Old 05-06-2017, 06:52 PM   #29
JAK_SPYRO
JAK_SPYRO's Avatar
Drives: 2017 Subaru BRZ Yellow Series
The stock FA20 block it self can handle pretty much 500-700 HP if you upgrade the internals. The only reason people blow engines or make holes in their blocks is because a rod or piston breaks and launches into your block at 8000 RPM! So if you upgrade to some 1000HP rods and a low compression piston set for example 9.5:1 or 10:1 you'll be all set. Also don't forget about the valve springs and if you're passing the 400 HP mark, upgrade the crankshaft. Upgrade/replace the head gaskets and the studs also. Other than that, you'll be set for a 350-700 HP BRZ/FR-S/GT86!
JAK_SPYRO is offline   Reply With Quote
Old 05-11-2017, 01:46 AM   #30
Dipstik-sportech
Dipstik-sportech's Avatar
I'm running 600hp at the crank and I have the stock crank, headstuds and gaskets. The cranks on these cars are forged factory so there is no need to upgrade it like the old ej.
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
D_Thissen (05-12-2017)
Old 05-11-2017, 01:49 AM   #31
JAK_SPYRO
JAK_SPYRO's Avatar
Oh nice! Good to know since a new crank is very expensive 😅
Could you tell me exactly what you did to your engine and the internals to get to 600 HP? I'm trying to learn as much as I can
Old 05-15-2017, 11:15 AM   #32
Dipstik-sportech
Just rods and pistons. There was nothing else available at the time it was built
cdrazic93 (06-01-2017)
Old 06-01-2017, 03:57 AM   #33
ajc209
Drives: GT86 Cosworth
Originally Posted by Bfranklyn86 View Post
I may be biased though, knowing that my supercharged will never be able to get me more than 300-350 to the wheel!
Not if you put a turbo behind it
ajc209 is offline   Reply With Quote
Old 06-01-2017, 01:20 PM   #34
Bfranklyn86
Drives: GT86 Harrop S/C
Presumably the turbo would go before it?
It would be an awesome setup, but I didn't hear anything else about that Perrin twin charged FA20DIT, so will assume it blew up.
Bfranklyn86 is offline   Reply With Quote
Old 06-01-2017, 02:12 PM   #35
celek
Resident Gear Head
celek's Avatar
I have seen 752WHP on a stock casting sleeve.
The problem is they wiggle at around 500 causing gasket failure. You can fix this with bigger head studs and sleeves. If you want to go big don't push a limit or skip a corner trying to get the most on a stock casting. will only cause compounded issues for reliability
celek is offline   Reply With Quote
Help! Crawford power block install catastrophe (fixed!!) wootwoot Engine, Exhaust, Transmission 54 02-26-2025 04:12 AM
Wtb Crawford power block builders Dori_86 Want-To-Buy Requests 4 01-05-2017 02:01 AM
WTB crawford billet power block. jupillam Want-To-Buy Requests 1 07-06-2015 05:09 PM
FS Crawford Billet Power Block used jordanrw260 Engine, Exhaust, Bolt-Ons 2 01-16-2015 04:45 PM
Power limit for our transmission? TESTED YET? hmong337 Engine, Exhaust, Transmission 26 12-12-2013 03:22 AM
