Xero Limit
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > DIY (Do-It-Yourself) Guides
Old 04-25-2014, 01:07 AM   #1
FRSPacNW
Drives: 2013 FRS (building)
Headliner Removal Guide
Hello Again everyone!
I needed to replace the Side curtain Airbags and did a quick search here for a Headliner removal guide.
I found a typed one asking for pics so i decided to make one. (I used this guide to begin with, its a good guide, thank you!!)
http://www.ft86club.com/forums/showt...ight=headliner
Tools:
Screw drivers - Both Flat head and Phillips.
I would grab a med size Phillips and a Med-small flat head.
To start i removed both Seats headrests to give myself extra room.
Remove Both Sun visors by removing the 2 Phillips screws each (if you have power to them, there will be a plug as well)
Next remove the 2 visor clips. This is kinda tricky and i almost messed it up.
Insert the flat head into the slot and push. Using your other hand pull down on the visor clip. this should release the rear of the clip, move the screw driver to the front (near the windshield) and do the same. I would release some pressure on the clip to allow the screw driver to not catch on the headliner.
The visor clip is a push-in on both sides and releases.
I had a better pic but i cannot find it sorry
next move the center, using the screw driver pull gently on the Bluetooth mic to pop from the headliner.
After the microphone, the center light should be pried using more force than the mic. Start at the front at both left and right sides as the metal clips are there.
After that, pull it back and it should be out!
Next i went to the back for the 3 clips. Here i had to be extra careful because these clips are fragile. Using the screwdriver, gently pry on the outer edge only till you see the inner white plastic.
Next the Pillars!!! These were tricky.
Front pillars:
using the flathead again, pry at the upper edge.
this will pop it open, now pull the pillar back and out.
I released the tether from the plastic on the fronts because it was easier.
Use the Same sequence for the Rear pillars.
Pry the rear, pull back and out.
On the rears, i removed the tethers from the body as it was easier. Use a flat head and push in the 2 smaller tabs in the center. I pushed in the top, pulled, then pushed in the bottom and it released.
At this point the Headliner was free and was held in place by only the B pillars where the seatbelts attach. I didnt want to remove these as the headliner i am working with is already creased because of the airbags.
I would recommend removing them if you dont want to crease your headliner though.
Hope you guys Enjoy and let me know if you want more pics!
FRSPacNW is offline   Reply With Quote
The Following 6 Users Say Thank You to FRSPacNW For This Useful Post:
Bonburner (12-16-2017), EAGLE5 (04-25-2014), Efferalgan (06-12-2017), FiRStsc10n (04-25-2014), Jman1759 (09-05-2014), ML (04-25-2014)
Old 04-25-2014, 09:16 AM   #2
FiRStsc10n
Canadian FR-S Member
FiRStsc10n's Avatar
Drives: FR-S '10 Series'
Always helpful to have these guides when the time comes.
FiRStsc10n is offline   Reply With Quote
Old 04-25-2014, 12:24 PM   #3
ML
Mr No Bumper
ML's Avatar
Drives: 13 White MT FR-S
Anyone seen mods to the headliner? Like resurfacing them or something.
Build Thread
Old 04-25-2014, 02:57 PM   #4
FiRStsc10n
FiRStsc10n's Avatar
Bulletproof automotive has a build they redid all of interior including headliner in red alcantara. I'm sure there is others too
The Following User Says Thank You to FiRStsc10n For This Useful Post:
ML (04-25-2014)
Old 09-05-2014, 03:49 PM   #5
Jman1759
Builder
Drives: 2014 BRZ - World Rally Blue
Seeing this part about the white and black clips on the back saved my bacon! Great write up, used this today! Will be shaving my antenna altogether and need to get in there to apply some backing material! Thank you!!!
Jman1759 is offline   Reply With Quote
Search this Thread:
Advanced Search
Removing Headliner? l0aded DIY (Do-It-Yourself) Guides 15 05-04-2016 01:24 PM
FR-S OEM spoiler removal -- rough picture guide CamryDS Cosmetic Modification (Interior/Exterior/Lighting) 5 07-28-2014 11:03 PM
WTB Headliner for FRS? Shock_r Canada Classifieds 4 11-26-2013 05:48 PM
Wtb rear deck / headliner jshadeck Exterior Parts (Aero, Lighting, Etc.) 0 02-03-2013 09:31 PM
FS: FRS (oem) Headliner NRG x FRS Interior Parts (Incl. Lighting) 1 11-28-2012 01:27 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
