Old 04-25-2017, 10:39 AM   #3123
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
weird question:
If the rules of certain series force me to use stock sway bars and stock end links with my RCE T2s, would corner balancing be possible? Are there any tricks like slotting the end link mount holes etc. that might help?
Thanks in advance
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
Old 04-25-2017, 11:13 AM   #3124
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by 200hp/tonne View Post
weird question:
Thanks in advance
Leave one loose? I'm sure you could slot, but I don't know how that would hold up over time. And there's not much room to work with for slotting either before you start being unable to tighten things down. That may also not be considered in the spirit of the rules.
Old 04-25-2017, 12:11 PM   #3125
200hp/tonne
Drives: Raven Fr-S
The front is easy, just a few shims under the sway bar (bushing) mounting plate on one side will be enough to adjust height. I can't think of a way to adjust the rear, offset bushings maybe?
Old 04-26-2017, 09:53 AM   #3126
cjd
cjd's Avatar
Drives: 2017 BRZ
Only place would be the bar end, unless you slot the lca I guess... Still not sure it would pass the rule check. I imagine that the lack of adjustability is the reason for specifying stock endlinks. Slotting struts for camber is either explicitly allowed or isn't legal in all rulebooks with which I am familiar (not many, mind)... That wouldn't be any different for swaybar mounting and the ability to dial out preload.
Old 04-27-2017, 03:10 PM   #3127
HamburgerSushi
Drives: 2017 Subaru BRZ 6MT, Perf Pack
No worries...yes the RCE Yellows are a good fit for the PP Sachs dampers.
Just a note though, I would only get the Starter kit lite if you have a very good shop doing the install. The rear camber bushings are a PAIN to install and many shops have screwed it up or take a very long time ($$$) to do it. The alignment process is also more difficult.
The "Cambo" package is a little more money up front, but the rear LCAs are super easy (and cheaper) to install and align. In general I recommend that package instead.
- Andrew
Hi!
Thank you for this recommendation. I am in the same boat - I've got the 2017 PP and am hesitant to just get a lowering spring for the sake of spring/shock matching. I am wondering:
1. What is the change that comes with the Sachs dampers? Is the change exclusively in the shock absorber (to perhaps a more aggressively valved unit), or did Subaru low-key swap out the springs as well?
2. Why your Yellow series and not the Tarmac (firmer & more progressive & with tender coil portion)? Would the Tarmac be under-damped? Similarly, have you guys had any experience driving a PP car with the Sachs dampers and your Yellow or Tarmac springs?
Thank you!
HamburgerSushi is offline   Reply With Quote
Old 05-02-2017, 04:37 PM   #3128
MechOps
Drives: 2013 BRZ Limited
Hey guys. I installed TRD springs last summer with stock struts since I wanted to reduce some wheel gap with about an 1" drop. I like the setup especially when body rolls are a lot less than stock. Lately though, I've been entertaining the idea of getting coilovers.
I'm looking for a setup that's geared more towards ride quality. The TRD springs are great with stock struts. But I can definitely do better for ride quality. I DD the car with some autoX events perhaps 2 times a year. I'd like to get a comfy setup with some spirited driving along the way. I have driven a friend's brz with KW V2s l, and I really like them in terms of performance and comfort.
My current setup mods:
TRD springs with Stock struts
OEM crash bolts for front camber
235/40/18 front
255/40/18 rear (I know I know, staggered. Going for looks here I suppose )
Tires are continental extreme contact DWS
Looking at coilovers due to my thick tires. Budget is ~$2000. What do you guys think or recommend?
MechOps is offline   Reply With Quote
Old 05-02-2017, 04:43 PM   #3129
Originally Posted by HamburgerSushi View Post
Hi!
Thank you!
Sorry missed this earlier!
1. I'm not 100% certian if there is a difference in PP spring rates vs. standard spring rates. But I believe all 2017 spring rates are slightly different compared to previous years. Rear swaybar is slightly larger too. The shock absorbers are actually more refined than the older suspension...without much of a tradeoff in handling (if any). I'm still trying to get a set to put on the shock dyno.
