| Member's Car Journals Car journals by our members. |
Big in Japan
Drives: turBRZ
GT86's Firestorm 86
Greetings everyone
For those of you who know me, I've been somewhat obsessed with cars my whole life. This obsession has led to me owning a total of 14 cars over the last 10 years. Some good, some horrible, others mediocre. In short, I've ended up just about where I started... My car progression... : 2000 Pontiac Grand AM GT 2003 WRX - STI conversion - 500+whp (pre-kids when I could dump 15k into a car build )1981 Datsun 280zx 2005 VW GLI 2006 Subaru Legacy 2013 FR-S 2014 Evo X MR 2015 VW GTI Mk7 - APR stage 2 2015 BRZ Limited Just like with the FR-S, my goal is to improve the braking and handling of the car, but this time I want to add some additional power. I still hope to instruct HPDEs some day soon (It's a matter of bravery at this point ). So, I want a car that can not only be a blast on the track but can also provide a great platform for learning and teaching. Mod List Cosmetic: -Valenti tail lights Aerodynamics: -Velox Motorsports Front Race Splitter Engine/Exhaust/Trans: -Velox Motorsports cam plate -Custom GTX3076R turbo kit - open dump, Tial WG, water to air IC -Tanabe OP & Catless FP -Oil Cooler Suspension/Chassis/Brakes/Weight Reduction -Tein Mono Sport Coilovers -SPC Adjustable rear lower control arms -Project Mu Club Racer Pads and Brake Fluid Wheels & Tires: -17x9 Enkei RPF1 +38 in Gunmetal w/ Hankook RS3 v2's in 245/40/17 Next Up Mods -Most of Velox Motorsports' catalog for aero -Some sort of seats - so I don't have to hunch with a helmet ![]() 2017 Track Day Schedule Death of Winter Atlanta Motorsports Park with JZilla Atlanta Motorsports Park with JustTrackit Others - TBD My old FR-S
Big in Japan
Drives: turBRZ
Sadly these will have to wait till tomorrow.
Went ahead and set up the adjusents according to the Tein specifications. I guess well see how they are once installed.
Big in Japan
Drives: turBRZ
Adjusted a bit further and everything is on spot with Tein's recommended specs.
This should look and more importantly feel great once the 57Xtremes and RE11A's are mounted. Front ![]() Back ![]() Won't be messing with camber until alignment and new wheels mounted. ![]()
Big in Japan
Drives: turBRZ
Items incoming!
GramLight 57Xtreme Semigloss Black 17x9 - ordered Bridgestone RE11A tires 245/40/17 - ordered Tein StreetFlex Coilovers with tops - ordered Last edited by GTHachiRoku; 04-05-2014 at 03:47 PM. |
Big in Japan
Drives: turBRZ
After about three hours of tinkering ... Out with the old and in with the new.
![]() ![]() There were some frustrating moments and some tips I'd like to share... When I'm more awake lol. |
Big in Japan
Drives: turBRZ
Thanks @GrimmSpeed and @DarrenDriven for the excellent write ups.
Between the two of your guides I was covered! Also a big thanks to Jacky at @vividracing for the great sales & support. I had great experiences back in 2003 with them when building my WRX and it looks like they're still doing a great job. The new wheels and tires should look great now! Some notes & tips on my install: If you're limited on jack stands or don't have a flat area to work, lifting just the front works great for removal and install. As noted in the GS DIY, in order to reattach the end links in the front you must have undone both sides. You don't have to remove the ABS cable from it's clip. Both clips will pop out of the strut fairly easily. Just be gentle. Rear is harder than it looks. I had to remove the rear hub bolts as noted in DarrenDriven's guide as the strut wouldn't budge otherwise. It indeed takes a lot of strength to push the LCA down to fit the strut. Using the little scissor jack to reposition the LCA as well as the rear hub helps! Last edited by GTHachiRoku; 04-09-2014 at 09:01 AM. |
Drives: 2006 S2000
Too late now but its easier to install the bolts into the lca starting with the hub side and working inward to the subframe mount. You have more leverage to push the inside end up and the bolt through the subframe and lca. I did it without any assistance from a jack on my sti when I installed my cusco lcas on my sti which shares the same rear suspension setup.
Big in Japan
Drives: turBRZ
Yeah, I accidentally figured that out on the 2nd rear install.
I still had to man handle the crap out of the hub to get it in place. Will be great to know when I put on the LCA's eventually. Thanks! |
Big in Japan
Drives: turBRZ
Some photos today
#10 |
Big in Japan
Drives: turBRZ
Look what showed up !
![]() My cat approves! |
#11 |
Drives: 2014 SWP BRZ
#12 |
86-er
Drives: BRZ tS
Cool were going to be twins. Same wheels I got. Its going to look beautiful
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
#13 |
Big in Japan
Drives: turBRZ
Yours does look great! Can't wait to get mine on. Will be next weekend probably.
#14 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
Can't wait to see the new shoes! Your car is going to be a completely different animal on track next month. You're gonna love it!
| GT86 OEM Option Pin Stripes (anyone done this to their 86/GT86/FRS/BRZ)??? | jbsali | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 07-28-2013 11:10 PM |
| L3P's Firestorm FR-S | L3P47 | Member's Car Journals | 67 | 06-02-2013 10:32 PM |
| FRS-GT86's Firestorm! | FRS-GT86 | Member's Car Journals | 0 | 02-23-2013 10:37 PM |
| MEETING 'MR GT86' - Tada San drives GT86 in Scotland (Pistonheads) | RadOnc | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 11-23-2012 08:42 AM |
| Firestorm FR-S Available | mattyboy311 | Mid-Atlantic | 1 | 09-26-2012 10:36 AM |
