Old 04-05-2017, 08:20 PM   #211
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by johan View Post
TJ was on 91.
I thought he could be on 93 just because solcal has 93.
Originally Posted by Bfranklyn86 View Post
That was on 91. But yeh, I was surprised (disappointed) with his numbers on pump. It's worth saying that he didn't have any throttle body work done though. Maybe water/meth is the way forward when there is no e85 availability.
I'm pretty sure the timing was retarded by the ECU or intentionally by Delicious knowing he would be running e85 most of the time. I'm sure they could have forced a tune, but it may have been risky.
Old 04-08-2017, 09:49 PM   #212
johan
Drives: '14 981CS, '99 NB1
Dyno tuned the car today.
The low line is my car with a tomei header, untuned... the best I've got for a baseline.
https://www.facebook.com/vittuned/po...93103370901328
johan is offline   Reply With Quote
The Following 3 Users Say Thank You to johan For This Useful Post:
Bfranklyn86 (04-09-2017), Irace86.2.0 (04-08-2017), kuczynskika (04-08-2017)
Old 04-08-2017, 11:43 PM   #213
Irace86.2.0
Do you think the numbers are off? Looks like you went from 138whp to 282whp and 124wtq to 224wtq. Seems like the base numbers are low unless the untuned header was killing your hp. These are big gains or decent numbers with a custom tune n a header. Stock pulley on 91 or what?
Old 04-09-2017, 12:19 AM   #214
VitViper
Drives: '15 FRS
The car made 158whp/132-ish wtq tuned with the header. Numbers are accurate. My dyno reads on the lower end for these cars -- a stock 6MT dynos 148-150ish.
edit: I've never seen an untuned header hurt power.
VitViper is offline   Reply With Quote
Old 04-09-2017, 01:55 AM   #215
Irace86.2.0
Gotcha. So those are sweet gains. Looks like 120whp+. E85?
Old 04-09-2017, 02:11 AM   #216
Bfranklyn86
Drives: GT86 Harrop S/C
280whp is an insanely good number for this kit with just one exhaust mod....to the extent that I want to go out and get that Tomie UEL header right now.
This is stock pulley and on 93 I assume....?
Bfranklyn86 is offline   Reply With Quote
The Following User Says Thank You to Bfranklyn86 For This Useful Post:
Irace86.2.0 (04-09-2017)
Old 04-09-2017, 04:09 PM   #217
VitViper
Drives: '15 FRS
I don't know what the "stock" pulley is. The one the kit came with originally was total junk and we swapped it out to the next step up one. I don't think I'd recommend anyone run the base pulley...
Car makes 11.5psi @ 7300 rpm.
Car has a 100% stock fuel system. If you can get E85 to work on a 100% stock fuel system with this blower (or really any F/I making 10psi+ boost) you've met a miracle man... -_-
Old 04-10-2017, 12:37 AM   #218
Irace86.2.0
Junk? Junk quality? Junk psi output? Not in the kits ideal efficiency range?
This guy used a smaller pulley too, 10psi. One of the first ones to get the kit from the other Harrop thread. I don't know why he didn't do a 4th gear pull with 93 or why do a 3rd gear pull at all. 4th with autos are 1:1, right? Anyways, in 3rd he made 270whp with decent mods. Who knows the other conditions like altitude or weather.
http://www.ft86club.com/forums/showp...&postcount=146
Old 04-10-2017, 12:57 AM   #219
VitViper
Drives: '15 FRS
Not ideal boost levels -- I felt it was too low. Maybe it's ideal for someone elses use/application.
I don't see a baseline for that car so those charts provide virtually no meaningful context. I see most Dynojets baselining 20-30hp higher than the FT86 do on my dyno (at least the ones I've seen locally).
With E85 I feel the pulley Jay is using could make ~300ish (it makes 11.5psi @ 7300 rpm, and about 12psi at 7600 rpm), but we need an injector upgrade first. That would be a solid 160whp+ over his "stock w/ raceheader" baseline and over 140whp over his "tuned w/ race header" baseline.
Great kit from Harrop, very clean install, I liked it.
The Following User Says Thank You to VitViper For This Useful Post:
COO86L (05-01-2017)
Old 04-10-2017, 01:33 AM   #220
Irace86.2.0
Yea i agree the numbers you're getting on this car n kit are great.
Old 04-10-2017, 03:57 AM   #221
Bfranklyn86
The standard pulley is 95mm. I guess you've gone to a 90 or 85mm.
It's good to see a tuner drop the pulley size by default - should in time prove that it can be done safely and mean that the rest of us are basically missing out on free power.
I would like to be up around 260-270whp myself. Currently at 240whp with the standard pulley and fully stock exhaust.
Old 04-10-2017, 12:19 PM   #222
johan
85mm
Old 04-14-2017, 08:38 AM   #223
Trefoil
Trefoil's Avatar
Drives: GBS BRZ Harrop SC/PTuning Header
85mm
Will the 85mm pulley work with 91 aki?
Trefoil is offline   Reply With Quote
Old 04-14-2017, 11:57 AM   #224
Irace86.2.0
Will it show gains, right? Thats the real question when you say work. More psi could just result in more knock causing the motor to retard timing which gives it less power, right? Im curious too. Where is the starving point for the injectors and where is the point where knock is an issue on pump gas?
JDL turbo kit owners thread yomny Forced Induction 1352 01-08-2025 04:20 AM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Harrop car lip kit? djdnz Cosmetic Modification (Interior/Exterior/Lighting) 15 12-15-2015 02:50 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
