Old 05-09-2016, 07:10 PM   #169
Chaetagnath
Drives: Whiteout FRS
Originally Posted by nunonuna View Post
I don't know if it will help you or not, but after I swapped my battery for new one, it never happened once for 3 months so far. It seems like it happens if the battery charge is lower, at least in my case. I was lucky that I was covered by warranty from Braille. Since my battery is lightweight AGM from Braille, I cannot say it is the case for everyone, but it worked for me.
Got a new battery, fixed the problem.
Chaetagnath is offline   Reply With Quote
The Following 3 Users Say Thank You to Chaetagnath For This Useful Post:
Lorico (08-29-2016), nunonuna (05-09-2016), XtremeMaC (05-10-2016)
Old 08-08-2016, 11:58 AM   #170
kennyd8606
Drives: 2013 scion frs
hi can u show me where can I buy that keyhole slot cover at I got a push to start install in mine but can't find that cover for the key hole anywhere
kennyd8606 is offline   Reply With Quote
Old 08-08-2016, 12:02 PM   #171
XtremeMaC
Drives: Asphalt Grey FR-S
Hello P/N is 34348CA000VH
I've purchased mine from Hodges Subaru
2013 Asphalt Grey FR-S MT VIN: 7086XX
XtremeMaC is offline   Reply With Quote
Old 08-08-2016, 06:48 PM   #172
kennyd8606
thank alot for the reply!!
Old 11-09-2016, 01:12 PM   #173
Lorico
Drives: 2015 FRS
doesnt seem like amazon carries this any more
Lorico is offline   Reply With Quote
Old 11-09-2016, 03:33 PM   #174
XtremeMaC
Amazon still carries it. Here is the link
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 11-22-2016, 12:54 AM   #175
dejahboi
dejahboi's Avatar
Drives: 13 FRS - Boosted
Remove the piece in the back with long nose needle nose pliers, and there is more room to get at the steering wheel lock.
Once that’s out you can reinsert the ignition cylinder if you like (or leave it out).
I did the third method, and removing that little peg will engage the steering lock which defeats the purpose of disabling the lock itself.
I had to learn it the hard way and find a way to reinsert the little peg back into the cylinder. Instead what I end up doing is leaving that back piece and rotating it to the right locking the peg in place. I did everything else (remove the harness from the ignition) and its working fine. I also did everything on the steering column without removing the ignition assembly.
dejahboi is offline   Reply With Quote
The Following User Says Thank You to dejahboi For This Useful Post:
Chaetagnath (11-22-2016)
Old 12-21-2016, 06:53 PM   #176
meekrob
Drives: red
wow awesome write up, helped a lot, thanks!!
meekrob is offline   Reply With Quote
Old 04-30-2017, 02:29 PM   #177
blindsta
Drives: Toyota Corolla 2009
Hi I want to buy the EasyGo system for my corolla 2009, and I want to know if it has given you problem or the product is recommended?
blindsta is offline   Reply With Quote
Old 05-02-2017, 11:28 AM   #178
nunonuna
nunonuna's Avatar
Shoot!!! Price of this kit is reduced significantly lol. Amazon sells it for $150 now. LOL
nunonuna is offline   Reply With Quote
The Following User Says Thank You to nunonuna For This Useful Post:
infinitewhiskey (05-03-2017)
Old 05-03-2017, 08:30 AM   #179
blindsta
Can someone tell me if the system is recommended or gives many problems please
Old 05-03-2017, 09:53 AM   #180
nunonuna
nunonuna's Avatar
Assuming you read this thread completely, there is only one minor issue related to remote start. If there was more problem, few of us would already posted something in this thread. So I would say no headache at all~
Old 05-03-2017, 10:43 AM   #181
blindsta
Thanks for your reply, i will buy it and let know here the result of whether it worked or not
Old 05-03-2017, 11:04 AM   #182
XtremeMaC
wtf? firestorm color $187. rest shows $632. I'd buy the firestorm and get it painted instead, or not even use the door handle
easygo, remote start
STI Push Button Start Proud of BOXER Cosmetic Modification (Interior/Exterior/Lighting) 117 08-05-2019 05:19 PM
Push Button start... usptwins DIY (Do-It-Yourself) Guides 155 07-31-2019 11:10 AM
Q: push button start frs blanco Electronics | Audio | NAV | Infotainment 8 08-09-2013 04:58 PM
BRZ STI push to start button notFRS Interior Parts (Incl. Lighting) 4 04-24-2013 12:24 PM
TRD push start button nix Australia Classifieds 1 11-27-2012 12:53 AM
