#85 |
I Love custom Turbo kits
Drives: Limited BRZ
😂 😂 😂 true... If I had all the money in the world to throw at it, would definitely be boosted but I don't so that's why it's not.
#86 | |
Drives: Limited BRZ
The plan is to have KAB fabricate the mounts, they'll either do the full exhaust or ill take it to a good local friend to do it, I already bought shorty headers for it. Any custom work will be done though Kab really to make the AC fit etc...
#87 | |
Drives: 2015 FRS - FFR GTM
Nice,,, KAB in Miami??
2015 FR-S - One Day I'll Finish The Swap |
#88 |
Drives: Limited BRZ
KAB in South FL, he's in Broward. Was in Sunrise now moving 5 minutes north starting in March
#89 |
Drives: Limited BRZ
Work on my car is supposed to start next week. Ended up buying CX Racing mounts and have the shop modify them as required (if needed).
Also pretty set on getting the Motec M130 deal from Pure Automotive, based on the functionality it offers. More pics to come as it gets worked on.
#90 |
Drives: 2017 WR BLUE BRZ
Cool, why did you choose the cx mounts over the weapons grade stuff?
Im with you on that motec. I want everything to work like factory and would rather not have to change the gas pedal. |
#91 | |
Drives: Limited BRZ
Additionally, any modifications need to be made for the CX mounts KAB is ready to do them. The CX mounts do have good reviews.
#92 |
Drives: 2013 Ultramarine FR-S
Thinking about doing the same with the CX mounts. Want to try and get the car running before summer really hits and lot of events pop up. Not to mention perfect back road/track weather.
#93 | |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Also... I find it weird that anyone would say their ac works sometimes and doesn't other times. If they are running dual ecu and their hvac controls only work sometimes, they fucked up some wiring they never should've touched.
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#94 |
Haltech is supposedly working on it/has it working. MotoEast is using it in their RB Swap.
#95 | |
Drives: Limited BRZ
#96 |
Drives: Limited BRZ
Inclined to now go with Hooker shorty headers, they're shorties with 1-7/8" which is what I'm looking for.
#97 |
Drives: Limited BRZ
Need to make a decision on the Oil pan. Only LS Oil pan with a front sump is the GTO one. The problem is I am concerned with the rear end of it, that has a protrusion that would need to sit behind the subframe. That would limit the movement I play I can have with the engine back and forward to accomodate the shifter. The CX racing pan has more room for play as the back is completely flat, but it introduces other things like needing to remotely locate the filter and cut the disptick to correct length.
Below GTO Pan. ![]() CX Racing pan
#98 |
Drives: Limited BRZ
Good friend @spitfire481 also pointed me the Sikky oil pan which seems like another solid option
https://www.sikky.com/product/lsx-oil-pan/
| Sportsguy's LS2 Swapped BRZ | Sportsguy83 | Member's Car Journals | 2969 | 08-20-2018 11:12 AM |
| FS: (Sold) Sportsguy ArmRest | kvnchu | Interior Parts (Incl. Lighting) | 22 | 03-13-2014 02:40 PM |
| Sportsguy's AVO Turbo experience, the Good the Bad and the Ugly | Sportsguy83 | Forced Induction | 155 | 08-05-2013 06:17 PM |
| Motegi 126 customs | kioton32 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 06-26-2013 12:34 AM |
| FS: NY - Sportsguy Handcrafted Armrest | xxscaxx | Interior Parts (Incl. Lighting) | 43 | 05-04-2013 05:30 PM |
