Old 04-11-2017, 05:30 PM   #1
sp-BRZ
sp-BRZ's Avatar
Drives: 2016 Subaru BRZ
Roof Dent
I guess somebody was mad and decided to take it out on my brz.. Anyone know what I can do or how much it would cost to fix this dent in the corner of my roof?
sp-BRZ is offline   Reply With Quote
Old 04-11-2017, 06:31 PM   #2
jmark
Drives: '97 NSX-T, '18 Type R
Paintless dent removal.
jmark is offline   Reply With Quote
Old 04-12-2017, 12:28 AM   #3
First off ....... I don't see any dent ...... therefore, it must not exist .....for me at least......
Since it must be on the passenger side, if a passenger sees what they think is a dent......just tell them it's the lighting......
Or, like @jmark suggests, have a PDR person look at it (if they can find it). They should make it all better for about $100.
Old 04-12-2017, 08:34 PM   #4
KalbiCool88
KalbiCool88's Avatar
Drives: 2005 SLK350, 2015 RS 1.0 FRS
Depending on the person doing the PDR, they may change a bit more seeing how they need access to the dent in order to fix it. This means possibly taking the headliner off which in turn may charge more time.
KalbiCool88 is offline   Reply With Quote
Old 04-13-2017, 12:07 PM   #5
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Remove the headliner yourself before bringing it to PDR.
After PDR take the opportunity (or not) to put some sound deadening up there before reinstalling the headliner.
Done.
Edit: http://www.ft86club.com/forums/showthread.php?t=64362
Joon525 is offline   Reply With Quote
Old 04-13-2017, 12:15 PM   #6
JD001
JD001's Avatar
Drives: Subaru BRZ
After PDR take the opportunity to put some sound deadening up there before reinstalling the headliner.
Done.
I think they may be able to sort it without touching the lining.
Why add extra weight in the roof when our cars are all about low c&g..
Old 04-13-2017, 12:47 PM   #7
Joon525
Joon525's Avatar
Drives: 2016 BRZ
That's dependent on the owner. Some are more casual about actual performance and don't go all out (hence adding subwoofers and such).
But of course the OP doesn't have to do it if he doesn't want to. It was only a suggestion.
Old 04-13-2017, 03:05 PM   #8
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
The roof is thin enough for a PDR technician to probably do a glue pull. They won't have to access it internally.
dhuang is offline   Reply With Quote
Old 04-13-2017, 03:14 PM   #9
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Just put a band-aid sticker over it.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 04-13-2017, 11:28 PM   #10
Heck, the tops are so thin on our cars ....... one of these may pull the dent out ......
(CAUTION: DO NOT lean on another part of the top will pulling up the dart ....)
dent, fix, roof
FRS Dent on Roof and Hood OrlandGabeFRS Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 40 12-12-2016 01:51 AM
My First Dent! Wow... bobsacamenoh Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 40 01-06-2016 05:27 PM
FRS dent on roof and hood!! :( OrlandGabeFRS NY / NJ / CT / PA 12 09-02-2013 07:04 PM
Dent :( Will paintless dent removal be able to get this out? Greg_Di CANADA 22 08-31-2013 11:22 PM
