Old 01-26-2017, 09:59 PM   #15
swarb
It's for locating the bolt in slotted struts, which we don't have.
Originally Posted by FatFree View Post
bump? no one has an answer for this?
Old 01-26-2017, 10:11 PM   #16
FatFree
FatFree's Avatar
Drives: 2013 Asphalt FR-S
Thanks. Would be nice to mention in the instructions... what about the torque specs?
FatFree is offline   Reply With Quote
Old 01-26-2017, 10:38 PM   #17
swarb
Old 01-26-2017, 10:49 PM   #18
FatFree
FatFree's Avatar
Originally Posted by swarb View Post
Yes, I did. I'm not one to just blindly ask questions without first searching for the answer. Your first answer was not very clearly verified or responded to by anyone else. Hence my concern with if the rectangular washer was needed. Same goes for the answer to my second question. The 106 ft lbs answer is the third torque spec I've seen for the whiteline camber bolts and again, I didn't see the answer clearly verified by anyone. Why is the correct torque spec different from the two other specs that I received with the product? No need to act rude. Like 'oh SEARCH!! I never would have thought of that myself!!'
Old 01-26-2017, 11:20 PM   #19
swarb
Originally Posted by FRSFirestorm View Post
What Orbital says makes sense.
Being on the nut side would make it an expensive washer. Being on the bolt head side would negate the rotating camber tab. Just my thoughts.
torque specs
Old 01-26-2017, 11:23 PM   #20
FatFree
FatFree's Avatar
You're so helpful. Thanks
Old 01-29-2017, 04:42 PM   #21
Teseo
Drives: frs
Why not let the allignment guy do the job?
Old 01-29-2017, 06:13 PM   #22
FatFree
FatFree's Avatar
I was just installing the bolt myself. Wanted to save a few bucks. Turns out the shop I go to didn't have the correct tool to do the alignment. Something about needing an angled socket. So I gotta wait until they get that tool.
Old 01-30-2017, 01:05 AM   #23
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Noticed you are in Seattle, which shop do you go to?
When I do decide to actually get lowering springs and go for alignment, I'll most likely visit Chase Race since I very much enjoyed my time when I got my tires installed. Doesn't hurt to have more choices though.
The Twins make me smile
Old 02-02-2017, 03:52 AM   #24
FatFree
FatFree's Avatar
Yeah I didn't really shop around. I just go to Les Schwab on Lake City for any suspension or wheel/tire work.
The Following User Says Thank You to FatFree For This Useful Post:
soulreapersteve (02-02-2017)
Old 04-28-2017, 03:15 PM   #25
Impureclient
Drives: 2015 FR-S
Just to make this clear since it was a little confusing seeing all the different torque specs being thrown around. The camber bolt is supposed to be at 113 Nm /83 ft lbs according to the Whiteline instructions and the factory one below is at 155 Nm/114 ft lbs.
At least that is what the directions read that came in the Whiteline set I just ordered a week or so ago and installed.
Adjustable Camber Arms vs. Whiteline Camber Bushings digital_assassin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 70 06-02-2013 06:06 AM
FS: rce yellows & whiteline camber bolt $300 chappys4life Mid-Atlantic 19 05-13-2013 02:31 PM
[SYD] Brand new SPC 81280 16mm camber bolt (Whiteline rebrand these as their own) eckoflyte Australia Classifieds 1 03-31-2013 11:02 PM
