#29 | |
"DGM BRZ"
Drives: 2016 BRZ Limited
I saw someone switched their axle nuts from left to right, I might try that before ordering the part online idk. I could also try re-torquing my spacers.
#30 | |
Fingers crossed
#31 |
"DGM BRZ"
I just re-torqued the spacers and wheels, no luck there. Also torqued the axle nuts to 150lb even though it probably won't move because of the notch. Sound is still there. Guess I'll order some and replace those myself.
| The Following User Says Thank You to treminaor For This Useful Post: | sato (04-21-2017) |
#32 |
Gotta lift the material where it's peened really well or you'll fuck up the threads on your spindle. I did it when I was younger and less patient.
#33 |
"DGM BRZ"
You're talking about getting them off to replace them, right?
#34 |
Yes but once you lift the tab enough you might choose instead to turn it clockwise a little.
#35 | |
"DGM BRZ"
So just turn them first to see if that solves the problem?
#36 |
That's what I'm thinking. That little crimp is amazingly effective. There's no way it would've allowed you to torque the nut any higher.
I know it's a single-use item but it's reasonable to crank on it just a little and re-crimp (peen... whatever the correct term)
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | strat61caster (04-23-2017), treminaor (04-21-2017) |
#37 | |
"DGM BRZ"
#38 | |
It is better to use a new one but its ok to add extra torque to the old one if that's all you're doing.
#39 | |
"DGM BRZ"
#40 | |
Like I warned earlier, don't force it or you will thoroughly fuck up the threads on the spindle. ![]() Crimp it back down and have the dealer replace the nut. I think the important take-away here is seeing why that nut is a single-use item. Can't lift and crimp the same spot repeatedly.
#41 |
Hey, check out this clip. Sound familiar? That thread is interesting, especially after @strat61caster linked the old thread in the STI forum.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | strat61caster (04-23-2017), treminaor (04-22-2017) |
#42 | |
"DGM BRZ"
| The Following User Says Thank You to treminaor For This Useful Post: | Ultramaroon (04-22-2017) |
| Clutch Fork Squeaks | fantah | Hawaii | 28 | 11-07-2018 01:22 PM |
| Clutch Squeaks at the end of travel... clutch fork? | treminaor | Issues | Warranty | Recalls / TSB | 54 | 12-02-2016 03:53 AM |
| stiffer clutch= broken Clutch fork | KAR | Engine, Exhaust, Transmission | 1 | 04-25-2016 05:31 AM |
| Clutch Fork Broken | rick s | Issues | Warranty | Recalls / TSB | 8 | 08-27-2015 01:49 PM |
| Clutch clicking/creaking | Bg8780 | Issues | Warranty | Recalls / TSB | 4 | 03-24-2015 11:27 PM |
