Old 04-25-2017, 01:58 AM   #1
MyNave
MyNave's Avatar
Drives: 2013 stock blue
lighter revo crank worth it?
is this http://www.raceseng.com/revo-crank-t...z-2013#answer1 worth it?
and how easy is it to install?
MyNave is offline   Reply With Quote
Old 04-25-2017, 02:12 AM   #2
1. No.
2. Doesn't matter. Refer to first point.
Cole (04-25-2017), humfrz (04-25-2017)
Old 04-25-2017, 02:21 AM   #3
If I were you, I'd pass any aftermarket crank pulley.
There ain't nutten wrong with the one that came with your car.
Cole (04-25-2017), Ultramaroon (04-25-2017)
Old 04-25-2017, 03:01 AM   #4
MyNave
MyNave's Avatar
okay cool. well, i am glad i asked before buying. kinda interested in why it is useless though.
Old 04-25-2017, 05:00 AM   #5
norcalpb
norcalpb's Avatar
Because the heavier the crank pulley the smoother the engine is (to an extent).
When you put on a lightweight crank pulley it makes the engine rev faster in neutral but it makes everything so shakey, lots of nvh etc and there's posts on here that show you make the most power on the stock pulley.
Get this if you want to change the pulley out.
http://www.ft86speedfactory.com/flui...w#.WP8CAYFlCEc
The Following User Says Thank You to norcalpb For This Useful Post:
Somerandom18 (04-25-2017)
Old 04-25-2017, 12:14 PM   #6
Somerandom18
Drives: 2017 manual BRZ
Had a lightweight pulley on for about 300 miles. Then switched to the fluidampr. No regrets.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 04-25-2017, 12:58 PM   #7
And... The second you put the car in gear the transmission and drive train become the limiting factor on how fast the engine turns over not the weight of a pulley. Any effect that a light weight pulley has would be totally lost in the noise of everything else that the engine is spinning once the car is moving.
Old 04-25-2017, 01:07 PM   #8
MyNave
MyNave's Avatar
well thanks for the thorough replies.
Old 04-25-2017, 01:32 PM   #9
Tcoat, that is the most succinct explanation I have heard/read yet.
I'm surprised we haven't heard from the fanbois. Popcorn's gonna go stale.
Old 04-25-2017, 10:19 PM   #10
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Here's the thread you want to start with for lightweight bliss.
I'm just not a fan of raceseng, sure the stuff looks great but it is so expensive. More importantly, the pulley's are the last bit to do, not the first. Unless you just want the bling, in which case you should go for a full set. I am sure they make some sort of difference, but I'm not sure I could tell on this car.
Oh and the installation of our crank pulley's can either be super easy or the worst pain in the ass you have ever had to deal with, depending on how lucky you are getting everything lined up just right.
why? is offline   Reply With Quote
Old 04-26-2017, 01:02 AM   #11
Poodles
Drives: 2015 Series.Blue
Eh, Raceseng makes pretty niche product that are made in the USA, so I don't feel bad paying what I did for my tow-hook license plate mount (plus it's the only one on the market that's as adjustable as it is and doesn't come loose!).
Pulleys are 100% useless bling though unless you run underdrive stuff, but of course that causes other issues.
Also, you left out that an improperly installed harmonic damper isn't just a pain in the ass, but can cause serious damage. Not worth it unless you're going for huge power and NEED a larger damper. Money is best spent elsewhere.
Old 04-26-2017, 09:59 PM   #12
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
And I opened this thread to read about a light weight crankshaft.
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
RJasonKlein (04-27-2017), sam69 (04-26-2017)
Old 04-27-2017, 12:21 AM   #13
You haven't heard about the new lightweight crankshaft that allows rpms up to 12,000, thus increasing horsepower and torque by 40% ........??
Ya gotta keep up ....
what more can i do for a lighter front end? mokinbird87 Tracking / Autocross / HPDE / Drifting 116 02-08-2020 05:06 PM
Second time crank seal leak possible crank walk kiichiro Engine, Exhaust, Transmission 13 09-19-2018 06:57 AM
Anyone know why the 86 is lighter than the brz? Tjs Blunts and Coffee Scion FR-S / Toyota 86 GT86 General Forum 44 09-11-2016 01:49 PM
FS: Raceseng Revo Crank Pully stueck9356 Engine, Exhaust, Bolt-Ons 13 02-01-2015 11:44 AM
Making the BRZ ever lighter Alabang BRZ Cosmetic Modification (Interior/Exterior/Lighting) 10 04-16-2014 09:57 AM
