Old 04-17-2017, 08:34 PM   #1
vincelive123
Drives: Scion FR-S
Slave cylinder Help
Hey guys, I'm having squeaky noise from my slave cylinder every time I step on the clutch. Sounds like a dry hinge door opening, anyways.... I rolled down the rubber boot and sprayed it with some white lithium grease and it was gone!
After about 4 days it came back today -____-.
Is there any better solution for this instead of spraying it every week?
Can I take this to the dealer and have them replace it? I'm on 45k miles. 2013
Please help.
vincelive123 is offline   Reply With Quote
Old 04-21-2017, 10:05 PM   #2
Maybe you didn't hit it square on the socket. Another shot may do it .....??
Any thoughts there @Ultramaroon ....??
Old 04-21-2017, 11:24 PM   #3
It's not the slave cylinder, it's the clutch fork hinge.
The sound went away for a while because you jiggled and moved it outside its normal throw. Moved a little bit of shit around on the pivot so it quit squeaking for a bit.
The grease you sprayed into the slave cyl won't hurt anything but didn't do anything either.
http://www.ft86club.com/forums/showthread.php?t=117266
http://www.ft86club.com/forums/showthread.php?t=115631
http://www.ft86club.com/forums/showthread.php?t=56882
humfrz (04-22-2017), Teseo (05-09-2017)
Old 04-23-2017, 06:31 PM   #4
@vincelive123, I got your pm but you have this thread. Did you read all the threads I linked?
Old 04-23-2017, 08:45 PM   #5
stevesnj
stevesnj's Avatar
Maybe your issue is covered by the recent TSB?
http://www.ft86club.com/forums/showthread.php?t=117440
My 2016 Build thread
Old 04-23-2017, 09:32 PM   #6
It's not his TOB. It's the pivot. They'll ignore that because it's just an annoyance. It won't leave you stranded.
Teseo (05-09-2017)
Old 04-24-2017, 07:46 PM   #7
MrDinkleman
Drives: 2016 Oceanic, "base" model
Just playing Devil's advocate here but, can't it be argued that metal-on-metal rubbing of the pivot in the socket will eventually cause the arm to fail, leaving you stranded? I have that squeak but have been too lazy to do anything about except wonder if the arm is going fail sooner rather than later...
MrDinkleman is offline   Reply With Quote
Old 04-24-2017, 10:01 PM   #8
It could but it would take many more years of cycles for it to fail in that particular way.
Of more immediate concern is breakdown of the lubricant between the TOB and the transmisson front cover. The TOB starts to bind on the guide making it possible to destroy the fork simply by stepping on the clutch. Be very careful if you feel the slightest bit of tightness anywhere in the throw of the pedal. I took mine apart and cleaned it for that very reason. I'll drop my transmission to inspect it again this summer but I don't know what the long term answer is.
Old 05-02-2017, 11:01 AM   #9
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Mine has made that noise for 3 years now.
Old 05-02-2017, 11:42 AM   #10
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
I took out my clutch pedal spring adjusted the height of the pedal to be a little lower than the brake pedal, and cracked open the clutch slave screw twice to try to gravity bleed it (this may have been a mistake).
I have since noticed that the pedal has a slight squeak to it and also there's more feel through the pedal but it's not necessarily a great feeling. When I push the pedal down, I can feel the clutch disengaging but it's kind of like a crunchy feel to it. Most of the pedal range is smooth but once I actually get to the engage/disengage point it has much more texture. It's kinda nice because it's more communicative but I'm also concerned that something's wrong. Other than those things, nothing has changed and the clutch performs fine. No TOB noise that I can detect.
Thoughts?
ApexEight is offline   Reply With Quote
Old 05-02-2017, 11:58 AM   #11
Thoughts?
There should be no crunchiness. That's the TOB binding on the guide. Needs to be cleaned up and possibly replaced.
Old 05-09-2017, 05:29 AM   #12
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
Mine happened for couple months after winter. XD
FR-Sky is offline   Reply With Quote
Old 05-09-2017, 07:08 AM   #13
ApexEight
I've read that you can take a cover off the transmission and shoot the TOB with some grease. Do you think this stuff would work? http://m.homedepot.com/p/WD-40-SPECI...0059/204960991
And where is the cover on the transmission?
Old 05-09-2017, 01:03 PM   #14
It won't do anything. If it's the TOB, only replacement will help. If it's the fork pivot, then any temporary elimination of the squeak/creak will have been because the fork was jostled around a bit.
Click the readme link on my sig. Someone has generously hosted all the service manuals.
BNIB Subaru OEM 3/4" Clutch Slave Cylinder e1_griego Transmission and Driveline 4 11-12-2016 09:16 PM
Slave Cylinder Upgrade for Heavy Clutches? Spinning Sushi Engine, Exhaust, Transmission 17 08-10-2016 05:21 PM
FS: OEM Clutch Slave Master Cylinder MicheleAbbate Transmission and Driveline 3 05-09-2016 04:48 PM
Clutch Slave Cylinder KAR Southern California 4 08-08-2015 09:25 PM
OEM Clutch Slave Cylinder $20 shipped SlowCone Transmission and Driveline 0 04-25-2015 05:07 PM
