Old 02-22-2017, 10:06 PM   #85
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by vgi View Post
, we'll see once you're done with the build and drive it for some time...
😂 😂 😂 true... If I had all the money in the world to throw at it, would definitely be boosted but I don't so that's why it's not.
Old 02-22-2017, 10:09 PM   #86
Sportsguy83
Drives: Limited BRZ
Originally Posted by gtpvette View Post
Sportsguy,,, a couple of questions. You mentioned a shop KAB that will be doing the work. Are they local??? As for the bits and pieces to mount the engine and trans,, is the plan to fabracate these or use someones kit?? What about headers and exhaust, radiator, AC compressor brackets, etc. etc. I know there's a thousand things have to be done, do you a general idea of the details you might share???
It's going to be a super hot rod!
Thanks!!!.
The plan is to have KAB fabricate the mounts, they'll either do the full exhaust or ill take it to a good local friend to do it, I already bought shorty headers for it. Any custom work will be done though Kab really to make the AC fit etc...
Old 02-23-2017, 10:06 AM   #87
gtpvette
Drives: 2015 FRS - FFR GTM
Thanks!!!.
Nice,,, KAB in Miami??
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
Old 02-23-2017, 10:50 AM   #88
Sportsguy83
Drives: Limited BRZ
KAB in South FL, he's in Broward. Was in Sunrise now moving 5 minutes north starting in March
Old 03-22-2017, 06:44 PM   #89
Sportsguy83
Drives: Limited BRZ
Work on my car is supposed to start next week. Ended up buying CX Racing mounts and have the shop modify them as required (if needed).
Also pretty set on getting the Motec M130 deal from Pure Automotive, based on the functionality it offers. More pics to come as it gets worked on.
Old 03-22-2017, 10:15 PM   #90
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Cool, why did you choose the cx mounts over the weapons grade stuff?
Im with you on that motec. I want everything to work like factory and would rather not have to change the gas pedal.
ILLSMOQ is offline   Reply With Quote
Old 03-22-2017, 10:18 PM   #91
Sportsguy83
Drives: Limited BRZ
WGP stuff doesn't have any stellar reviews and only bought the engine mounts, which the CX ones are fairly simple and provide adjustability. Transmission mount will be done custom by KAB.
Additionally, any modifications need to be made for the CX mounts KAB is ready to do them.
The CX mounts do have good reviews.
Old 03-24-2017, 11:27 AM   #92
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Thinking about doing the same with the CX mounts. Want to try and get the car running before summer really hits and lot of events pop up. Not to mention perfect back road/track weather.
Old 03-28-2017, 04:52 PM   #93
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
The plan is still to use the MRS CAN device with GM and BRZ ECU. Only reason why I don't say 1000% it's a done deal is only because @MRS-Colin is still working on getting the Push Button start working and I need that in order to use it.
The desire to use the CAN device instead of a full standalone is the cost difference between both is somewhere around $4-$6k.
I know of someone local with 2JZ swap who used the Haltech 2500 Elite and has some of the functions working, but some others don't and some like the A/C sometimes works and sometimes don't.
In the end, any capable standalone (Haltech 2500, Motec M150/M130, AEM Infinity 8H, Emtron, etc) have the capability of controlling the stock car systems. The problem is having the money to buy one and having someone who is able to program it to control the CAN systems.
False, the haltech 2500 and aem 8h do not have the capabilities to control/communicate the frs can protocol. That's the reason for having to maintain the frs factory ecm and bcm, and if running stock cluster a different or custom crank trigger. Only the ones you listed that can are the m1x0 series and the emtron ecus.
Also... I find it weird that anyone would say their ac works sometimes and doesn't other times. If they are running dual ecu and their hvac controls only work sometimes, they fucked up some wiring they never should've touched.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 03-28-2017, 04:59 PM   #94
DustinS
DustinS's Avatar
Haltech is supposedly working on it/has it working. MotoEast is using it in their RB Swap.
Old 03-28-2017, 05:52 PM   #95
Sportsguy83
Drives: Limited BRZ
Thanks for the further clarification.
Old 04-05-2017, 06:14 PM   #96
Sportsguy83
Drives: Limited BRZ
Inclined to now go with Hooker shorty headers, they're shorties with 1-7/8" which is what I'm looking for.
Old 04-05-2017, 06:18 PM   #97
Sportsguy83
Drives: Limited BRZ
Need to make a decision on the Oil pan. Only LS Oil pan with a front sump is the GTO one. The problem is I am concerned with the rear end of it, that has a protrusion that would need to sit behind the subframe. That would limit the movement I play I can have with the engine back and forward to accomodate the shifter. The CX racing pan has more room for play as the back is completely flat, but it introduces other things like needing to remotely locate the filter and cut the disptick to correct length.
Below GTO Pan.
CX Racing pan
Old 04-05-2017, 06:58 PM   #98
Sportsguy83
Drives: Limited BRZ
Good friend @spitfire481 also pointed me the Sikky oil pan which seems like another solid option
https://www.sikky.com/product/lsx-oil-pan/
Sportsguy's LS2 Swapped BRZ Sportsguy83 Member's Car Journals 2969 08-20-2018 11:12 AM
FS: (Sold) Sportsguy ArmRest kvnchu Interior Parts (Incl. Lighting) 22 03-13-2014 02:40 PM
Sportsguy's AVO Turbo experience, the Good the Bad and the Ugly Sportsguy83 Forced Induction 155 08-05-2013 06:17 PM
Motegi 126 customs kioton32 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-26-2013 12:34 AM
FS: NY - Sportsguy Handcrafted Armrest xxscaxx Interior Parts (Incl. Lighting) 43 05-04-2013 05:30 PM
