Old 05-01-2017, 01:53 AM   #995
kzale1249
Drives: 2015 Scion FRS
Originally Posted by allowe View Post
Was it used or new? You should've flashed it back to stock right away it only would've taken 10 minutes and peace of mind knowing the can't bitch
I did managed to flash it back to stock, but at the same time I'm worried that they can check the last time i flashed to stock (which was directly before I brought my car to toyota). I really hope they wont find out tho..
kzale1249 is offline   Reply With Quote
Old 05-01-2017, 02:00 AM   #996
kzale1249
Some people really like making others feel like shit hence why the world we live in sucks. @kzale1249 go to the dealership and play dumb and blame it on them. Your car has a warrenty for a reason. If it's used, don't admit to it being tuned. They might think it's the previous owner. Depending on whether you live in Canada or the US. There is a lemon law and Canada has CAMVAP. Don't pay a dime until you've exhausted every possibility. The oil warning light should've came on, if the car loses that much oil in that many kms, your car is either burning oil or leaking which are both "manufacturers defects" if you live in Ontario I can come with u to the dealership. I've dealt with bs like this before and I have friends who dealt with CAMVAP before. If there is anything I can do to help, please let me know.
Crap I didn't see where u were living. Well if you need anything man let me know. Sorry to hear about ur car!
Thanks a lot man! I really appreciate your support. I'll sure to let you know if I need help. So far, there are no futher updates from toyota, i guess its because of the weekend. Again, really appreciate your support!
Old 05-01-2017, 07:03 AM   #997
steve99
Drives: FT86
If
With the standard dealer software they cannot tell when the car was flashed or look at flash counters if their actually is one.
When you flash to stock with oft its 100% stock rom no licencing or anything else left behind. Checksum is same.
A reflash looks same as an ecu reset to them ie removing battery connection or a flat battery​ as it just resets all the timers in ecu. Thier is no realtime clock in ecu it just has counters from last ie it was reflashed or reset ie power removed or flat battery.
It may be possible for some super guru from toyota or subaru to dig further but ive not seen definitive proof that its possible evertthing seems to be lost on power rest besides the rom area. It unlikey they will investifate further if ecu rom is stock and you don't have substiantal engine mods or something like an oil cooler that couls have leaked
tato.valverde (05-02-2017)
Old 05-03-2017, 03:25 AM   #998
BRRRZZZ
i just did a quick data log and saved in csv file. anybody with better knowledge free to take a look for me.
i also set my alarm to adv multi <1. i see it blinks sometimes when i look at the parameters but is always showing 1?
ltft once in a while will get to around -10.5 as well
thanks, im new at this.
im running stage1 oft tune.
http://www.datazap.me/u/brrrzzz/log-...7?log=0&data=1
BRRRZZZ is offline   Reply With Quote
Old 05-03-2017, 04:19 AM   #999
steve99
Drives: FT86
Iam of 1 all the time is good means minimal knock
Afr is goid
Fuel trims are gois except as idle so is ok
If it not causing you any hesitation off idle dont worry, if your kean you could take 5% out of the maf fliw numbers at the idle flow rates
BRRRZZZ (05-03-2017)
Old 05-03-2017, 04:36 AM   #1000
BRRRZZZ
Afr is goid
thanks so much!!!
Just wanted to make sure everything looked alright. still going to look at params day to day, but now i am confident to push it hard.
Old 05-03-2017, 03:05 PM   #1001
BRRRZZZ
is the stage1 original tune on the oft 91 or 93oct?
i modified a 91oct stage 1 tune on romraider to get launch control, and it doesnt seem to want to pull as hard as the stage 1 original tune that came preloaded on the oft.
Old 05-03-2017, 06:51 PM   #1002
steve99
Drives: FT86
I think the preloaded tunes are 93
BRRRZZZ (05-04-2017)
Old 05-04-2017, 12:21 PM   #1003
pancake
Drives: 2015 BRZ Limited MT
Doesn't the original OFT tune come with launch control enabled ?
pancake is offline   Reply With Quote
Old 05-04-2017, 12:55 PM   #1004
BRRRZZZ
i bought mine used, may have been early units without lc yet? not sure, it wasnt enabled.
Old 05-04-2017, 03:38 PM   #1005
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
I am pretty sure they do not have launch control enabled by default. Mine did not, that is for sure (when loaded with OTS maps).
justinco is offline   Reply With Quote
Old 05-04-2017, 03:49 PM   #1006
Teseo
Drives: frs
Weird, mine came with LC and was set to 5k rpm
Old 05-04-2017, 03:56 PM   #1007
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Really? How did you activate/enable it?
Maybe I had it and just didn't know how to use it :p
Old 05-04-2017, 04:01 PM   #1008
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
The ots maps are set to 5500 rpm, that might be why you haven't noticed.
When under 6 mph the rev limit is lowered to the LC rev limit. Just push the clutch and gas to the floor, it should hold revs at 5500rpm, let the clutch go and you launch in a cloud of tire smoke and clutch dust. :P
The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post:
justinco (05-04-2017), Teseo (05-04-2017), trvth (05-04-2017)
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 08:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 09:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 03:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 03:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
