Old 04-24-2017, 03:07 AM   #1
Armin93
Drives: Toyota 86 GTS
Cold starts
My cold starts sound like this (
) its annoying
How do i fix it ?
Setup: greddy sp elite axle back
Uel psr headers and overpipe
Stock front pipe and mid pipe and tuned with brzedit
I have purchased a dual resonated hks front pipe but havent put it on the car yet
Armin93 is offline   Reply With Quote
Old 04-24-2017, 03:38 AM   #2
steve99
Drives: FT86
) its annoying
How do i fix it ?
Easy, to. Tune out cold starts
Maf offset after start
Post start ignition timing
Reduce post strt ilde speeds
Disable post start ignition cel
humfrz (04-24-2017)
Old 04-24-2017, 05:12 AM   #3
steve99
Drives: FT86
Duel resonated front pipe will likely be louder than stock front pipe unfortunatly
Trust86 (04-24-2017)
Old 04-24-2017, 05:16 AM   #4
Armin93
I dont really care if gets louder
I just want it to have a nicer tone to it
Like no rasp or very little
Old 04-24-2017, 01:40 PM   #5
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Tune it out!
Follow the same instructions that steve99 posted -- There's more info in this thread, which is what I used to tune mine out.
Here's the difference it makes on my car...
----- Before -----
[ame="https://www.youtube.com/watch?v=sbrWfXa_qmQ"]Scion FR-S Borla UEL / FT86 SpeedFactory V1 Cold Start - YouTube[/ame]
----- After -----
[ame="https://www.youtube.com/watch?v=8rrfXthK_dc"]Scion FR-S Cold Start "Quiet" Tune - YouTube[/ame]
dhuang is offline   Reply With Quote
The Following User Says Thank You to dhuang For This Useful Post:
Sportsguy83 (10-15-2017)
Old 04-24-2017, 01:52 PM   #6
D_Thissen
D_Thissen's Avatar
The reason these cars have loud cold starts is because they retard timing (among other things) after start to heat up the cats quickly. When you have a catless header, most tunes don't change the post start timing which is what causes the rasp. As @steve99 said, you can tune out most of the bark.
My car, for example, has a Borla UEL, stock op/fp, Invidia midpipe and a Vibrant muffler.
[ame="https://www.youtube.com/watch?v=7huYEHd37YE"]FRS Coldstart - YouTube[/ame]
Old 04-24-2017, 01:53 PM   #7
Armin93
My tuner told me he tried to eliminate the loud cold start as much as he could
Should i tell him the problem? Or do i need a complete retune
Old 04-24-2017, 02:22 PM   #8
Get the new front pipe installed and then see what you think. Not much sense worrying about the current set up just to add a piece later.
Old 04-24-2017, 06:54 PM   #9
steve99
Drives: FT86
Get tuner to make these changes and reflash id even go to max base idle speed of 1200 instead of 1400. If you dont alter the Maf offset after start tables car will continue to idle fast at startup. These changes wont effect rest of tune ust startup, but you would ned to reflash
tony-brz (04-24-2017)
Old 04-24-2017, 09:26 PM   #10
Armin93
If i put the new fromtpipe on the car will have no cats thats what i'm worried about
Not sure if many people are running completely catless
Old 04-24-2017, 09:44 PM   #11
Loads and loads and loads of them are.
Just saying there is no point trying to tune out a sound and then change the exhaust again. Finish the exhaust. See how it sounds. Then work on tuning out the cold start noise.
e_lunatic (04-25-2017)
Old 04-24-2017, 10:19 PM   #12
I reckon any worries would be complying with any local vehicle emission standards.
The car don't care .....
Old 04-24-2017, 11:35 PM   #13
Trust86
Drives: 2016 Halo FRS
The hks dual resonated is going to be louder than OEM. If you want a catless front pipe, and for it not to be loud, should have went with the fujitsubo dual resonated front pipe.
Trust86 is offline   Reply With Quote
Old 04-25-2017, 09:40 AM   #14
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Heads up: Any after-market front pipe will be louder and introduce more rasp than stock.
Also: If you run catless your cold starts with be even more obnoxious. The cold-start reduction tuning does help significantly though.
ajcarson11 is offline   Reply With Quote
Do e85 cold starts damage engine? jaorocks1 Engine, Exhaust, Transmission 20 12-02-2015 06:12 AM
Random tip - cold starts Dammod AFRICA 34 09-22-2015 02:38 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 06:05 PM
Cold morning starts coldy CANADA 43 04-23-2013 03:30 PM
Issue: Cold starts jesseps CANADA 7 11-24-2012 12:26 PM
