| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#365 |
Country Boy 4 Life
#366 |
Drives: Fr-S 2.0 Release
i believe that person's wheels are actually +45
http://www.ft86club.com/forums/showthread.php?t=101096 but if +45 will work 42 shouldn't be a problem |
#367 | |
Country Boy 4 Life
+45 is 3mm closer to the spring/strut compared to the +42. So, If you do not add camber and get the same width tire, then yes probably. Judging from what the above posts have described. Also, a 3mm slip spacer would help if it was too close. Good luck! |
#368 | |
I'm assuming different brands offsets and widths are different because i see some running +45 on stock suspension with no issue and some other brands it doesnt work or maybe they have the wrong width etc. |
#369 | |
Country Boy 4 Life
Confused myself. What I said is correct, but you don't want the +45, so the information in the second paragraph was irrelevant. Sorry. Last edited by Leonardo; 10-24-2016 at 10:05 PM. |
| The Following User Says Thank You to Leonardo For This Useful Post: | novice (10-25-2016) |
#370 |
good to know about accuracy of offset. thanks for clarifying.
#371 |
Drives: BR86
Before camber bolts went on I had a mountain of clearance - about 10mm from memory, so -1.5deg neg camber @ that wheel height made quite a difference for me. +45 will push the inner mounting face further out towards the exterior of the car which means the inner wheel clearance will increase by 3 mm compared to what I have so expect 7mm inner wheel clearance on 0 camber = easy fit on stock suspension.
#372 | |
#373 |
Drives: BRZ Limited; GR86
how do you guys clean your wheels. I have the Winning Blue and idk what products I can use on them
#374 | |
Drives: 2017 Subaru BRZ WRB PP
#375 |
Drives: BR86
http://www.autotechnik.com.au/ Sydney Australia - recommend you buy from a local supplier
#376 | |
#377 | |
Drives: BR86
#378 | |
Drives: Raven 86
Last question, do you think I'll rub on stuck suspension if I did 235/40 tire or should I stay with 225/40 tire? |
| Wheel Directory: Gram Lights 57Xtreme 17x9.0 +40 | L8Apex | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 71 | 08-05-2023 09:20 PM |
| Wheel Directory: Gram Lights 57Xtremes 18x8.5 +45/18x9.5 +40 | WorkoArt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 02-18-2017 06:46 PM |
| Candy Red Gram Light 57Xtreme 18X9.5 +40 | ugadogs_11 | Wheels and Tires | 8 | 10-03-2013 09:04 AM |
| FS: Gram Lights 57Xtreme 18x8.5, 18x9.5 | funcheung | Canada Classifieds | 7 | 09-16-2013 05:01 PM |
