| Engine Swaps Discussion of engine swaps. |
#29 |
Drives: 2013 FRS Whiteout
Yes, we tested it under different conditions and played with pressure to make sure that it would cycle the compressor properly as well as react in an over-pressurization situation. The easiest/safest way is to use as much of the FRS AC lines as possible, that way the total system fill is as close to stock as possible. We use the FRS pressure sensor as well since it's already pinned into the body harness.
| The Following 4 Users Say Thank You to Pure Automotive For This Useful Post: |
#30 |
Complete harness, jumper, and m130 in hand, should be installing and starting this week!
#31 |
Drives: 2017 WR BLUE BRZ
Nice! Can't wait to see it running!
| The Following User Says Thank You to ILLSMOQ For This Useful Post: | Sportsguy83 (05-01-2017) |
#32 |
Drives: Nissan GT-R
Subbed. I'm so torn between doing LS and 2J
#33 |
| The Following User Says Thank You to ILLSMOQ For This Useful Post: | Godzilla35 (06-20-2017) |
#34 |
Drives: 2JZ FRS
Old harness built by a company a couple years ago vs new plug and play harness. Car ran, but absolutely nothing oem related worked. Now everything works
![]() after the old harness was out, about 30 minutes worth of install on the new harness and did the first start with a bench test firmware. now we can finish the firmware and base map tune in the actual car [ame="https://www.youtube.com/watch?v=2AWVukPTlnM"]Frs/Brz/GT86 pure automotive performance LS plug and play first start - YouTube[/ame]
| The Following 6 Users Say Thank You to spitfire481 For This Useful Post: | CxG (06-05-2017), Drakiv (07-11-2017), ILLSMOQ (05-06-2017), Lonewolf (06-06-2017), Sportsguy83 (05-06-2017), tirespin782 (05-07-2017) |
#35 |
Awesome! Can barely even pick out the wire harness on the motor...very clean great job!
#36 |
[ame]http://youtu.be/H2oq7VIOUuI[/ame]
| The Following 7 Users Say Thank You to Pure Automotive For This Useful Post: | CxG (06-05-2017), DHitHim (06-07-2017), Drakiv (07-11-2017), ILLSMOQ (06-02-2017), R2RO (06-02-2017), Sportsguy83 (06-02-2017), The Racers Line (11-06-2017) |
#37 |
Great news! Thanks for the update! I'm pumped to get started on mine!
| The Following User Says Thank You to ILLSMOQ For This Useful Post: | Sportsguy83 (06-02-2017) |
#38 |
I Love custom Turbo kits
Drives: Limited BRZ
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | ILLSMOQ (06-02-2017) |
#39 |
Drives: 2013 FRS- Hot Lava
#40 | |
Drives: Limited BRZ
As far as I've learned, (my LS plug and play package is already bought and underway) the airbags are controlled almost completed independently by its own controller and will work with stock steering wheel and stock airbag. Motec implements traction control superior to OEM one that with the plug and play package you can control with the stock traction buttons. Additionally, ABS does fully work with this package. TPMS is a good question, I think it still work but not 1000% sure.
#41 |
Drives: 2013 WRB BRZ
so what's going on with this? Just spun a bearing on my FA20 with only E85 lol. Looking for a swap but 2jz is too heavy for my liking.
#42 |
Drives: 2JZ FRS
Harness is built to order depending on your specs and the firmware package is done. we have 2 kits already shipped out awaiting install, and we have the lsa swapped frs complete here at the shop
| Pure Automotive Performance's White Street Fighter- 2JZ Swap - Formerly the FRSS LS2! | Pure Automotive | Member's Car Journals | 53 | 03-05-2015 06:11 PM |
| Motec M1 Plug N Play | FullBlown | Forced Induction | 89 | 05-09-2014 12:45 PM |
| The New Consolidated Install Thread @Pure Automotive Performance, FT86 Specialists! | Pure Automotive | Mid-Atlantic | 14 | 09-26-2013 10:28 PM |
| **The Eibach Thread** Springs, Coilovers, Sway Bars @ Pure Automotive | Pure Automotive | Brakes, Suspension, Chassis | 1 | 02-06-2013 02:32 PM |
| *Pure Automotive Performance: Project Whiteout FRS Build Thread* | Pure Automotive | Member's Car Journals | 6 | 01-18-2013 11:34 AM |
