Old 04-12-2017, 03:54 PM   #2171
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Originally Posted by PR138 View Post
It is a DD first and foremost, but it will see 10+ autocross sessions a summer, along with 2-3 HPDEs at my local track. So I would consider it as needing a track-type setup for oil cooling. I'm currently leaning towards the C38 JRSC setup for the reasons you listed - proven setup with their own oil cooling designed to go with it. However, the extra low/mid range torque of this type of blower is calling my name. I don't know if I can resist the extra torque in a daily driver.
I had the same predicament. In the end, I figured I spend more time DD than on the track and that extra bit of low end torque when passing on the freeway or shooting the gap in traffic makes it all worth it.
The Following 2 Users Say Thank You to BigFatFlip For This Useful Post:
CSG Mike (04-12-2017), PR138 (04-12-2017)
Old 04-12-2017, 04:36 PM   #2172
PR138
PR138's Avatar
Drives: '14 WRB BRZ | '17 CB STi
YOU'RE NOT HELPING
Honestly though, your decision as to why to go with the Edelbrock is exactly what has me coming back to this thread every day. I've read through the entire thread as well as probably 75% of the JRSC thread, and I'm still undecided.
The allure of more lower end grunt with basically the same top end power is appealing, but the oil cooler situation is a bit of a downer.
PR138 is offline   Reply With Quote
The Following User Says Thank You to PR138 For This Useful Post:
Old 04-12-2017, 06:32 PM   #2173
CSG Mike
CSG Mike's Avatar
YOU'RE NOT HELPING
Edelbrock + Jackson Racing dual radiator oil cooler. Proven solution to work on track
PR138 (04-12-2017), strat61caster (04-14-2017)
Old 04-12-2017, 06:58 PM   #2174
PR138
PR138's Avatar
Not gonna lie - this is exactly what I was hoping to hear. I kept going back to the JRSC, but I secretly wanted confirmation that this would work out OK on the track.
You've given me what I needed to push me to the Edelbrock side. See you guys in a couple months, hopefully with dynos and pics. CSG - I'll be in touch to piece together what I need and to place my order as well.
The Following 3 Users Say Thank You to PR138 For This Useful Post:
CSG Mike (04-12-2017), Silverfox (04-12-2017), strat61caster (04-14-2017)
Old 04-14-2017, 01:46 AM   #2175
Vosinh
Drives: GT86 Auto black
Exclamation fuel leack
Hi! I just install my Edelbrock supercharger but I've 2 problems:
I can't start the vehicule (i think it's because I've not the good basemap. I'm wating for an other Ecutek tune.
But I've au other problem (maybe which is related to the tune?)
I've a fuel leak from driver side (see the picture) :-(
Do you know what is the problem?
sorry for my broken english... I'm french from Martinique
Vosinh is offline   Reply With Quote
Old 04-14-2017, 04:00 AM   #2176
dejahboi
dejahboi's Avatar
Drives: 13 FRS - Boosted
Is fuel leaking from the banjo? I can't remember the torque specs but it maybe loose?
Sent from my SAMSUNG-SM-G935A using Tapatalk
dejahboi is offline   Reply With Quote
Old 04-14-2017, 06:56 AM   #2177
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Originally Posted by Lunatic View Post
Yes, Yes.
What check valve are you using with the Radium setup? I found several options out there but want to see what others are using. I suppose a check valve in the PCV line would be good to use with any FI application even without a catch can.
https://www.vividracing.com/catalog/...FZCFswodVkMLQw $$$
http://tracylewisperformance.com/pro...-check-valves/ $
and it looks like USPlastics has several varieties but I don't see any with the 1/2' (12mm) barb ends, assuming you cut and inserted it into the Radium supplied hose.
https://www.usplastic.com/catalog/de...lickid=popcorn $
and then there's the Ebay specials....
BirdTRD is offline   Reply With Quote
Old 04-14-2017, 09:43 AM   #2178
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
[QUOTE=BirdTRD;2891498]What check valve are you using with the Radium setup? I found several options out there but want to see what others are using. I suppose a check valve in the PCV line would be good to use with any FI application even without a catch can.
I don't honestly know. My mechanic installed it. It is metal, kind of a brass color.
Lunatic is offline   Reply With Quote
The Following User Says Thank You to Lunatic For This Useful Post:
BirdTRD (04-14-2017)
Old 04-14-2017, 10:01 AM   #2179
Vosinh
yes, the banjo.
"Torque banjo 23 ft.lbs (31 N.m)." was correct
Old 04-14-2017, 02:36 PM   #2180
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
You shouldn't need a check valve for the Edelbrock since the breather outlets connect to pre-charged areas. Check valves are a good idea to use when the the breather connects to a charged (pressurized) area like an OE intake manifold on a force inducted car. I through a Vibrant Performance one-way valve on my wifes Forester XT (FA20DIT) when I did a catch can. Works like a charm. Our E-force equipped 86's shouldn't need it.
Nitro22 is offline   Reply With Quote
The Following User Says Thank You to Nitro22 For This Useful Post:
Old 04-16-2017, 11:05 AM   #2181
DanGTZ
Drives: 1989 Toyota Corolla GTI 16v
Question
Hello everyone,
Does anyone can provide me the link to download the free EcuTek tune from Edelbrock? Thanks
I already have EcuTek. Do I need to buy the Tuner kit or just the Hardware?
You need the kit without tuner, part number 15560. The CARB tune will be available for everyone to download, free of charge, from Edelbrock!
I looked at http://www.edelbrock.com/automotive/.../support.shtml but couldn't see any information related to this free tune.
Thanks.
DanGTZ is offline   Reply With Quote
Old 04-16-2017, 12:24 PM   #2182
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Originally Posted by DanGTZ View Post
Hello everyone,
Email calibration@edelbrock.com and they will send it to you.
Old 04-16-2017, 12:34 PM   #2183
DanGTZ
Ok thanks!
Envoyé de mon iPhone en utilisant Tapatalk
Old 04-17-2017, 09:33 PM   #2184
devtec
Drives: 2015 Subaru BRZ Limited
What does it mean that whenever I fill up with a full tank of gas, the engine feels smoother and stronger?
This happens very consistently, and it's not placebo. At higher RPMs it performs fine, more noticeable at lower RPMs. I also have the dreaded hesitation problem with the Edelbrock S/C, and having a full tank seems to help with that too.
Fuel pressure issue? Is it a known thing to have to do fuel-related upgrades for the Edelbrock S/C?
I have no other engine mods... Running Delicious tune v21.
Anyone else have this issue?
Thanks
devtec is offline   Reply With Quote
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
