Old 04-05-2017, 01:00 AM   #1
#my86build
Cusco 4.556 final drive questions
Hi everyone,
I'm planning to have my FD installed next week and had a couple of questions. I've searched the forums and have only found reviews on the subject. Do I or the shop that I'm having it installed at need to purchase shims, a pinion shaft, differential bushing (suggested since I'm doing the FD) "It supposed to help with getting the car off the line". Also, do I need to change the differential oil to Tomei differential oil? Is this all necessary? Is there anything else I need to know about before having it installed? My car has 14k on it at the moment. Cusco USA says everything I need is in the kit, so I'm a bit confused.
#my86build is offline   Reply With Quote
Old 04-05-2017, 11:15 AM   #2
Rougenite
Drives: Raven FR-S
I don't know what CUSCO puts into their kit. Open the box and see whats in there. The pinion shaft is more than likely part of the kit. Shims probably are as well. Bring the box of parts to the shop and have them look if you do not want to do it.
Look up the Whiteline diff bushing stuff (they have two types). You do not need to replace, it is an option based on preference.
Rougenite is offline   Reply With Quote
The Following User Says Thank You to Rougenite For This Useful Post:
#my86build (04-06-2017)
Old 04-05-2017, 01:24 PM   #3
kingkenny
Drives: 2014 Toyota GT86
1.41201D Pinion shim set all size , it take only one but need all of it to adjust clearance , better to have these ready if you don't want any delay .
2.41231 Pinion spacer/distance collar , in my case this parts was not useable and mine was replace/upgrade to cusco distance collar but need Nissan Shim set to adjust pinion clearance , the 41201D shim set no longer suitable .
3.41334B x 2 differential size seal
Other stuff , the workshop have it for me .
kingkenny is offline   Reply With Quote
The Following User Says Thank You to kingkenny For This Useful Post:
Old 04-05-2017, 07:21 PM   #4
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
Did you already purchase the Cusco kit? My understanding is that it uses an OEM Toyota ring and pinion and is therefore quiet and reliable. If you want to save some money Weir Performance offers an excellent 4.56:1 kit for quite a bit less money, which is what I chose to do.
Unless you're replacing your LSD at the same time you can continue to run OEM specification 75w90 gear oil, so there's no need to run special Tomei fluid.
Last edited by RJasonKlein; 04-05-2017 at 10:14 PM. Reason: Corrected a typographical error.
RJasonKlein is offline   Reply With Quote
Old 04-05-2017, 08:01 PM   #5
#my86build
Thank you all for chiming in and helping a new guy out. I opened the box today at the shop and there is a ring, pinion and a bag of misc that I'm not familiar with. I got really confused because I was talking with the sales guy at the shop initially and not the tech. Now that I've spoken to the tech, I understand the part instal a little more clearly. The only sad part is I will have to be without my car for about a week. They will order new shims from Toyota and that is included in the 8hr instal rate. I will also be adding the Whiteline rear diff mount and transmission mount bushing insert, along with the Mtec shift springs as well. Figured I might as well save some money on shop time, cause we all know, that ain't cheap.
P.S. How do I give these guys a forum thanks? The ones the forums keeps track of.
Old 04-05-2017, 09:28 PM   #6
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Here is what I ordered for my install...
90311-38070 pinion seal $8.71 - the one included in the Toyota kit will not fit our housing...
90366-35133 pinion bearing $87.06 - not strictly necessary, but can can be damaged during removal from your old pinion shaft...
12157-10010 drain bolt gasket $1.08
SU003-00122 fill bolt gasket $1.79
90311-43009 quantity 2 differential axle seal($15.60 each)
Most differential shops stock the shims and oil - I was not picky on the oil since I changed it out after 500 mile break in.
nextcar is offline   Reply With Quote
The Following User Says Thank You to nextcar For This Useful Post:
Old 04-05-2017, 10:31 PM   #7
RJasonKlein
Congratulations and welcome to the forum! I have every modification you're installing and I think you'll be very happy with them - the car will definitely be more responsive, shift better, and be perceptibly quicker, but there will be a small (but noticeable) increase in NVH. It wasn't a big deal for me, but you (or your wife, girlfriend, mother, or boss) may feel differently.
You'll be able to thank other members after your 10th, 15th, or 20th post (I've forgotten which) by clicking on the 'Thanks' button that will appear to the right of the 'Quote' button on any post.
The Following User Says Thank You to RJasonKlein For This Useful Post:
Old 04-06-2017, 02:32 AM   #8
#my86build
Thanks for the info and part numbers, I'm assuming. If those are indeed part numbers, my OCD thanks you. I didn't know there was a 500 mile break in period. Is there a certain RPM that I should not be passing during this time?
Old 04-06-2017, 02:37 AM   #9
#my86build
Thanks for the info!
Old 04-06-2017, 02:54 AM   #10
#my86build
I had the rear gutted in my first FR-S build with a Grimmspeed intake, Tomei UEL, Nameless catted resonated overripe, Perrin CB resonated (both 2.5") and loved all the NVH. I've got a extra Perrin kicking around that I'm planning to do a muffler delete on. Even more NVH
As for what others think of the sound/noise...I actually don't care, at all. No girl I know would open her mouth and complain about such insignificant matters. If she did, I would pull over and suggest she walk.
You'll be first one I thank, once I've earned my forum stripes. Until then,
The Following User Says Thank You to #my86build For This Useful Post:
RJasonKlein (04-06-2017)
Old 04-06-2017, 10:42 AM   #11
nextcar
Not RPM limited... general rules:
1) After install, drive for 30 minutes at highway speeds to get the gears up to operating temp followed by a full cool down of at least 3 hours parked.
2) repeat the 30 minute highway drive/3 hour cool down a total of 3 times.
3) No burn outs/hard launch/hard shifts for first 500 miles...
After break in I switched to Motul 300 synthetic gear oil...
The Following 2 Users Say Thank You to nextcar For This Useful Post:
#my86build (04-06-2017), tmaz42o (06-14-2020)
Old 04-06-2017, 01:51 PM   #12
nextcar
Yes, those are the part numbers...
As far as the pinion spacer/crush sleeve is concerned, the Cusco kit, which is in reality just a Toyota kit, already contains one. It is the metal tube that is about 1.5 inches in diameter and a bit over 2 inches long.
Old 04-06-2017, 03:22 PM   #13
#my86build
I remember reading that it was nothing more than a glorified, marked up Toyota product, rebranded Cusco and then "Cusco taxed" on top of that. However, I also have aluminum bits in my car with "blue powder coat tax" on them as well. What I'm getting at, is that I'm a sucker.
Old 04-06-2017, 04:23 PM   #14
nextcar
Don't be so hard on yourself... I don't know where "Raincity" is, but in the US it is impossible to order the Toyota kit - Cusco represents a valid sales channel for those not comfortable with the hassles of foreign purchase and import...
If you are willing to take on the headache of self-importing (I did...), you can save some money - but is not exactly hassle free!
4.8 final drive drift86 Engine, Exhaust, Transmission 29 11-28-2022 12:49 PM
CUSCO 4.55 FINAL DRIVE installed. Racecomp Engineering Engine, Exhaust, Transmission 488 06-17-2018 12:14 AM
Needed: drive line shop in Houston for 4.56 final drive install - good experiences? Joesurf79 Southwest 3 03-10-2017 12:21 AM
Final Drive 4.67 Bongertz Engine, Exhaust, Transmission 33 09-02-2015 03:11 PM
3.3 Final drive? Manji Engine, Exhaust, Transmission 18 01-01-2015 02:51 PM
