#29 | |
Drives: 2017 BRZ Ltd White
So I turn the system on with the unlabelled fan dial. Then turn off the AC button, turn on, then off the recirculate button, adjust the fan speed, cycle thru the vent options to get it back to top vents only, and voilà. I have manual fan. AWESOME!!! So easy and soooooo obvious. (and yes more sarcasm intended) |
#30 | ||
#31 | |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
The buttons you're thinking of are labeled as "On/Off" or "Power"
RTFM
#32 |
Drives: 17 86
| The Following 4 Users Say Thank You to PetrolioBenzina For This Useful Post: |
#33 | |
Drives: BRZ 2017 Pure Red, MT
I didn't say it was convenient, just how it worked, haha ![]() I'll probably try to get used to the automatic control, instead of trying to fight it... |
#34 |
Drives: 2014 BRZ Limited
You can usually walk both ways through a door marked "out" also. But then sometimes there's no handle on the wrong side! My god, what will you do? WHAT WILL YOU DO?
On the contrary, I would never, ever assume that a button marked "OFF" turns things on. The idea that one would read something and think it means its exact opposite is completely foreign to me. Oh praise Jesus, Buddha and Allah. Our national nightmare is finally over. |
#35 |
Drives: 2014 Scion FR-S Monogram
Wait until you sit in any BMW and try to work with AC in that car...
Normally if a button says OFF it means off only. It'll have on button or something else that turn the device on as a separate function. I think you are confusing on/off button as OFF only buttons Get used to this style off AC operation if you want multi-zone climate control in ANY car, because this is the standard. |
| Swap Aircon HVAC controls from BRZ/GTS to FRS/GT | MudithJ | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 08-04-2016 11:13 AM |
| Subaru BRZ - Dual Zone Climate Temperature - Wrong? | Nourdmrolnmt1 | Issues | Warranty | Recalls / TSB | 21 | 03-22-2015 02:11 PM |
| Tiny amount of engine oil smell passing through aircon? | Mim | Issues | Warranty | Recalls / TSB | 9 | 01-18-2015 01:11 PM |
| AFR's Danger zone!? | Brick | Software Tuning | 20 | 02-24-2014 07:14 PM |
| DRL + "Eyebrow strip" dual operation? | Weeber | BRZ First-Gen (2012+) — General Topics | 3 | 11-26-2013 02:35 PM |
