Old 04-18-2017, 11:53 PM   #29
PNW-BRZ
PNW-BRZ's Avatar
Drives: 2015 Limited
I was running Stage 1 with an OFT Tune. Switched over to a Gruppe S UEL header and ECU Tech Tune (on Dyno) and it was a HUGE difference (currently 190 HP at the wheels on 92 Octane) and the Torque dip is drastically reduced. The rest of the exhaust remained stock. It's really pretty quiet (unless I'm just starting up or I jump on it) Wished I would have done it sooner it's really night and day difference.
PNW-BRZ is offline   Reply With Quote
The Following User Says Thank You to PNW-BRZ For This Useful Post:
allowe (04-21-2017)
Old 04-19-2017, 04:24 PM   #30
allowe
allowe's Avatar
Anyone know the differences between ofh and ofh2? I just got the ofh header.
allowe is offline   Reply With Quote
Old 04-19-2017, 06:03 PM   #31
Fred1
Fred1's Avatar
Drives: Scion Frs 2014
Originally Posted by dobbrz View Post
can't you use chevron 94?
Sadly they are no such Chevron close by. Anyway I thinks their not much WHP difference between oft stage 2 91 and 93.
Fred1 is offline   Reply With Quote
The Following User Says Thank You to Fred1 For This Useful Post:
allowe (04-21-2017)
Old 04-19-2017, 06:08 PM   #32
timmydatooth
Drives: Scion Frs
getting my tomei UEL header installed tuesday! super excited! question do I have to do a tune right after I install them? or am I safe to drive around on the stage 1 tune for a little while?
timmydatooth is offline   Reply With Quote
The Following User Says Thank You to timmydatooth For This Useful Post:
allowe (04-21-2017)
Old 04-19-2017, 06:15 PM   #33
allowe
allowe's Avatar
Does anyone know what to tune to make cold start less loud ?
Old 04-19-2017, 07:15 PM   #34
invaliduser
Drives: 2017 86
Search Software forum.
Sent from my Pixel XL using Tapatalk
invaliduser is offline   Reply With Quote
The Following User Says Thank You to invaliduser For This Useful Post:
allowe (04-21-2017)
Old 04-20-2017, 03:03 AM   #35
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by allowe View Post
This question has probably been asked many times but I'd like your opinion on it.
I have an mxp exhaust, injen intake and an oft stage 1 91 oct tune (we don't have 93 where I live). I'm about to buy an OFH off someone but I'm scared about the loudness.
What I'm mostly concerned about is, does it really make a difference in the torque dip?/ does it make a noticeable difference with the stage 2 uel tune combined? I've heard that the difference is so small you won't even notice anything. Is this true? I'd love to hear your opinions.
Also, would an EL hks be just as loud?
All non-stock, catless headers will increase how loud the car is. With a stock exhaust it is still quiet at idle and cruise but noticeably louder when accelerating or on cold start. I don't know where your catback sits on the loudness scale but the Invidia Q300, Perrin 2.5" resonated and the new CSG MXP catback are supposedly not too loud with a header installed.
There is a whole thread on it. Nothing significant changed I believe.
You won't damage anything by not running the stage 2 UEL tune but the car will be MUCH nicer to drive with the stage 2 tune.
I don't believe there is an OTS tune. You will most likely have to read the thread and modify your existing tune.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
allowe (04-21-2017)
Old 04-20-2017, 05:22 AM   #36
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
If it's catted you're good to go (cat in header that is- the secondary cat does not trip any CEL if removed). If it's catless however, Stage 1 tunes do not disable the P0420 CEL and your car will trip the CEL and go into low power mode and disable the cruise control regularly.
Stage 2 tune does disable the P0420
guybo is offline   Reply With Quote
The Following 2 Users Say Thank You to guybo For This Useful Post:
allowe (04-21-2017), timmydatooth (04-20-2017)
Old 04-20-2017, 11:18 AM   #37
allowe
allowe's Avatar
I know this is a bit off topic but while I'm trying to install my header I saw this
There are no signs of dripping on the skid plate..
Old 04-20-2017, 12:02 PM   #38
Chronology
Drives: 13' Satin White Pearl BRZ
Upgraded headers with a tune is better money spent then the intake you put in. UEL will give you that "subi" sound, EL will give you a bit more peak HP.
Most NA guys will go I(filter replacement)/H/E + tune, slap some E85 and your around 50+ hp. without stickers!
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
Chronology is offline   Reply With Quote
The Following User Says Thank You to Chronology For This Useful Post:
allowe (04-21-2017)
Old 04-20-2017, 12:09 PM   #39
allowe
allowe's Avatar
Do I need new bolts for op to header? Those bolts don't have an end part to them
Old 04-20-2017, 12:16 PM   #40
Chronology
I had to drill out the bolts between the over pipe and mid pipe, then realized I was going to replace all of it.
I would grab some extra bolts, I needed 4 I think.
allowe (04-21-2017)
Old 04-20-2017, 01:12 PM   #41
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
I haven't heard crickets since I started filling at shell
And they have the auto full thing so I don't have to hold the pump
Wait are you telling me that every gas station in canada doesn't have those? I have never once pumped gas here in Detroit without using one.
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
The Following User Says Thank You to Detroiter For This Useful Post:
allowe (04-21-2017)
Old 04-20-2017, 01:12 PM   #42
allowe
allowe's Avatar
Crap I don't want to replace the op :/. Where did you buy your bolts and what size were they if u don't mind me asking
Tune + Headers +e85 Worth it? or wait for FI? brzfl Engine, Exhaust, Transmission 39 08-29-2016 08:55 AM
WTT: Tomei uel headers for EL headers 86Tony Canada Classifieds 6 07-27-2015 09:42 PM
FI worth it? Gt86_nick Forced Induction 62 01-28-2014 12:55 AM
Injen SES Headers/ Agency Power headers Choong86 Engine, Exhaust, Transmission 10 12-27-2013 09:51 PM
Is the FR-S worth getting? DIM Scion FR-S / Toyota 86 GT86 General Forum 60 10-28-2012 11:43 PM
