Drives: Toyota 86 GTS
Cold starts
My cold starts sound like this (
) its annoying How do i fix it ? Setup: greddy sp elite axle back Uel psr headers and overpipe Stock front pipe and mid pipe and tuned with brzedit I have purchased a dual resonated hks front pipe but havent put it on the car yet Sent from my iPhone using Tapatalk |
#2 | |
Drives: FT86
Easy, to. Tune out cold starts Maf offset after start Post start ignition timing Reduce post strt ilde speeds Disable post start ignition cel |
#3 |
Drives: FT86
Duel resonated front pipe will likely be louder than stock front pipe unfortunatly
#4 |
I dont really care if gets louder
I just want it to have a nicer tone to it Like no rasp or very little Sent from my iPhone using Tapatalk |
#5 |
Cannonball Record Guy
Drives: Series.Yellow, 4C, Fit
Tune it out!
Follow the same instructions that steve99 posted -- There's more info in this thread, which is what I used to tune mine out. Here's the difference it makes on my car... ----- Before ----- [ame="https://www.youtube.com/watch?v=sbrWfXa_qmQ"]Scion FR-S Borla UEL / FT86 SpeedFactory V1 Cold Start - YouTube[/ame] ----- After ----- [ame="https://www.youtube.com/watch?v=8rrfXthK_dc"]Scion FR-S Cold Start "Quiet" Tune - YouTube[/ame] |
#6 |
The reason these cars have loud cold starts is because they retard timing (among other things) after start to heat up the cats quickly. When you have a catless header, most tunes don't change the post start timing which is what causes the rasp. As @steve99 said, you can tune out most of the bark.
My car, for example, has a Borla UEL, stock op/fp, Invidia midpipe and a Vibrant muffler. [ame="https://www.youtube.com/watch?v=7huYEHd37YE"]FRS Coldstart - YouTube[/ame]
#7 |
My tuner told me he tried to eliminate the loud cold start as much as he could
Should i tell him the problem? Or do i need a complete retune Sent from my iPhone using Tapatalk |
#8 |
Get the new front pipe installed and then see what you think. Not much sense worrying about the current set up just to add a piece later.
#9 | |
Drives: FT86
#10 | |
If i put the new fromtpipe on the car will have no cats thats what i'm worried about Not sure if many people are running completely catless Sent from my iPhone using Tapatalk |
#11 | |
Just saying there is no point trying to tune out a sound and then change the exhaust again. Finish the exhaust. See how it sounds. Then work on tuning out the cold start noise.
#12 | |
The car don't care ..... ![]() humfrz |
#13 |
Drives: 2016 Halo FRS
The hks dual resonated is going to be louder than OEM. If you want a catless front pipe, and for it not to be loud, should have went with the fujitsubo dual resonated front pipe.
#14 |
Drives: 2013 Subaru BRZ Limited (Black)
Heads up: Any after-market front pipe will be louder and introduce more rasp than stock.
Also: If you run catless your cold starts with be even more obnoxious. The cold-start reduction tuning does help significantly though. |
| Do e85 cold starts damage engine? | jaorocks1 | Engine, Exhaust, Transmission | 20 | 12-02-2015 05:12 AM |
| Random tip - cold starts | Dammod | AFRICA | 34 | 09-22-2015 01:38 AM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
| Cold morning starts | coldy | CANADA | 43 | 04-23-2013 02:30 PM |
| Issue: Cold starts | jesseps | CANADA | 7 | 11-24-2012 11:26 AM |
