Why Adjust Camber?
Hey guys, so I want go get the TEIN STREET BASIS Z Coils, but a friend is telling me to get the TEIN FLEX Z Coils because you can adjust camber.
I know what camber is, but would it really be a big deal to be able to adjust camber? What would the benefits be of adjusting camber even if it's not that much? |
#2 |
Not a troll
Do you want to understeer into a wall on the track or would you rather go around the corner instead?
| The Following 5 Users Say Thank You to Cole For This Useful Post: | Sam.Vera (10-14-2023), Stang70Fastback (05-01-2017), TheWhiteWizard13 (05-06-2017), tony-brz (05-02-2017), wparsons (05-02-2017) |
#3 |
#4 |
Drives: 2014 Scion FRS (Asphalt)
Like Cole was hinting at. Adjustability with camber is good if you want to control understeer. Also it can help with uneven tire wear. When you drive aggressively with stock camber settings, you will notice that the shoulder see of the tire wears faster than the rest. If there's another incentive to get the flex z over the basis it would be that the flex z has much better dampening and therefore will ride much better.
#5 |
Drives: Subaru BRZ Limited
+1 for tire wear on track. I was destroying the outside of tires even with -2.0 degrees. Now running -3.0 and it's a lot better. Probably need -3.5, but it is a daily driver!
#6 | |
What about if it's just a daily with no track use? Sent from my iPhone using Tapatalk |
#7 |
Drives: '13 FRS - STX
Being told the answer is one thing, knowing why is another.
Camber plates are added complication, if you're not looking to improve handling performance, KISS: keep it simple stupid [ame="https://www.youtube.com/watch?v=1fvJMxErfms"]MacPherson Strut - Explained - YouTube[/ame] |
| The Following 3 Users Say Thank You to strat61caster For This Useful Post: |
#8 |
Huge E85 fan!
Drives: 2016 Scion FRS
Extra negative camber helps the car handle a little bit better. It also improves grip to a point. More camber does not necessarily mean more grip and better handling- it's all about enough camber. Too much will mean worse handling and less grip. More camber on a street car will also shorten the lifespan of your tires.
On a street car, there are lots of ways to change the balance of the car. At stock, this car is very neutral and has very little understeer. Camber is one way to change that balance. Know what you're fixing before you fix it. It's really not accurate to talk about under/oversteer as a thing because it happens for different reasons in different phases of the corner. There's corner entry balance, balance at the apex and track out balance. Camber can affect any phase of the corner, but front and rear camber have to be considered. If you get adjustable coilovers and you don't know anything about this stuff, you will only hurt your car's handling. Most people with adjustable suspensions think they know about it and have them dialed in very wrong. The wheel rate and damper settings have a huge effect on handling too. Your right foot has a lot more effect on your car's balance however. Practice that. |
| The Following User Says Thank You to guybo For This Useful Post: | Gforce (05-01-2017) |
#9 |
Drives: 2013 Subaru BRZ
Camber is not well understood. The idea is to set camber so that the contact patch is evenly pressured when the suspension is at the most extreme angle expected for the track you're on.
For road use you want camber set so that in normal cornering the contact patch is flat and evenly loaded across the tread. Too much negative camber overheats the inside tread rib and reduces total grip. For these cars 1-2 degrees negative is the maximum camber you want at the rear. For front camber zero or close to it is best for street use. The chassis already exhibits oversteer under drop throttle or power on so you do not need much camber if any at the front unless you are tracking the car. For good illustration look at F1 cars. They run less front camber under 2017 rules than they did before the front tires were allowed to be so wide and very litle rear camber. |
| The Following User Says Thank You to Gforce For This Useful Post: | MatthewFRS (05-02-2017) |
#10 |
Drives: 2013 FR-S 10 series [755]
It is better to have a adjustment than regreting that you don't later.
Camber/Dampening can give you better performance and ride quality. |
| The Following User Says Thank You to FR-Sky For This Useful Post: | MatthewFRS (05-02-2017) |
#11 |
Drives: 2014 GT86
And why again F1 argument is being brought up. :/
Why not bring up alignment settings of monster trucks? They should be as applicable then F1's. And 1-2 deg neg. camber rear, zero camber front for street? Oh, yes, of course there will be a bit oversteer due mass transfer from lift off & it's not hard to get power oversteer with stock low-grip tires, but it's driver inputs induced behaviour, car is understeer-ish with stock zero camber all around, why make it much more understeery than it is? Maybe rather worth be more mindful how one drives then simply mash up accelerator everywhere and steer with .. ehemm, alignment to compensate wrong control inputs. |
#12 |
Drives: FR-S Whiteout
Because all the cool kids are doing it. KISS Simple. lol
Intent > Content
cowardice is the mother of cruelty. |
| The Following User Says Thank You to solidONE For This Useful Post: | strat61caster (05-02-2017) |
#13 | |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
Going cheap in general for coilovers will probably lead to regret later. I'd spend a little more now. Even if you dont end up using the adjustments now, you might want it later for different reasons. Also, keep in mind you cannot adjust camber in the rear without aftermarket LCAs. |
| The Following User Says Thank You to PandaSPUR For This Useful Post: | MatthewFRS (05-02-2017) |
| FS: Whiteline Rear Toe Arm/ Whiteline Rear Camber Adjust Kit | Quanye | Brakes, Suspension, Chassis | 7 | 02-07-2016 01:55 PM |
| Lowering - best way to adjust camber? | _frs | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 08-28-2014 04:35 PM |
| Adjust camber/caster from top or bottom? | diss7 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 06-22-2014 04:03 PM |
| The proper way to adjust camber independently? | Cheeseballs | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 12-27-2013 08:03 PM |
