Old 04-17-2017, 04:20 AM   #1
Smiley
Drives: Raven Black 2015 FR-S
Megan Racing EZ Street Series Coilovers
Guys! I installed my brand new coilovers onto my 2015 Scion FR-S, but I am having an issue. I got my wheels aligned and balanced without a problem. But now when I drive at about 22 mph to 33 mph, my wheels begin to shake (I almost want to say wobble). When that happens, my car begins to bounce up and down as if I am going over a million smooth wavy bumps. Can anyone tell me why this could happen? Also, my back coils, every time I hit a minor bump, I hear a slap from inside the vehicle. I cant hear it from the outside though. I feel like I almost have no springs on my coils. I am a beginner at this. I love my car and just want a clean ride. Can anyone help me? Before I take it to a suspension shop and they make me pay them for something that does not need to be fixed.
Smiley is offline   Reply With Quote
Old 04-17-2017, 05:43 AM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
The noise from the rear might be because they are just poor quality, worth making sure everything is tightened to spec though. As for the wheel wobble, again make sure everything is tight but it could be off balanced wheels.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-17-2017, 09:54 AM   #3
dattran86
Driver
Drives: 2013 Whiteout FRS
- Check the top nut inside the trunk make sure its tight
- Check everything in the rear coilovers making sure its tight
- Your Dampers setting might be too stiff, Soften them half way or so (too stiff = bumpy ride on bad road)
- Get a torque wrench to tighten all your wheel down to spec
- Get Hub Rings for your aftermarket wheel if U have Aftermarket.
Modifying car is a headache, Shoulda keep it stock OP
dattran86 is offline   Reply With Quote
Old 04-17-2017, 11:59 AM   #4
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
As stated above:
-Double check everything in suspension and make sure its tights
-Make sure lugs are torqued properly
The wheel shake is likely from improperly balanced wheels. You'll most likely have to take the wheels back to the tire shop to have the re-balanced. The popping in the rear is most likely from the top nut backing itself off. Torque it down and keep an eye on it.
No surprise there, given they're Megan
The Following User Says Thank You to TylerLieberman For This Useful Post:
Shark_Bait88 (04-17-2017)
Old 04-17-2017, 01:26 PM   #5
Chronology
Drives: 13' Satin White Pearl BRZ
I had a similar issue (bounce) with my RS*R's. My mistake was running track settings on a normal road. Adjust your settings from stiff --> soft, start at the middle and work your way to stiff or to soft.
If you are hearing noise (metal to metal) it could be the indication of the product, it's common for coils in that "range" to make noise.
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
Chronology is offline   Reply With Quote
frs scion gt86 brz
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 06:53 PM
FS: SoCal: Megan Racing Street Series haloterence Brakes, Suspension, Chassis 2 04-05-2014 01:57 PM
Megan Racing street series review Drftfan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 09-18-2013 09:31 AM
megan racing street series coilovers w/front camber plates 256brz2013 Brakes, Suspension, Chassis 33 07-01-2013 10:39 AM
Megan Racing Street Series Coilover Kit DeeJayMajesty Brakes, Suspension, Chassis 4 03-22-2013 05:59 PM
