#197 |
Drives: 2008 FT86 GTS
Updated! Techstream Ver.12.00.127 crack version + patch, no need activation
http://blog.obdii365.com/2017/04/05/...127-100-patch/ tested on windows 7. It is working. Just for share |
| The Following 5 Users Say Thank You to Liliflower For This Useful Post: | BRZyJ (04-06-2017), FRSBRZGT86FAN (07-25-2018), HyperTech (04-08-2017), JF86Red (04-19-2017), tato.valverde (04-06-2017) |
#198 | |
Drives: Camry
Techstream V12.00.127 free download
I have Techstream V12.00.127 download link with register key in the text file. https://mega.nz/#!kAxzDTqY!2O9PHSr7lNpz12iTZYVpD0JvP7wP5t2qta-zWILmFrA Please do a fresh install and you will not have any problems. Works ok on WIN7 32bit, haven't try WIN10, someone try yes. Test it ok on the following interfaces: MINI VCI Cheapest MINI VCI Diagnostic cable MVCI 3 in 1 interface Mangoose VCI for Toyota OTC GTS (IT3) Toyota Diagnostic Tool And I make a installation video to prove it is cracked with working register key. |
#199 |
Drives: 2019 Mazda Miata RF
This cable work? seems to match the others.
https://www.amazon.com/CBK-Authentic...mini+vci+scion |
#200 |
Drives: Brz WRB - Europe LHD
Toyota TechStream Ver GTS_12.00.127 UPDATED POST #1
#201 |
JDM Vaping Stance Nation
Drives: 2013 White
Did a lot of searching but can't find the answer. I have version 12 installed but don't have a customize button to change my seat belt chimes.
Did it change from the others? Can anyone show me where the option to change this is?
Clueless
#202 | |
Drives: 2013 BRZ Limited / 2024 G70 3.3T
I didn't see any way to disable the door open sound when acc. is on though...that was the whole reason I bought the cable.
#203 | |
Drives: 2013 White
Thinking they might have changed it from another version so I may try an earlier version.
Clueless
#204 |
Drives: 2013 White
V12 does not work for me. I installed v10.10 and it works for me.
Using Windows 7 x86 (32 bit). V12 does not have "customize" feature, Utility feature or health check. Installed V10.10 and it showed up for me.
Clueless
#205 |
Weird, I fired up the crusty laptop to check the version...12.00.127
...I think I had to set it to Europe before it worked.
#206 |
Drives: GT86 C7P
I finally tested it, and it works again.
Thanks a lot
#209 |
Drives: Sideways
Does anyone know if there are some drivers to make the cable work with win10 32bits ?
Thanks ! |
#210 |
Drives: Toyota GT86
Is it possible to read the MAF sensor Voltage with techstream?
I want to scale the maf sensor. |
| TPMS Tools | developer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 27 | 10-04-2021 01:28 PM |
| anyone with a shop or tools | Tylub | Southern California | 0 | 05-14-2013 11:03 AM |
| Tools? | Gost | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 35 | 04-03-2013 03:46 PM |
| Tools for DIY maintenance? | F1point4 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 19 | 08-08-2012 07:47 PM |
