Old 04-06-2017, 05:27 AM   #197
Liliflower
Drives: 2008 FT86 GTS
Updated! Techstream Ver.12.00.127 crack version + patch, no need activation
http://blog.obdii365.com/2017/04/05/...127-100-patch/
tested on windows 7. It is working. Just for share
Liliflower is offline   Reply With Quote
The Following 5 Users Say Thank You to Liliflower For This Useful Post:
BRZyJ (04-06-2017), FRSBRZGT86FAN (07-25-2018), HyperTech (04-08-2017), JF86Red (04-19-2017), tato.valverde (04-06-2017)
Old 04-07-2017, 10:20 PM   #198
camry619
Drives: Camry
Techstream V12.00.127 free download
Originally Posted by HyperTech View Post
how you get it to work? mine keep asking for a key to register...
I have Techstream V12.00.127 download link with register key in the text file.
https://mega.nz/#!kAxzDTqY!2O9PHSr7lNpz12iTZYVpD0JvP7wP5t2qta-zWILmFrA
Please do a fresh install and you will not have any problems.
Works ok on WIN7 32bit, haven't try WIN10, someone try yes.
Test it ok on the following interfaces:
MINI VCI
Cheapest MINI VCI Diagnostic cable
MVCI 3 in 1 interface
Mangoose VCI for Toyota
OTC GTS (IT3) Toyota Diagnostic Tool
And I make a installation video to prove it is cracked with working register key.
camry619 is offline   Reply With Quote
The Following 3 Users Say Thank You to camry619 For This Useful Post:
HyperTech (04-08-2017), JF86Red (04-19-2017), Xanatos (08-04-2018)
Old 04-27-2017, 06:59 PM   #199
Gunman
Drives: 2019 Mazda Miata RF
This cable work? seems to match the others.
https://www.amazon.com/CBK-Authentic...mini+vci+scion
Old 04-28-2017, 04:39 AM   #200
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Toyota TechStream Ver GTS_12.00.127 UPDATED POST #1
Trap63 is offline   Reply With Quote
Old 04-28-2017, 05:48 PM   #201
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Did a lot of searching but can't find the answer. I have version 12 installed but don't have a customize button to change my seat belt chimes.
Did it change from the others? Can anyone show me where the option to change this is?
Clueless
YamahaR86 is offline   Reply With Quote
Old 04-28-2017, 06:20 PM   #202
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2024 G70 3.3T
I had the same thing...it looked like it was connected, but there was no customize option and everything else was yellow/not ready status. I finally gave up screwing around with the 64 bit drivers and installed it on Windows XP, and the customize option was there. I noticed it also read the VIN after connecting which it was not doing before.
I didn't see any way to disable the door open sound when acc. is on though...that was the whole reason I bought the cable.
BRZyJ is offline   Reply With Quote
Old 04-28-2017, 08:11 PM   #203
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
It connected for me. I tried it on win 10 64 but didn't work. So I connected it on window 7 32. I can see malfunctions and clear my tpms light but no customize button.
Thinking they might have changed it from another version so I may try an earlier version.
Clueless
Old 04-29-2017, 02:21 PM   #204
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
V12 does not work for me. I installed v10.10 and it works for me.
Using Windows 7 x86 (32 bit).
V12 does not have "customize" feature, Utility feature or health check. Installed V10.10 and it showed up for me.
Clueless
Old 04-29-2017, 03:44 PM   #205
BRZyJ
BRZyJ's Avatar
Weird, I fired up the crusty laptop to check the version...12.00.127
...I think I had to set it to Europe before it worked.
Old 05-06-2017, 12:51 PM   #206
JF86Red
Drives: GT86 C7P
I finally tested it, and it works again.
Thanks a lot
JF86Red is offline   Reply With Quote
Old 05-06-2017, 04:49 PM   #207
byun
byun's Avatar
Drives: 2015 BRZ CWP
anyone in NorCal have this working?
byun is offline   Reply With Quote
Old 05-07-2017, 12:53 AM   #208
BRZyJ
BRZyJ's Avatar
Yep
Old 07-23-2018, 04:35 AM   #209
nkobns
Drives: Sideways
Does anyone know if there are some drivers to make the cable work with win10 32bits ?
Thanks !
nkobns is offline   Reply With Quote
Old 08-02-2018, 01:54 PM   #210
mato2sk
Drives: Toyota GT86
Is it possible to read the MAF sensor Voltage with techstream?
I want to scale the maf sensor.
mato2sk is offline   Reply With Quote
TPMS Tools developer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 10-04-2021 01:28 PM
anyone with a shop or tools Tylub Southern California 0 05-14-2013 11:03 AM
Tools? Gost Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 35 04-03-2013 03:46 PM
Tools for DIY maintenance? F1point4 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 08-08-2012 07:47 PM
