leaving it for a bit but could be wrong. If you've changed sparkplugs on any car before then you can DIY this.
The problem is that it's a boxer engine. it's hard to get in to. I ordered a new set from AutoZone tho. Hopefully, they will last longer. I need to take care of my car. Lol. Thank you!
Sent from my SM-G920I using Tapatalk
2013 Scion FRS
2022 Toyota GR86
Exrald is offline   Reply With Quote
Old 05-12-2017, 09:55 AM   #380
MurderousPandas
MurderousPandas's Avatar
Originally Posted by Exrald View Post
I ordered a pack from AutoZone. They got 20% off sale, so I pretty much got it for cheap... My friend's gonna help me swape coils, but we don't know how difficult it is yet... I hope it'll be easy.
The dealership is pretty cheap and usually next day, and you don't pay for shipping. I don't think anyone else carries OEM coilpacks, just replicas.
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
The Following User Says Thank You to MurderousPandas For This Useful Post:
Exrald (05-12-2017)
Old 05-12-2017, 10:11 AM   #381
Exrald
Exrald's Avatar
Dang. I already ordered my pack. :'( hopefully these Duralast Coilpack will live up to its name. Hahaha
2013 Scion FRS
2022 Toyota GR86
Old 05-12-2017, 11:39 AM   #382
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I did the left side standing in my dark driveway with my gf holding a flashlight, it took an hour because I dropped my socket but I fished it out.
No need to jack anything up or do anything crazy. Just remove what's in the way and get wrenching.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Exrald (05-12-2017), Icecreamtruk (05-12-2017)
Old 05-12-2017, 12:28 PM   #383
Exrald
Exrald's Avatar
Awesome! I'll change all four. So pray for me! Thanks guys!
2013 Scion FRS
2022 Toyota GR86
Old 05-12-2017, 04:04 PM   #384
PulpBrah
Drives: 2014 frs
Coilpack went out at 58k, so I'll go ahead and do the spark plugs while I'm at it.
With regard to lifting the engine, the video does not mention anything about the steps in prepping the engine for being jacked up besides removing a couple of covers. Can anyone pinpoint the bare minimum that needs to be done to jack up the engine?
Thanks in advance.
PulpBrah is offline   Reply With Quote
Old 05-12-2017, 04:24 PM   #385
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open
I think the consensus here is that there is no need to jack or lift the engine. Just unbolt /remove stuff that's in the way to reach the coils/plugs.
Anyone feel free to correct me if I'm wrong as I'll be doing this in like a month 😬
Kronos is offline   Reply With Quote
Old 05-12-2017, 04:46 PM   #386
MurderousPandas
For the driver side closest to the firewall, it might be easier to lift the engine just because it's a tighter fit than all the other tighter fitting coilpacks, but still do-able without lifting.
The most important part to me is patience. I was getting frusterated working in a tight space, made the job harder. Just take your time and be patient. One took me 20 minutes, smaller fingers would've been nice.
Kronos (05-12-2017)
Old 05-14-2017, 12:38 AM   #387
PulpBrah
Drives: 2014 frs
I just did it today. While not completely necessary to unbolt the engine, IMO, you're making your life MUCH harder by not doing so. It is VERY easy to do. Unbolt the fuel line bracket, the HPFP heat sheild, and the strut bar, in addition to the two bolts on the bottom and just jack up the motor. It was really easy to do, and this is my first real DIY deal that I've done that involved this much work.
I will post a pic of my old spark plugs. My sister's FRS is approaching 60k miles so I will make a video tutorial when I do them. I was getting the p0351 code and after replacing the coil and all four plugs, the car runs WAY more smoothly. My old plugs did not look like they wore very evenly - stay tuned and I'll post pics tomorrow or something.
The Following User Says Thank You to PulpBrah For This Useful Post:
Exrald (05-14-2017)
Old 05-14-2017, 12:39 AM   #388
Exrald
Exrald's Avatar
Yes please! Thank you! I'm planning to do mine next week!
2013 Scion FRS
2022 Toyota GR86
Old 06-21-2017, 02:01 PM   #389
empower-auto
Kouki-Monster
empower-auto's Avatar
Am I correct to understand that there was a revision made to parts but no TSB or support from Toyota / Subaru?
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 06-21-2017, 04:16 PM   #390
Kronos
Kronos's Avatar
I'm curious to know this as well.
I'm also wondering how people are lifting their engines to access plugs and coils easier. I assume you need some special tool or jack to lift the engine up?
Old 06-21-2017, 04:23 PM   #391
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
FYI I just got the P0353 at about 43K miles. I changed out #1 coil at about 32K-ish? Just to confirm what we already know. The #1 and #3 coils on the right bank are weak points, so dont be too surprised when they need to be replaced.
Intent > Content
Old 06-21-2017, 05:03 PM   #392
strat61caster
I've gotten #1 and #2 a few times, will likely swap the coil packs this summer when I do the spark plugs for 60k.
ineedyourdiddly
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Shutting off your "key-in-with-door-open" beeper -- it's very easy avusblue Cosmetic Modification (Interior/Exterior/Lighting) 2 08-13-2012 05:29 PM
