Old 04-30-2017, 01:20 PM   #43
Lukevick65
Drives: 2013 Firestorm FRS
Boats are meant for water though...??
2013 Firestorm FR-S, 17 brz bumper swap, seibon CSL carbon trunk, spec d headlights, x force 3 inch catback, 25mm spacers, 2 JL audio 10’s on 1000 watts
Lukevick65 is offline   Reply With Quote
The Following 2 Users Say Thank You to Lukevick65 For This Useful Post:
Ghost of Akina (04-30-2017), WolfpackS2k (05-04-2017)
Old 04-30-2017, 01:33 PM   #44
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
I'd go WRX or Camry.
Old 04-30-2017, 01:56 PM   #45
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
If you go mustang get the track pack, or whatever they're calling it with the current model . I had a 14 track pack with Ford racing suspension . It handled well (not twins well but still) and held it's own at autcross events.
The power was intoxicating and the exhaust note was glorious . Insurance was stupid high and the interior was cheaper than Subaru's play school crap (the new models have addressed this issue. )
The car rewards good drivers and pushes bad ones. So if you don't act like a tool before you learn the limits of your car you won't take out any crowds .
Another vehicle to consider ( and the one I'd have if I still lived in Texas ) would be a Chevy SS . Sleeper as hell , nice interior and it's a 4 door so it's usable . Also not many tools own them because they're not flashy so insurance isn't as bad
Sent from my Pixel XL using Tapatalk
Ricepuddin is offline   Reply With Quote
Old 04-30-2017, 02:02 PM   #46
rcowboy
rcowboy's Avatar
Drives: 2017 BRZ Sport-Tech
Originally Posted by Riftur View Post
Curious if anyone knows if other muscle cars besides the Corvette shuts down 4 cylinders while just cruising?
Yes, which lends me to say the Hemi Challenger doughs.
The EPA and some professional reviewers give wildly disparaging fuel economy numbers.
The protection agency claims 19mpg on mid-grade fuel. It could be an achievement if someone could drive with mandatory short-shifting and feathering the throttle, to see if 20mpg is obtainable.
Interestingly, the manual version uses the Tremec TR-6060 unit. One of the two(and only) recommended transmissions used in a FR-S/BRZ LS swap.
rcowboy is offline   Reply With Quote
The Following User Says Thank You to rcowboy For This Useful Post:
Riftur (04-30-2017)
Old 05-02-2017, 11:47 AM   #47
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
yes...
The automatic camaro does.
Jaden
Jaden is offline   Reply With Quote
Old 05-03-2017, 11:24 AM   #48
unhappymeal
Drives: 2018 Miata RF, 2017 Golf R
Originally Posted by MurderousPandas View Post
The only thing great about the challenger would be the room. Twins are light, nimble, and pretty gas efficient. Also, the twins have aftermarket parts that are available. Yeah, you can change the tail lights, tint, and put 22's on your Challenger, but what you can do with a twin reliably is pretty great. The twins only need a bit more power and grip, not to the point where something breaks every thousand miles.
Sent from my HTC6535LVW using Tapatalk
NVH and ride comfort too. Despite the ancient architecture, the LX platform cars with the dual mode exhaust are substantially more quiet than the twins at highway speeds. They're also less twitchy over road imperfections.
Also, the platform and engine on the V8 models, while antiquated, are extremely reliable. The transmission reliability issue of the past was solved when they switched to ZF units for automatics across the line-up.
I will say, it's definitely a very different car. I took out its platform mate, the Charger 392, for a test drive and while it corners well, there's no hiding the weight. It's also deceptively under tired (245s or 275s depending on trim) for an engine that produces that much torque.
unhappymeal is offline   Reply With Quote
Old 05-03-2017, 11:28 AM   #49
unhappymeal
Originally Posted by DAEMANO View Post
Challenger is a big GT cruiser, it wont' feel quick for very long. Like @Tcoat said above you'd be much better off with a WRX (WRX hatch from a few years ago for max versatility and good pricing.) or a hot hatch of some sort.
Alternatively, you can get a 2013-2014 BMW 328, Cadillac ATS 2.0T, or Infiniti Q50 for $16-$20k if you want something more serious.
All the above will offer more power and versatility. None will feel as light and handle as well (RWD) as your twin.
So really you need to start over and decide if you want a lightweight sports car, a muscle car, a hot hatch, or something else before you make any more financial moves.
I have an ATS 2.0T and while you feel the higher CoG, the car feels surprisingly light for something that weighs ~500 - 600 lbs more than the BRZ.
Having said that, I wouldn't say it's much more practical than the BRZ. You do get more rear passenger room, but the trunk is actually more narrow and shorter than the BRZ. I could fit a 7 foot Christmas tree on a diagonal with the seats folded down in the BRZ. You can't do that in the ATS because the chassis is setup to accept RWD and AWD, which causes intrusions in the trunk. Also, the subwoofer is mounted in the top of the trunk and that cuts into the opening size.
