#2171 | |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
#2172 | |
Drives: '14 WRB BRZ | '17 CB STi
![]() Honestly though, your decision as to why to go with the Edelbrock is exactly what has me coming back to this thread every day. I've read through the entire thread as well as probably 75% of the JRSC thread, and I'm still undecided. ![]() The allure of more lower end grunt with basically the same top end power is appealing, but the oil cooler situation is a bit of a downer. |
| The Following User Says Thank You to PR138 For This Useful Post: | CSG Mike (04-12-2017) |
#2173 | |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | PR138 (04-12-2017), strat61caster (04-14-2017) |
#2174 | |
You've given me what I needed to push me to the Edelbrock side. See you guys in a couple months, hopefully with dynos and pics. CSG - I'll be in touch to piece together what I need and to place my order as well. |
| The Following 3 Users Say Thank You to PR138 For This Useful Post: |
#2175 |
Drives: GT86 Auto black
Hi! I just install my Edelbrock supercharger but I've 2 problems:
I can't start the vehicule (i think it's because I've not the good basemap. I'm wating for an other Ecutek tune. But I've au other problem (maybe which is related to the tune?) I've a fuel leak from driver side (see the picture) :-( Do you know what is the problem? ![]() sorry for my broken english... I'm french from Martinique
#2176 | |
Drives: 13 FRS - Boosted
Sent from my SAMSUNG-SM-G935A using Tapatalk |
#2177 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
What check valve are you using with the Radium setup? I found several options out there but want to see what others are using. I suppose a check valve in the PCV line would be good to use with any FI application even without a catch can.
https://www.vividracing.com/catalog/...FZCFswodVkMLQw $$$ http://tracylewisperformance.com/pro...-check-valves/ $ and it looks like USPlastics has several varieties but I don't see any with the 1/2' (12mm) barb ends, assuming you cut and inserted it into the Radium supplied hose. https://www.usplastic.com/catalog/de...lickid=popcorn $ and then there's the Ebay specials.... |
#2178 |
Drives: 2015 Raven FRS
[QUOTE=BirdTRD;2891498]What check valve are you using with the Radium setup? I found several options out there but want to see what others are using. I suppose a check valve in the PCV line would be good to use with any FI application even without a catch can.
I don't honestly know. My mechanic installed it. It is metal, kind of a brass color. |
| The Following User Says Thank You to Lunatic For This Useful Post: | BirdTRD (04-14-2017) |
#2179 |
#2180 | |
Drives: Scion FR-S (Hot Lava)
| The Following User Says Thank You to Nitro22 For This Useful Post: | BirdTRD (04-14-2017) |
#2181 | |
Drives: 1989 Toyota Corolla GTI 16v
Hello everyone,
Does anyone can provide me the link to download the free EcuTek tune from Edelbrock? Thanks Quote:
Thanks. |
#2182 | |
Simply Forgotus
#2183 | |
Ok thanks! Envoyé de mon iPhone en utilisant Tapatalk |
#2184 |
Drives: 2015 Subaru BRZ Limited
What does it mean that whenever I fill up with a full tank of gas, the engine feels smoother and stronger?
This happens very consistently, and it's not placebo. At higher RPMs it performs fine, more noticeable at lower RPMs. I also have the dreaded hesitation problem with the Edelbrock S/C, and having a full tank seems to help with that too. Fuel pressure issue? Is it a known thing to have to do fuel-related upgrades for the Edelbrock S/C? I have no other engine mods... Running Delicious tune v21. Anyone else have this issue? Thanks |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
