Old 04-18-2017, 08:48 PM   #16339
Originally Posted by Ojoshcaal View Post
thanks, its just some red pin striping i found at an automotive store
It worked well. Visible but still subtle. It stick to the plastic OK?
Old 04-18-2017, 09:06 PM   #16340
dnieves
Drives: FR-S 10 Series
Originally Posted by wulfstan View Post
DIY with pics? Part numbers?
It's so easy it wasn't even worth documenting or even putting in the DIY section.
Here's the rundown:
Order Subaru part #H701SCA000 RED or H701SCA100 BLUE
Plug: Order them from Reeves Subaru Parts Online $132.56 free shipping over $100. The best you'll do is $4 cheaper but everybody charges about $14 extra for shipping.
Kit consists of two LED small oval pods (with double sided tape) that connect to a jumper, six foam adhesive squares, four small screws to screw down the pods to the mounting points under the dashboard.
You're supposed to disconnect the battery to prevent short circuits
1. Remove trim piece around head unit (I used a flat head with the tip covered in masking tape to prevent scratching.
2. Remove head unit -it's held in place by four 10mm bolts the top two are easy to reach but the bottom two are recessed about an inch (they can fall down).
3. Pull out head unit carefully (not much slack) and 5-6 (depending if you have navi) connectors must be squeezed and pulled out.
4. Locate wiring harness that goes to the alarm clock/hazard light button assembly then disconnect it.
5. Plug in the jumper between the alarm clock/hazard light button panel and the harness from step 4 and route the two long wires down behind the console on either side.
6. Wire tie the cables behind the radio, wrap the foam adhesive around the connection between the wiring hardness and light kit's jumper (you don't want that rattling around).
7. Plug the lights' connectors to the cables and wrap them with adhesive too.
8. Peel the tape from the pods and stick them under the bottom edge of the dashboard (clean the area with alcohol first!) and use the included screws to permanently secure them.
9. Tidy up your slack wire and wire tires, reconnect your headunit's connections (remember not much slack back there -small hands would be helpful and keep in mind your metal headunit can scratch the crap out of your plastic interior).
10. Put headunit back in, bolt it down, reconnect the car battery then turn on headlights. If all is well they will light up and you can put the headunit trim back on.
If not is all well make sure your connections are tight, headlights turned on, fuses ok, and battery is reconnected. All connectors only fit in one direction and they're different sizes <-this is so easy I can't picture anybody screwing it up.
Here are the official directions:
http://www.ft86speedfactory.com/inst...H701SCA100.pdf
If you need pics of the placement of the LEDs tell me (thankfully the instructions included measurements because the drawings were so-so).
dnieves is offline   Reply With Quote
The Following User Says Thank You to dnieves For This Useful Post:
wulfstan (04-19-2017)
Old 04-18-2017, 09:42 PM   #16341
Ojoshcaal
soul of Æ86
Drives: 16 Halo FR-S/95 Black EJ2 Coupe
thanks thats what i was going for, yea its staying on fine its been raining pretty hard where i live lately, ive been driving around and its still there
Ojoshcaal is offline   Reply With Quote
The Following User Says Thank You to Ojoshcaal For This Useful Post:
Tcoat (04-18-2017)
Old 04-19-2017, 12:08 AM   #16342
zeal86
zeal86's Avatar
Drives:
Finally got my Beatrush gold painted Essex harness bar back today... the color match is pretty spot on.
I wanted to incorporate some of my engine bay color theme into my interior... I think this will do the trick. I also had the side plates that hold the Bride seats to the rails painted Beatrush gold.
Hope to have installed pics soon...
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram @zeal.eightsix
zeal86 is offline   Reply With Quote
The Following 2 Users Say Thank You to zeal86 For This Useful Post:
Kestrel (04-19-2017), OrangeGuitar (04-19-2017)
Old 04-19-2017, 11:22 AM   #16343
Swagopopotamus
Swagopopotamus's Avatar
Drives: Not an FRS, but same initials.
Carefully configured my Canadian cargo cover to catch carelessly cast carry-on without causing contamination to my carpet.
Swagopopotamus is offline   Reply With Quote
The Following 3 Users Say Thank You to Swagopopotamus For This Useful Post:
Kaotic Lazagna (04-20-2017), OrangeGuitar (04-19-2017), trvth (04-21-2017)
Old 04-19-2017, 12:32 PM   #16344
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Originally Posted by NyC Zn6 View Post
Do you have a link to where you purchased this from?
WRONG SIR. This request MUST be in the form of an alliteration.
Fix and ask again please
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
Swagopopotamus (04-19-2017)
Old 04-19-2017, 12:42 PM   #16345
Swagopopotamus
@NyC Zn6 Tracked it down in this thread.
The Following 2 Users Say Thank You to Swagopopotamus For This Useful Post:
Captain_Awesome_Pants (04-20-2017), NyC Zn6 (04-19-2017)
Old 04-19-2017, 12:42 PM   #16346
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Originally Posted by Swagopopotamus View Post
@NyC Zn6 Tracked it down after seeing this thread.
Thank you
Old 04-19-2017, 12:45 PM   #16347
NyC Zn6
NyC Zn6's Avatar
lol hey listen it is almost 4/20 and i am pregaming
Old 04-19-2017, 02:27 PM   #16348
Kestrel
Kestrel's Avatar
Drives: 2015 Ultramarine FR-S AT
I need this.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Kestrel is offline   Reply With Quote
The Following 2 Users Say Thank You to Kestrel For This Useful Post:
Kaotic Lazagna (04-20-2017), stevesnj (04-19-2017)
Old 04-19-2017, 08:25 PM   #16349
stevesnj
stevesnj's Avatar
Originally Posted by Kestrel View Post
I need this.
+1
My 2016 Build thread
Old 04-20-2017, 02:30 AM   #16350
Kaotic Lazagna
Drives: GR Corolla
Cleaned and conditioned the leather parts in my FR-S since I haven't done those in a long time.
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
Overdrive (04-20-2017)
Old 04-20-2017, 03:54 PM   #16351
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Didn't back in when parking and now I'm the odd one out.
dhuang is offline   Reply With Quote
Old 04-20-2017, 04:03 PM   #16352
StraightOuttaCanadaEh
Wes
lol I did that at the last car meet. Then turned it around