The Following User Says Thank You to unhappymeal For This Useful Post:
DAEMANO (05-03-2017)
Old 05-04-2017, 01:30 PM   #50
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
I can't for the life of me understand why the OP wants to have a car in NYC. I had very limited use for one when I lived there. Do you only spend time in the outer boroughs? Owning a car in the city is just an unnecessary expense for most people, though I realize people have different situations.
I wouldn't worry about gasoline prices. The only way they're going to have any sort of notable increase in the coming years is if we go to war with Iran. Otherwise $2-3/gallon gasoline is here to say for well over 5 years. For which you can thank the American energy industry.
Altogether though, I've always felt that a WRX is the best vehicle for an NYC environment. AWD for inclement weather as well as sure footed traction for jumping out into traffic from a standstill. And a fairly compliant suspension to soak up all the ridiculous potholes and other piss poor road conditions.
Old 05-12-2017, 09:19 AM   #51
Antonovich
Drives: '13 BRZ, 04 rust bucket Suburban
That might have been an option, if it was readily available in manual. But all I've found was either auto, or a 2017 model which is over my budget. I would love to see some more of those Muscle Sedans. Especially those Aussie ones: the HSV's, the FPV's.
I want a manual. When I become a boring middle-aged human being, I'll consider an auto.
If I do get a Challenger, wider tires is one of the first things I'll get for it. Along with those old-school style rims.
What a ridiculous thing to say! I need a car to get to and from work! And to generally drive to places in comfort. It takes me about 20-40 minutes to get to and from work, depending on traffic; VS 2-3 hours taking public transportation.
I do agree on the potholes thing though. The roads are shit in NYC! I bought some rims and tires for my BRZ (Enkei TS10's wrapped in Continental Extreme Contact tires), hit a pretty big pothole at night while it was raining because I couldn't see it well enough. Put 2 dents into both right side rims. Not major, but noticeable up close.
Antonovich is offline   Reply With Quote
Old 05-13-2017, 06:04 AM   #52
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Forget the ride. Forget power vs agility. None of that matters. You are thinking about buying a Dodge.
The fiat-Chrysler Group (and specifically dodge) have the WORST reliability ratings of any brand in the US right now. If you are thinking this is the same car or the same company as the dodge your Dad had- you are wrong. You will be trading in reliability and customer service for a car that has neither. You will live to regret buying that car and it will suck every last dollar from your wallet.
Don't trust the reviews you read- most are paid for. Look deeper for the info on this car. Also consider the company and customer service you are buying with the car. There are much better muscle car options out there,
guybo is offline   Reply With Quote
Old 05-15-2017, 11:44 PM   #53
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
If we're talking about Aussie sedans, why not look for a Pontiac G8 GXP? I assume it's hard to find one of those as well? Are you strictly looking for a new car?
Old 05-16-2017, 05:08 AM   #54
Antonovich
Like I said before, I wouldn't mind a 4-door V8 sedan, with a manual, but I'm very skeptical about buying an older model car from a company that doesn't exist any more. Just did a search, and all of them were over 80k miles.
On another note; there is another option. My mom wants to get rid of her old ass 2002 Nissan Maxima (with a lot of pressure from me) and get a small to mid-size SUV. She's set on either Toyota Rav-4, Nissan Pathfinder, or a Subaru Crosstrek. So if she buys something like that, I could use it for any heavy lifting. Especially since she rarely drives as is. While I can get my motorcycle licence (already got my permit) and buy a Ninja 650 for some excitement.
Old 05-16-2017, 07:50 AM   #55
Yardjass
Yardjass's Avatar
Drives: '14 Monogram, '95 Miata, '90 300ZX
So you want to sell your light, slow car and buy a fat slow one?
Yardjass is offline   Reply With Quote
Old 05-17-2017, 07:35 PM   #56
Cloud
Porsch-AH
Cloud's Avatar
Drives: 2007 Porsche Cayman S
It sounds like you want a slightly used luxury sedan/coupe. probably a bmw 5 series.
Cloud is offline   Reply With Quote
Thinking of selling 86 South Africa AFRICA 7 04-12-2017 12:21 AM
V6 challenger vs frs/brz Nictheguy FR-S / BRZ vs.... 58 04-16-2015 06:41 PM
Thinking about selling my srt exhaust once it gets here for same price. Want? Frsexxxy Engine, Exhaust, Transmission 0 02-28-2013 01:45 AM
BRZ next to a Challenger Hanzo BRZ Photos, Videos, Wallpapers, Gallery Forum 48 07-22-2012 11:21 AM
plates GT86 - thinking of selling mikedsilva AUSTRALIA 2 07-01-2012 05:16 AM
