Old 08-13-2014, 01:50 AM   #15
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Originally Posted by qtwre View Post
Interesting that you mention fuel trims because I find my idle is always reading in the -20s. That means it's pulling fuel, right? While a vacuum leak would be causing it to add fuel? Is -20 a lot?
Here is a short Ecutek log in case you or anyone else is interested in taking a look. My issue is that once the car is warm, when I disengage the clutch (press the pedal) while in motion, it keeps the RPMs at around 2k (sometimes it bounces instead.) Sometimes it even propels me in gear with no throttle at 2k rather than slowing to idle. This persists until I put the transmission in neutral and re-engage the clutch. It will then idle nicely so long as it's spinning the input shaft.
So this log is of me moving slowly in a parking lot, then the clutch pedal is pressed and I'm rolling for a few seconds, then stopping.
I'm going to have my mechanic check for a vacuum leak tomorrow because I can't find one by eye and poking around.
This is with a stock fuelling system and AVO turbo.
I briefly reviewed your log. Now I'm no expert so take my findings with a grain of salt. You're log doesn't appear to be a vacuum leak. You're fuel trims would be in the positives at idle, much higher than what you see. I suspect its your tune.
What I suggest is you talk with your tuner if you find no mechanical problems. If this is a base map, I suggest you drive straight to a tuner or find someone who will remotely tune (etune).
rb6freak is offline   Reply With Quote
Old 08-13-2014, 10:55 AM   #16
xwd
-19 to -20inHG is what I read taken right off the brake booster line on an AEM failsafe.
Old 08-13-2014, 04:10 PM   #17
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
PSI is not equal to inHg which is what most gauges read.
Idle should be -18 to -21 inHg.
This. I believe the issue is the OP's tune.
Sportsguy83 (08-13-2014)
Old 08-13-2014, 04:15 PM   #18
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Interesting.
When I first turbo'd my car I was seeing -21 to -22, now I see -18 to -19 generally. When it's really hot and I have been driving for a while it might pull -20.
I have been attributing it to starting to wear down the piston rings, although it seems it is still doing alright maybe compared to others.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 08-14-2014, 10:52 AM   #19
qtwre
Drives: White FR-S
I had a vacuum leak test done yesterday by my mechanic. He pressurized the intake tract with smoke. There was a tiny leak at a fitting on my catch can but it didn't change my bigger problem.
I'm working with my tuner to diagnose it remotely. Hey, at least we all know what a good vacuum reading is supposed to be now. Searching didn't come up with anything so this will help people of the future.
qtwre is offline   Reply With Quote
Old 05-03-2017, 09:57 PM   #20
Kris86
Kris86's Avatar
Drives: RHD Gt86
What ended up causing the vacuum leak?
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 05-03-2017, 10:27 PM   #21
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Is there a Torque Pro PID for vacuum?
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
Somerandom18 (05-03-2017)
vacuum at idle/decel jamesm Engine, Exhaust, Transmission 7 09-07-2013 07:04 PM
Seeing more than expected? CLTBRZ BRZ First-Gen (2012+) — General Topics 26 07-09-2012 03:47 PM
Expected Price of car in 3-5 years? FRSDREAMER Scion FR-S / Toyota 86 GT86 General Forum 72 03-20-2012 06:44 PM
BRZ expected to be at LA Auto Show MF_DEUCE Southern California 9 10-18-2011 09:21 PM
Not what I expected. Casual Scion FR-S / Toyota 86 GT86 General Forum 34 11-23-2010 07:25 PM