2. Yes we recommend aftermarket shocks for our Tarmac springs. They might be OKAY with the PP shocks, but I honestly haven't tried it so won't recommend it yet. The Yellows ride really nicely with the PP shocks.
- Andrew
jmark (05-11-2017)
Old 05-02-2017, 04:45 PM   #3130
235/40/18 front
The KW V3s would work well for you.
- Andrew
Old 05-02-2017, 04:49 PM   #3131
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
KW V3 are a good option.
Old 05-10-2017, 03:36 PM   #3132
SorryTires
SorryTires's Avatar
Drives: 2013 FRS
My local track is quite bumpy and there some bumps mid corner that currently upset the car so im looking to improve the cars ability to soak up bumps. Currently running tein s-tech springs which are way too soft in the front causing the car to dive and roll like crazy under trail braking. I imagine those mid corner bumps are making me hit the bump stops but the factory bump stops must be quite progressive because I cant feel it like i have on previous cars.
I know getting springs with proper rates will help but I am looking at coils anyway for the height adjustability. I have a couple questions hopefully the more experienced can answer:
1. what spring rates would you suggest for 245 MPSS or typical 200 tread wear tires on a rough track? I was thinking 5k front and rear as that's what the s-techs are in the rear and they seem to work well.
2. Obviously the choice in damper will have a big effect so is it worth getting an adjustable damper to play with the compression rates? or will a preset damper provide 90% of the benefit at a lower cost?
I'm currently debating between RCE Tarmac 0/KW V1 on the non adjustable side. For adjustable I was thinking Tarmac 2/KW V3, keep in mind I have zero experience setting up adjustable dampers but like the idea of learning.
I also wanted to say thank you so much to RCE and CSG for taking the time to educate people like me, ive learned a lot from just reading these threads
SorryTires is offline   Reply With Quote
The Following 2 Users Say Thank You to SorryTires For This Useful Post:
Clipdat (05-10-2017), CounterSpace Garage (05-10-2017)
Old 05-11-2017, 11:33 AM   #3133
OND
OND's Avatar
Drives: 2023 BRZ
Do you have the stock spring dyno charts with bumpstops? I am wondering how much progressiveness they add and at what point of travel they start working.
OND is offline   Reply With Quote
Old 05-11-2017, 08:02 PM   #3134
churchx
churchx's Avatar
Drives: 2014 GT86
OND: and imho with stock ones one should include how rates change after reaching bumpstops, car may often ride at with soft stock spring rates.
Old 05-12-2017, 02:33 AM   #3135
renfield90
The Stig's German cousin
1. I would soften sway bars or make shock changes to deal with rough/bumpy track before I reduced spring rate. Just my two cents. Softer sway bars help make the suspension more independent.
2. *If* you know what you're doing with the adjustable shocks, or are willing to learn, they are far superior. The downside to this is that if you're tempted to try and fix every handling issue with your shocks, you can end up with a car that drives worse than stock (and yes, I've done that more than once now). So realize this is a lot of work, and a lot of trial and error and note keeping on what does and doesn't work, but you will be able to optimize the shocks for different surfaces/conditions/tires/etc.
If that doesn't interest you, a shock package properly matched to its intended spring rates will still do you a world of good. When the shock is working right, it really doesn't need to be touched anyway.
I would opt for the RCE packages over the KW packages. IMO RCE did a way better job with spring rate selection.
The Following User Says Thank You to renfield90 For This Useful Post:
strat61caster (05-12-2017)
Old 05-12-2017, 04:42 PM   #3136
1. 6k front and rear would be a good fit for those tires on bumpy streets and tracks....with a good adjustable damper you'd be happy with 7k too and be a little faster.
2. Adjustability is nice to have if you usually drive on a bumpy track. I'd be perfectly happy with a non-adjustable for a street car that sees occasional track time but a 2 way like our RCE T2 or KW V3 does let you dial things in just right for your specific car and track. It can be a little confusing, but we give you a good baseline setting and can help you dial everything in.
- Andrew
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
