Old 04-28-2017, 06:17 PM   #1
Rougenite
Drives: Raven FR-S
Clutch Fork Failures?
I keep searching (even google) on the failure rate of the clutch forks and what type of pressure plates were being used at the time.
I just got a new clutch/FW/pressure plate put in...but the shop didnt put in the Velox fork. (May have been partly my fault) I really dont want to take the damn thing in next week to have it put in (and another couple hundred bucks) If I can just forego doing it right now.
Rougenite is offline   Reply With Quote
Old 04-28-2017, 06:31 PM   #2
Trust86
Drives: 2016 Halo FRS
Start/add a poll.
If you decide to sell, I'll buy it.
Trust86 is offline   Reply With Quote
Old 04-28-2017, 07:16 PM   #3
How much heavier is your clutch pedal? Same? A tiny bit more? Double?
I'm still convinced the stock fork is ok unless the TOB starts binding. THAT is much more likely.
Rougenite (04-28-2017), strat61caster (04-28-2017)
Old 04-28-2017, 08:03 PM   #4
Rougenite
Drives: Raven FR-S
http://counterspacegarage.com/act-sb...-frs-gt86.html
still a bother to worry about
Old 04-28-2017, 08:22 PM   #5
johl
johl's Avatar
Drives: toyota 86
If you already have the part just hold onto it until the factory unit fails. Then all you have to do is install the velox shift fork
johl is offline   Reply With Quote
Old 04-28-2017, 08:29 PM   #6
Rougenite
Drives: Raven FR-S
Thats the plan, but I can also add it into my build thread as an FYI for others
Old 04-28-2017, 08:49 PM   #7
While crouching just outside the car, can you still easily push the pedal to the floor with your right hand?
Old 04-28-2017, 09:00 PM   #8
Easy for YOU to do ........ big guy .......
Ultramaroon (04-28-2017)
Old 04-28-2017, 09:03 PM   #9
Rougenite
Drives: Raven FR-S
Well, im a lefty soooo not really haha.
Its like 30-40% more effort to push in than stock now.
Old 04-28-2017, 09:19 PM   #10
I'm big but I'm a hard lefty too. Makes the test that much more valid. I'd say you're fine as long as you don't ever feel any binding or extra stiffness in the pedal.
If it ever starts binding even a little, get in there and clean off the TOB & snout.
Clutch Fork Squeaks fantah Hawaii 28 11-07-2018 01:22 PM
Clutch creaking noise (not the clutch fork one...) treminaor Issues | Warranty | Recalls / TSB 59 10-23-2017 01:53 AM
Clutch Squeaks at the end of travel... clutch fork? treminaor Issues | Warranty | Recalls / TSB 54 12-02-2016 03:53 AM
stiffer clutch= broken Clutch fork KAR Engine, Exhaust, Transmission 1 04-25-2016 05:31 AM
Clutch Fork Broken rick s Issues | Warranty | Recalls / TSB 8 08-27-2015 01:49 PM
