Old 06-09-2016, 10:45 AM   #71
andrewFT86
andrewFT86's Avatar
Drives: dark grey metallic Toyota 86 MT
Tire Penz
Played with tire penz to help reduce (visually) the wheel gap. Will be lowering soon
andrewFT86 is offline   Reply With Quote
Old 06-11-2016, 01:25 PM   #72
andrewFT86
andrewFT86's Avatar
Dynamics coilover - finally
Stock height with small cans (air fresheners) on top of the tires to emphasize the gap.
Post install. Very great value for money coilovers.
Had a small oil leak and this needed to be replaced. Not sure if it's from my turbo kit or if it's factory. I'll know more after I talk to the mechanic.
Old 06-26-2016, 05:22 AM   #73
andrewFT86
andrewFT86's Avatar
Track day June 24
Finally able to track the car after the oil cooler, coils and wheels.
For budget coils, I can't complain and very happy to have given it a try. Track comfort and performance at paracetamol with the KW I had on my STI. (It may be unfair to compare 2 different coils on different cars). Versus stock, braking, cornering speed, acceleration and high speed stability.
Travel to and from the track was also comparable to the STI. No aching body after the 2 hours drive to the track and 2 hours back home. This is with the kind of roads we have here.
The oil temp maxed out at 230F in the winding section of the track and easily went down to 200-210 in the straights. No oil consumed after more than 15 laps. 5 cycles of 3-4 laps with 15-30 min of rest in between. Better heat management compared to my STI which tended to overheat on this track.
The Following 2 Users Say Thank You to andrewFT86 For This Useful Post:
ajaxthebetter (06-26-2016), MFB (07-08-2016)
Old 08-23-2016, 11:12 AM   #74
andrewFT86
andrewFT86's Avatar
DIY - functional shark fin vent (somewhat)
Old 03-21-2017, 11:15 AM   #75
andrewFT86
andrewFT86's Avatar
ARP GT mirrors
After a long time
Followed this DIY - http://www.ft86club.com/forums/showthread.php?t=32694
Complete except for removal of interior door handle trim before pulling out and up the door card/panel
Tools needed
Old 03-23-2017, 06:43 AM   #76
andrewFT86
andrewFT86's Avatar
More to follow ...
Old 03-29-2017, 09:46 AM   #77
andrewFT86
andrewFT86's Avatar
Hope to install soon
Old 03-30-2017, 01:45 AM   #78
andrewFT86
andrewFT86's Avatar
[IMG]http://i352.photobucket.com/albums/r360/asag888/Toyota%20GT86%20AVO%20Turbo/B0AC1703-7FB9-448A-94EF-***A2CED84B6.jpg[/IMG]
Old 03-30-2017, 08:26 AM   #79
StraightOuttaCanadaEh
Wes
looks great. How much did you drop the height by?
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
andrewFT86 (03-30-2017)
Old 03-30-2017, 12:19 PM   #80
andrewFT86
andrewFT86's Avatar
Thanks. About 1.5 inches/front and 1 inch/rear
Several more mods to come in the next 2 months.
Old 04-07-2017, 11:18 AM   #81
andrewFT86
andrewFT86's Avatar
One piece OEM 86 dash
subaru stamp
Old 04-08-2017, 11:28 PM   #82
andrewFT86
andrewFT86's Avatar
TOM's tails with small 86 and TRD details
DIY: one pice OEM dash trim
red TOM's tails
Rebadged "86" Weathertech mats
TRD brake fluid reservoir band
Old 04-09-2017, 04:41 AM   #83
andrewFT86
andrewFT86's Avatar
Originally Posted by JDM_inspired View Post
Nice build! What's the part number for the 2017 86 dashboard panel? Thanks
Astroboy (04-10-2017), Raven86Project (04-16-2017)
Old 04-10-2017, 10:15 PM   #84
andrewFT86
andrewFT86's Avatar
IRP short shift
[ame="http://youtu.be/gI7ozf-3Tfg"]http://youtu.be/gI7ozf-3Tfg[/ame]
After staring at it for almost 2 weeks and watching the above video x number of times I finally had it installed. A lifter makes the job easier and I'm glad I did not DIY on my own. FT86SF video was very helpful, i suggest to remove the exhaust for more room. There is a rubber boot covering the shifter linkage not included in the instruction video.
It works as promised and the product is truly on another level. The height will make you think about getting one but the height is one of the better things about it. More than the reduced throw (60% less as advertised) the reduced distance of 1/2nd to 3/4th to 5/6 is much less. Reverse lock out, works like a charm and is much cooler than the OEM design.
One thing not discussed in the video is road noise. Due to the removal of the foam insulation and the rubber boot the exhaust, road and drive shaft are all magnified.
This is a plus probably for some (hopefully more) and a deal breaker for others. This can be remedied with some DIY insulation or sound deadening. Ive yet to try the car on the highway but during my short trip home 100kph is very bearable.
[ame="http://youtu.be/B8-W-zyydrw"]http://youtu.be/B8-W-zyydrw[/ame]
Last edited by andrewFT86; 05-11-2017 at 06:42 PM. Reason: IRP short shift - title
Doors shaking like a mother empower-auto Electronics | Audio | NAV | Infotainment 16 10-08-2013 11:30 AM
Stupid Mother F***ing piece of S** Sketch575 Cosmetic Modification (Interior/Exterior/Lighting) 3 08-12-2013 10:30 AM
86 big brother Ryan86 AFRICA 16 01-02-2013 08:51 AM
LOL at my brother and his Mustang ML Other Vehicles & General Automotive Discussions 27 11-19-2012 10:37 AM
Every day use, and elderly mother taxi? Kiteless Scion FR-S / Toyota 86 GT86 General Forum 31 09-10-2012 11:26 AM
