Old 04-18-2017, 07:01 PM   #15
DarkSunrise
DarkSunrise's Avatar
Also keep in mind not every header will give you the same results. Depending on design, they will add or subtract power in different parts of the powerband. If you're primarily concerned about the torque dip, make sure you look over people's dyno results and pick a header that fits what you're looking for. But to answer your question, yes the right header does make a noticeable difference.
2022 BRZ Build
2013 FR-S Build
Old 04-18-2017, 07:04 PM   #16
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by allowe View Post
Shell v power has no ethanol
FYI, that's not always the case. In many areas ethanol is added during winter months.
The Following User Says Thank You to Pat For This Useful Post:
allowe (04-18-2017)
Old 04-18-2017, 07:09 PM   #17
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by Fred1 View Post
Petro Canada 94 octane is making soo much cricket sound under the hood. The high pressure fuel pompe do not like it.
I use Shell V-power too and no such noise as Petro-Canada 94.
I will put up with that for the added knock resistance. It's easy to shut the crickets up, as well.
Personal preference.
Old 04-18-2017, 07:15 PM   #18
allowe
allowe's Avatar
Are headers really worth it?
I haven't heard crickets since I started filling at shell
And they have the auto full thing so I don't have to hold the pump
allowe is offline   Reply With Quote
Old 04-18-2017, 08:09 PM   #19
allowe
allowe's Avatar
That's good to know actually thank you. I'll do more research on that later.
Old 04-18-2017, 08:18 PM   #20
Amputechture
Drives: 2014 BRZ
A header is the only piece of 'naturally aspirated hardware' that actually does make a difference on this car.
Amputechture is offline   Reply With Quote
Old 04-18-2017, 09:20 PM   #21
AREN
AREN's Avatar
Drives: Beige Corolla
The UEL Boxer rumble makes it worth it for me. RUMBLE!
AREN is offline   Reply With Quote
The Following User Says Thank You to AREN For This Useful Post:
e_lunatic (04-19-2017)
Old 04-18-2017, 09:22 PM   #22
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
[ame="https://www.youtube.com/watch?v=DXRaboSo70A"]It's gonna be HUUUUUUUUGE! - YouTube[/ame]
Yes, with a tune IT'S HUGE. IMHO gutting and tuning is the single best HP/$ thing you can do. You can get an aftermarket header which can make slightly more power, but many have issues down the road with cracking at the welds and the extra heat can damage coil packs unless you wrap or coat. Gutting the OEM header can retain the OEM heat shielding so there is no extra heat (maybe there's even less heat without the cat?)
either way, if you get a catless header or gut, GET A TUNE to go with it. As for noise- there was a big increase in noise when I gutted the secondary cat. The increase in noise when I gutted the cat in the header was minimal. But yes, it will be noisier either way. But you also get extra burbling, popping and over run sounds too which are nice. and extra stink, which is not nice.
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
allowe (04-18-2017)
Old 04-18-2017, 10:31 PM   #23
Ya that 2 or 3 minutes of holding a pump is a real bitch!
allowe (04-21-2017)
Old 04-18-2017, 10:56 PM   #24
Lantana frs
Drives: 13 frs red
Flattening the torque curve makes a tremendous difference on the street. The gains above 5 grand are a bonus imo.
Lantana frs is offline   Reply With Quote
The Following User Says Thank You to Lantana frs For This Useful Post:
allowe (04-21-2017)
Old 04-18-2017, 10:58 PM   #25
allowe
allowe's Avatar
When it's like -20, it's a blessing.
Old 04-18-2017, 11:14 PM   #26
Meh. I have gloves.
allowe (04-21-2017)
Old 04-18-2017, 11:17 PM   #27
tCsonfrs
Drives: 10 Series FR-S #207
Originally Posted by Summerwolf View Post
.... yes. Ffs read a header thread.
tCsonfrs is offline   Reply With Quote
The Following User Says Thank You to tCsonfrs For This Useful Post:
allowe (04-21-2017)
Old 04-18-2017, 11:18 PM   #28
dobbrz
Drives: RB v1 FRS
can't you use chevron 94?
PROPΔGΔNDΔ
DRIVEN TO INFLUENCE
instagram: @andrewdobbie93
dobbrz is offline   Reply With Quote
Tune + Headers +e85 Worth it? or wait for FI? brzfl Engine, Exhaust, Transmission 39 08-29-2016 09:55 AM
WTT: Tomei uel headers for EL headers 86Tony Canada Classifieds 6 07-27-2015 10:42 PM
FI worth it? Gt86_nick Forced Induction 62 01-28-2014 01:55 AM
Injen SES Headers/ Agency Power headers Choong86 Engine, Exhaust, Transmission 10 12-27-2013 10:51 PM
Is the FR-S worth getting? DIM Scion FR-S / Toyota 86 GT86 General Forum 60 10-29-2012 12:43 AM
