Old 04-04-2017, 09:32 PM   #15
Originally Posted by Mr Nerd View Post
You have mice crawling up there to keep warm at night. Bet.
......... pay attention .........
The bumper knows that someone crushed it ........ the OP had the rodent problem.
EDIT: OK, you're off the hook .......you edited your post ......
Old 04-04-2017, 09:38 PM   #16
Mr Nerd
Mr Nerd's Avatar
This is what I get for being on the forums while I'm at work.
Mr Nerd is offline   Reply With Quote
Old 04-04-2017, 09:57 PM   #17
Ya, I know how that goes ....... I get distracted by the baby needing changing (especially with the pooie diapers) or the baby needing a bottle or having to run to the grocery to get more baby food or ........oh yes ma-ma does most of it but I help out.
Multi-tasking is not my strong suit ...... I find single tasking hard enough .....
pa-pa humfrz
Ultramaroon (04-05-2017)
Old 04-04-2017, 10:48 PM   #18
Originally Posted by tjohnson104 View Post
bump. Does anybody know what the red clip controls? I need to replace that part. Mine was pinched during a clutch install and I am having a hard time figuring out what it controls and what it is even called.
Neutral switch
Old 04-04-2017, 10:50 PM   #19
Mr Nerd
Mr Nerd's Avatar
Neutral switch
I think your pic took a neutral switch
Old 04-04-2017, 10:58 PM   #20
Old 04-04-2017, 11:39 PM   #21
@Mr Nerd has been two steps behind and one to the side on this thread .....
Ultramaroon (04-04-2017)
Old 04-04-2017, 11:46 PM   #22
Mr Nerd
Mr Nerd's Avatar
The pic doesn't work for me
Is it because I'm white?
Old 04-05-2017, 07:16 PM   #23
Haha... maybe. It doesn't work for me from my work connection either. That's weird.
Click the readme on my sig. Repair manual > Drivetrain > tl70 manual transmission > Neutral position switch
Edit: oh! Now it loaded because I navigated to the page. Meh. ok.
Old 04-05-2017, 07:23 PM   #24
e1_griego
e1_griego's Avatar
Drives: Many
So the OP's car is actually my car.
He ended up hardwiring the wires straight across which wasn't great imo. I ended up replacing the reverse sensor (black plug) and finding the right pigtail for the other side (same as 240sx speed sensor plug that you can buy from Wiring Specialities) and wiring it all in like OEM.
I was losing the R indicator and backup cam with the old reverse switch. Thought it was the wiring but turns out it was the sensor itself.
e1_griego is offline   Reply With Quote
Old 04-05-2017, 08:22 PM   #25
Old 01-24-2019, 02:52 PM   #26
Djphamtom
Djphamtom's Avatar
Drives: 2013 Scion FR-S (base)
I have the same problem, but those rats ate mine wires. I'm getting my engine fix from the dealership because of the recall. While the technician was fixing, he came across these wires chewed. He told me that it's the neutral and backup switch. So if the black clip is the backup switch, then I suspect that the red clip is the neutral switch.
Djphamtom is offline   Reply With Quote
Old 12-27-2019, 01:05 PM   #27
Gamace
Gamace's Avatar
Drives: 2012 Toyota 86
I have this same issue, however, the problem for me, is that the end on my reverse light switch has been rubbed down. When the reverse gear is engaged, it's not sinking the switch down enough to trigger the reverse light/camera.
So I need a new switch overall. Does anyone know where I can order one of these?
Sent from my SM-N975U1 using Tapatalk
Gamace is offline   Reply With Quote
Old 12-27-2019, 03:26 PM   #28
Are you not able to order parts through a dealer there?
FR-S / BRZ Reverse/Backup LED Bulbs! See Comparison Photos, Ships Same-Day! Diode Dynamics Exterior Parts - Lighting 72 11-30-2021 02:19 PM
Diode Dynamics Tail-as-Turn™: Make your LED tail a turn signal & add backup LEDs! Diode Dynamics Exterior Parts - Lighting 192 10-04-2017 11:51 AM
Reverse gear signal on factory HU harness? Panman Electronics | Audio | NAV | Infotainment 2 01-24-2014 10:24 PM
Interior LED + Reverse backup package? Intake Scion FR-S / Toyota 86 GT86 General Forum 1 07-12-2013 11:46 AM
Radio Signal Issue When shifting into Reverse ruskymx Scion FR-S / Toyota 86 GT86 General Forum 13 01-22-2013 09:05 PM
