Old 04-15-2016, 03:58 PM   #43
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Originally Posted by GTHachiRoku View Post
Last weekend I got my track pads on and changed the brake fluid. I have enough for another change between my two half empty bottles! I remembered it being incredibly easy the last time I used the fluid extractor and it was even quicker this time around. I'm surprised more people don't use this method!
Either today or tomorrow I'll be taking off some weight for Sunday
Which fluid extractor/method are you using?
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
Old 04-15-2016, 04:11 PM   #44
GTHachiRoku
Big in Japan
GTHachiRoku's Avatar
Drives: turBRZ
I use a Mityvac fluid extractor. I believe it was only $50 or so off Amazon.
First I extract all the fluid out of the reservoir. Then I fill it with the new fluid to the full mark. Next I go around to each corner and attach the smaller rubber grommet to the bleeder valve. It's a rubber grommet that is used to connect the larger diameter tube to the smaller diameter tube... it just happens to be the perfect size.
Once it's on and I've got suction, I open up the valve and extract until I see the new fluid coming through.
After each corner I fill up the reservoir back to full.
GTHachiRoku is offline   Reply With Quote
The Following User Says Thank You to GTHachiRoku For This Useful Post:
LOLS2K (04-15-2016)
Old 04-15-2016, 04:21 PM   #45
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
@GTHachiRoku Ugh, of course! I'm really torn between buying the MityVac or taking the car in to have the brakes bled. It would actually probably cost me more to take it in. Everything points to buying the MityVac.
Old 04-15-2016, 06:55 PM   #46
GTHachiRoku
Big in Japan
Drives: turBRZ
Yup, and the other solutions I've seen aren't as versatile. You can also use it to change your oil top-side. That's actually what I bought it for in the first place.
I also used it to drain the 20lbs of washer fluid from my reservoir
Old 04-16-2016, 12:19 AM   #47
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Not bad, not bad at all. That's good thinking. May just have to drop 50 bucks on this considering that I bleed my brakes often. I don't think I'll be using it to drain any washer fluid though.
Old 04-27-2016, 09:51 AM   #48
GTHachiRoku
Big in Japan
Drives: turBRZ
I've been slowly selling off some stuff, which has given me a little bit to work with.
I've never been a big fan of the stock tail lights. I saw the Original Runduce car a while back in Japan.
Then recently I saw it in a magazine and really liked the look of the Valenti tail lights on the white car.
I also shaved off the Subaru badge. Maybe I'll shave off the BRZ as well... but still not sure.
Either way... I'm stuck doing little mods like this until I can make the jump to FI...
Old 03-16-2017, 08:58 PM   #49
GTHachiRoku
Big in Japan
Drives: turBRZ
Some new things in the works!
GTX3076 Turbo Kit
Oil Cooler
Catless FP
OP
Who knows what else! Waiting on Radium's fuel solution before going FF.
Old 04-24-2017, 12:54 PM   #50
GTHachiRoku
Big in Japan
Drives: turBRZ
So, I ended up going with a custom turbo kit from a local, well known tuner.
It's a GTX3076R based kit with a water to air intercooler. I also scored an oil cooler and a few other bits and pieces. For now, I've removed the small air inlet tube to the turbo and fitted a Turbo Guard. However, I'm working toward a custom made hard pipe to fit a proper air filter onto.
Dyno graph - I'm still on the stock clutch and stock fueling components. I'll be working toward flex fuel eventually, along with all the supporting mods.
Old 04-24-2017, 01:06 PM   #51
Dialkyl
Drives: Silver 2013 Subaru BRZ
Sick. How do you like driving it with the turbo compared to stock?
Dialkyl is offline   Reply With Quote
Old 04-24-2017, 01:49 PM   #52
GTHachiRoku
Big in Japan
Drives: turBRZ
It's an absolute blast. I honestly can't wait to test it out on track.
There is the typical turbo lag you'd expect. However, while stock I always found myself revving the hell out of it in order to stay above the torque dip. So staying above 3k rpm isn't bad at all.
The sound is really nice too. I've kept the stock catback for now, so it's fairly quiet until the turbo spools/dump tube opens up!
I hope to get some videos posted once it stops raining here.
GT86 OEM Option Pin Stripes (anyone done this to their 86/GT86/FRS/BRZ)??? jbsali Cosmetic Modification (Interior/Exterior/Lighting) 27 07-29-2013 12:10 AM
L3P's Firestorm FR-S L3P47 Member's Car Journals 67 06-02-2013 11:32 PM
FRS-GT86's Firestorm! FRS-GT86 Member's Car Journals 0 02-23-2013 11:37 PM
MEETING 'MR GT86' - Tada San drives GT86 in Scotland (Pistonheads) RadOnc Scion FR-S / Toyota 86 GT86 General Forum 15 11-23-2012 09:42 AM
Firestorm FR-S Available mattyboy311 Mid-Atlantic 1 09-26-2012 11:36 AM
