Old 04-01-2017, 11:37 AM   #15
ort895
ort895's Avatar
Pretty nice gains, just not a fan of flex joints.
Yeah its an auto, deal with it.
ort895 is offline   Reply With Quote
Old 04-01-2017, 04:19 PM   #16
cjd
cjd's Avatar
Drives: 2017 BRZ
I don't even get to the flex joints... not a fan of a company that consistently steals designs.
The Following 2 Users Say Thank You to cjd For This Useful Post:
G-Man (04-03-2017), JazzleSAURUS (05-16-2017)
Old 04-01-2017, 05:29 PM   #17
ort895
ort895's Avatar
Well that as well.
Old 04-01-2017, 08:05 PM   #18
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
I have the exact headers as well as a front and over pipe. They perform and sound good, but the flex pipe serves no purpose, just a million little exhaust leaks and a strange sound produced because so.
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Old 04-01-2017, 08:09 PM   #19
MurderousPandas
Oh, and because of the million exhaust leaks, you'll want to disable an O2 sensor code, i forgot which one exactly, but it will make the car run much better, otherwise you'll appear to be running lean and the car will give a pinch more fuel than needed.
Old 04-01-2017, 11:01 PM   #20
cjd
cjd's Avatar
Drives: 2017 BRZ
Disabling the code won't prevent the car from running poorly due to exhaust leaks... it just prevents it from throwing a code to say "hey, I think it's running like crap"
Old 04-02-2017, 01:19 PM   #21
MurderousPandas
I disable an O2 sensor code, forgot which one, but fuel trims fixed themselves very well. It was also mentioned in a thread about the code, i'll see if i can find it.
Old 04-02-2017, 01:34 PM   #22
cjd
cjd's Avatar
Drives: 2017 BRZ
I believe that trims got better around the same time as you disabled the code, but I'm pretty sure they're unrelated. Exhaust leaks, especially leaks near the header, are not good. They need to be fixed when they're there.
C
Old 04-02-2017, 09:45 PM   #23
MurderousPandas
C
Well, i'm sure the leak wouldn't fix itself, if anything get worse as bolts loosen over time. The PLM header's flexpipe is where it leaks, but my trims combined are only +/-2% now, where as before disabling the code it was nearing 10%+.
Old 04-05-2017, 08:30 PM   #24
nocoolname
Originally Posted by sirsol66 View Post
Would you be able to put up an OFT log for this? I'm curious how the off the shelf tune reacts with this header (mainly from a safety/knock viewpoint)
Sorry, I haven't been on the forum in a couple days but I think I have some logs saved. I put a perrin intake on last weekend (I know it doesn't give any power but i needed to replace my factory intake box for other reasons) and have been working on maf scaling. I do know the few times I logged after the header that I didn't record any knock
2001 MR-S - long, slow, rebuild
2000 MR-S - 2zz swapped daily
2013 BRZ limited - new toy
nocoolname is offline   Reply With Quote
Old 04-06-2017, 12:39 PM   #25
sirsol66
Drives: 2013 FRS- Hot Lava
Thanks! If you get bored and have a log of it with the stock intake, I would be super curious to see it. Realistically speaking its almost $300 cheaper than the OFH so I'm leaning towards that. But, I run the OFH on my other cars so I dont want to stray away if there's any concerns with knock. Thanks!
sirsol66 is offline   Reply With Quote
Old 04-06-2017, 02:00 PM   #26
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Exhaust gasses escaping from the flex joint would be something that would prevent me from purchasing this piece regardless of price or dyno results.
Intent > Content
Old 04-06-2017, 04:22 PM   #27
MurderousPandas
It sucks that the heat goes straight to the engine bay, the header is right below the oil pan, and the sound it makes isn't great. I went with it because it was cheap, i don't plan on spending more than 500USD for a part yet, and headers are a good power adder but most are nearing a thousand. When i near the end of my build, i'll be replacing the parts i cheaped out on and topping it all off with a supercharger.
The Following User Says Thank You to MurderousPandas For This Useful Post:
solidONE (04-08-2017)
Old 04-10-2017, 12:28 PM   #28
sirsol66
Decided to pull the trigger on one of these. Will be running it with a muffler delete on my 2.0 and OFT. I'll post a review shortly after I get it.
Private Label MFG (PLM) Power Driven FR-S / BRZ TRACKPIPE Muffler Delete SALE!! witz Engine, Exhaust, Bolt-Ons 67 08-05-2016 02:51 PM
$350 (PLM) Power Driven FRS/BRZ/FA20 LONG TUBE (EL) HEADER *GROUPBUY* witz Groupbuys 71 08-05-2016 02:50 PM
Private Label MFG Power Driven FR-S/ BRZ (2.5in/63mm) OVERPIPE SALE!! witz Engine, Exhaust, Bolt-Ons 64 08-05-2016 02:49 PM
$350 Private Label MFG (PLM) Power Driven FRS / BRZ / FA20 LONG TUBE (EL) HEADER witz Engine, Exhaust, Bolt-Ons 69 08-05-2016 02:48 PM
For stock power and street driven: 17x8 vs. 17x9 and +35 (245/40) vs. +45 (225/40)? Meanderchap Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 01-06-2016 04:02 PM
