Old 04-21-2017, 08:48 PM   #1863
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I may have missed it... what's your plan for a fuel surge setup?
Old 04-21-2017, 10:24 PM   #1864
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
full to the brim every session until an in-tank solution is released
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
Bramick (04-23-2017), DocWalt (04-21-2017)
Old 04-26-2017, 03:19 PM   #1865
ATL BRZ
ATL BRZ's Avatar
Got busy last weekend. ACT SB8-XTSS clutch and flywheel installed along with IRP Short Shifter. Rear interior stripped. Braum Venom seats and 5 point harnesses installed (not pictured). NA intake, header, catch can pulled off as well as the bumper, crash beam, and oil cooler. Ready for the turbo kit but I still don't have the turbocharger yet.... not sure what the delay is at this point.
GTHachiRoku (04-28-2017), Kris86 (04-26-2017)
Old 04-26-2017, 03:30 PM   #1866
akiranakayama
Drives: 2013 Subaru BRZ Limited (CBS)
Originally Posted by ATL BRZ View Post
Fueling stuffs. Walbro 485 pump kit and ID 1050X injectors to deliver ethanol sufficiently.
Wish there was an internal, fuel-tank fuel-starvation solution (baffled tank) or, otherwise, a nice surge tank. That would be nice.
2016 Scion FR-S
1991 Acura NSX
2012 Mazda Miata (Track)
2019 Triumph Bonneville Bobber
2007 Suzuki SV650 (Track)
akiranakayama is offline   Reply With Quote
The Following User Says Thank You to akiranakayama For This Useful Post:
ATL BRZ (04-26-2017)
Old 04-27-2017, 05:42 PM   #1867
ATL BRZ
ATL BRZ's Avatar
The turbo finally arrived!!
Garrett GTX2860R Gen2
The Following 4 Users Say Thank You to ATL BRZ For This Useful Post:
DocWalt (04-27-2017), D_Thissen (04-30-2017), PR138 (05-01-2017), Teseo (04-27-2017)
Old 04-27-2017, 09:11 PM   #1868
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Has anybody gotten around to putting some hydramat in the tank? or at least a second pump on the passenger side to feed the OEM swirl pot?
Turbo looks awesome! Good call on the ceramic coating. Going to throw a blanket on it too?
The Following User Says Thank You to DocWalt For This Useful Post:
avishenoy1 (04-29-2017)
Old 04-28-2017, 02:30 PM   #1869
ATL BRZ
ATL BRZ's Avatar
Thanks. Probably won't need a blanket since its coated and there will be a hood vent directly above it
The Following User Says Thank You to ATL BRZ For This Useful Post:
DocWalt (05-02-2017)
Old 04-29-2017, 10:41 PM   #1870
avishenoy1
avishenoy1's Avatar
Drives: 2015 FR-S Release Series 1.0
+1 on this question, curious to see how you handle this op. Full throttle left handers are the bane of my existence.
avishenoy1 is offline   Reply With Quote
Old 05-02-2017, 08:51 AM   #1871
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Right, forgot about the hood vents. I only asked because the coating helped my header temps, but wasn't as good as a wrap (which I didn't want to do, even if I was OK voiding the JDL warranty)
Old 05-03-2017, 03:05 PM   #1872
Wacko
Drives: 2016 Scion FR-S
As a developer, i would trade website building time for car parts from JDL :P They really could get a lot of people in the community to work on their site for nothing more than parts.
Love the turbo, am excited to see it!
Wacko is offline   Reply With Quote
Old 05-10-2017, 12:37 AM   #1873
ATL BRZ
ATL BRZ's Avatar
Installed the turbo kit along with the fuel injectors, AOS, and my modified oil cooler kit over the weekend!
Still to-do:
Install Walbro 485 fuel pump kit
Install new over/front pipe thats on the way from JDL. My prototype 1-piece didn't fit well.
Add engine oil and prime turbo
Re-install fuel pump fuse and run the car on the HRI Tuning startup/leakdown map and adjust BOV to allow a smooth idle.
Re-install bumper and drill and tap the crash beam to fit the Velox splitter support rods.
Break in clutch.
Load test and log to finish etuning with James.
dattran86 (06-20-2017), DocWalt (05-10-2017), DustinS (05-10-2017), Teseo (05-10-2017)
Old 05-10-2017, 02:04 AM   #1874
gramicci101
Off Topic
With the oil cooler fittings on the bottom, will there be any issue with air getting trapped in the system, such as during an oil change when everything is drained out?
Old 05-10-2017, 08:54 AM   #1875
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
This setup looks great. I love the color of the coating. Using OEM ducting for the cooling pack, I assume?
Yes. You'd have to remember to do the "flood clear" on every oil change (good practice anyway) or you'd have two problems. Air in the oil system & a much lower oil level than intended once the air finally purges. There's also potential for air to be trapped if you leave the car sit for an extended period of time (a week or so?) and air = no lube. Dry bearings aren't happy bearings.
I'd recommend changing that setup. I'd also rubber mount the oil cooler, not mount it directly to something that's cantilevered way out there that will vibrate up and down.
I'm not trying to be a jerk about it, just concerned for the well being of OP's car and for his well being too, oiling your own tires from a failed oil cooler is VERY bad.
Old 05-10-2017, 09:34 AM   #1876
ATL BRZ
ATL BRZ's Avatar
I could've easily re-used the little mounting feet from Perrin and put the OC on the lower tray in the same spot. I'm told that having the fittings on the bottom actually improves drainage. Also it prevents the OC from getting ripped off along with the tray if I ever have an off that takes my splitter which is mounted to that lower tray. Air in these OC lines after the car rests is inevitable either way I have the core mounted but I don't think it's an issue since the sandwich plate is at the very top of the motor and there is always some air between the oil in the crankcase and the sandwich plate and oil filter normally when the car rests that gets purged out via the PCV once the car is running again and oil flows to bring the pressure up. That's how I understand it, at least. @VeloxEric may be able to elaborate on this since the Full-Race kit and their oil cooler has a similarly mounted core, and he's an engineer with more educated reasoning.
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 03:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 12:46 PM
