Old 05-01-2017, 04:56 PM   #1
Eazy-V
Turbo with OEM front pipe
I have a FBM turbo with supplied 3" downpipe and Greedy EVO3 2.75" catback, but still use the OEM catalyzed front pipe which I think is only 2.25".
What frontpipes are you guys running and how bad is the noise and fumes?
I'm think of getting the Blitz 2.75" catless front pipe, so anyone have this and would gains be big? I have mine tuned to 12psi max.
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73
1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress)
2023 Chevrolet Corvette Z51 Stock
Eazy-V is offline   Reply With Quote
Old 05-01-2017, 05:40 PM   #2
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
I ran a Sydney Motorsport Engineering kit with a Borg Warner turbo at 18 PSI tuned by Delicious Tuning utilising the stock front pipe. I had an SME over pipe and a stock midpipe with only an axleback exhaust.
The main issue I found was boost taper. 18 PSI used to taper to 12 PSI by redline. I swapped it out for the Blitz 2.75" and put the stock axleback muffler on and found my issue mostly resolved!
You have a lot of different piping sizes in your exhaust so it would make sense to bolt up a Blitz front pipe or similar, even if just to cure my OCD.
COO86L is offline   Reply With Quote
The Following User Says Thank You to COO86L For This Useful Post:
Boomerang (05-04-2017)
Old 05-01-2017, 10:06 PM   #3
Eazy-V
How's the fumes and any raspy noises?
I'm trying to find a 2.75-3" frontpipe with a cat...any known available or just custom?
Old 05-01-2017, 10:37 PM   #4
Amputechture
Drives: 2014 BRZ
JDL, Nameless, Full Race, and Ultimate Racing.
Amputechture is offline   Reply With Quote
Old 05-04-2017, 08:42 AM   #5
Eazy-V
Most them seems to be 2.5" or a downpipe combo...do you know any part numbers?
Old 05-04-2017, 01:36 PM   #6
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Im running 3" all the way back without a resonator or cat and it sounds good. Zero rasp an sounds good as hell.
I should just post a sound clip on YouTube for everyone.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 05-04-2017, 02:02 PM   #7
Amputechture
Drives: 2014 BRZ
I don't. Ive visited everyone of each company's websites and can tell you that they are all listed.
Old 05-16-2017, 05:00 AM   #8
Eazy-V
It seems like the only current 3" catted front pipes for the FRS is the JDL and AVO? Anyone have either and which one would you recommend?
Also, since these are bolt-ons to OEM, does anyone know if they actually taper down to OEM size of 2.25" or are they 3" end to end?
Old 05-16-2017, 12:35 PM   #9
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
The JDL is 3" end to end and I am assuming the AVO is also. They are designed to be used with a 3" all the way through setup. That's the most efficient and best way to run exhaust on a boosted 86.
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
Old 05-16-2017, 02:06 PM   #10
Amputechture
Drives: 2014 BRZ
I have a 3 inch downpipe, followed by a 2.5 inch turboback with a Berk catted FP. The berk piece is definetly the biggest restriction, the connection to the midpipe tapers down to 2 1/4....I was so pissed when I measured it.
The Following User Says Thank You to Amputechture For This Useful Post:
Detroiter (05-16-2017)
Old 05-16-2017, 03:09 PM   #11
Detroiter
Detroiter's Avatar
Damn, why would they taper it down that narrow? I feel like it's counter intuitive. Tests have shown our engine has the best exhaust flow at 3in but it is of course louder so I understand the 2.75 and 2.5 to quiet it down some but 2.25 would just be making rasp and less power
Raven
Old 05-16-2017, 03:47 PM   #12
Amputechture
Drives: 2014 BRZ
Berk's explanation was that they wanted the end user to be able to have 0 fitment issues with the OEM catback and be able to retain the factory donut gasket. F'ing stupid if you ask me. 99/100 people that run a front pipe on this car are going to have an aftermarket CBE. They should have just made the bolt pattern on the flange be compatible with the smaller diameter stock flange.
Old 05-24-2017, 10:41 PM   #13
Eazy-V
I went with the JDL ultra quiet catted 3" front pipe with flat flange, hope itvfirs the Greddy EVO3
Old 06-14-2017, 09:01 AM   #14
Bobster
Drives: GT86 GTS
Stock FP good for 10PSI?
Bobster is offline   Reply With Quote
WTT 3' JDL ultra quiet front pipe for Fujitsubo front pipe Trust86 Want-To-Buy Requests 3 03-12-2017 09:59 PM
WTT Invidia catless front pipe for a resonated/catted front pipe nickmerronesucks Want-To-Buy Requests 3 05-10-2016 03:25 PM
FRS Part Out. MAP turbo kit, oil cooler kit, 3" exhaust, front pipe Opposed Engine, Exhaust, Bolt-Ons 15 08-25-2015 12:44 AM
Catless Front Pipe VS Test Front Pipe. What's the Difference? geruta Engine, Exhaust, Transmission 48 04-23-2015 05:07 PM
Gains from aftermarket catted front pipe vs stock front pipe? Vmax911 Engine, Exhaust, Transmission 4 01-20-2014 02:42 PM
