Old 04-16-2017, 10:39 AM   #29
Lantana frs
Drives: 13 frs red
I wanna go 4.56 so I can leave like an automatic.
Lantana frs is offline   Reply With Quote
Old 04-16-2017, 05:19 PM   #30
phrosty
Originally Posted by Greddy86 View Post
Currently have a jrsc w/ hbp on 6AT frs. I'm thinking about going Cusco 5.1 FD w/ Cusco RS 1.5 way. Hopefully this setup will help me get off the lines faster and quicker corner exit speeds.
I'd just warn you that freeway suffers considerably. With a 4.88, I had to adjust my cruise speeds to be 15mph lower to avoid noise and heat soak. But if you have the JRSC you've got an oil cooler, so heat soak probably isn't an issue.
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
mrg666 (04-26-2020)
Old 04-16-2017, 06:09 PM   #31
Greddy86
Platinum Member
Greddy86's Avatar
Drives: 86
My intentions aren't for fwy driving.... lol
I have a daily for the freeways...
86two6 Thursday Meets in SoCal.
IG @86two6
Greddy86 is offline   Reply With Quote
Old 04-17-2017, 10:23 AM   #32
kingkenny
Drives: 2014 Toyota GT86
AT has a taller transmission ratio , and much less worry about the gear shift , may be it work .I think this would be some interesting experiment ... I actually think that I can never FI the car with the 5.1 FD setup , because too busy with gear shift and traction issue .
I suggest you consider to spend a bit more get a 2nd used diff. for these , just in case if it too aggressive and you can sell off the diff. .
Please update if this is really happen .
kingkenny is offline   Reply With Quote
Old 04-17-2017, 11:33 AM   #33
fika84
fika84's Avatar
Originally Posted by TRAKRAVN View Post
The diff makes a lot of noise when it's cold under low speed and tight turns. More so when releasing. I've only had the diff on the car for about 2000km. It's mostly just for track use and driving to and from the track. Overall I wouldn't go back to a helical LSD for tracking. I also have the Whiteline diff and subframe bushings so the noise is transmitted to the chassis more so then without them.
Sounds about right. I've got the bushings (and lots of other bushings, including motor mounts) and even got the plates WPC treated before installing them. I've got the diff set to minimal preload and lock capacity as well! The thing is a monster in the corners though which makes all the train noises totally worth it!
I think if I was to do it again, I would save up for the OS Giken.
fika84 is offline   Reply With Quote
Old 04-17-2017, 06:27 PM   #34
Greddy86
Platinum Member
Greddy86's Avatar
Drives: 86
Will do.
IG @86two6
brz, fdr, final drive
How-To: Change final drive ratio (relatively) cheaply PantsDants Engine, Exhaust, Transmission 84 03-22-2020 04:58 PM
MFactory Final Drives & Close Ratio Gears YCW Transmission and Driveline 0 09-29-2016 01:28 AM
4.556 final drive with TRD gear ratio change - good or bad idea? nzer Engine, Exhaust, Transmission 51 12-26-2015 10:15 PM
taller final drive ratio SuperDave Engine, Exhaust, Transmission 17 10-26-2014 04:37 PM
About track cars' final drive ratio immo Tracking / Autocross / HPDE / Drifting 4 09-23-2014 10:04 AM
