Old 04-05-2017, 05:21 AM   #953
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Originally Posted by JW843 View Post
Would there be any reason for me to scale MAF settings when running on a catless header/stage 2 OTS tune with stock intake? I had a grimmspeed intake on, took it off, and i'm still getting odd values. i have high LTFT at idle and low RPM's/throttle. I have very random STFT spikes, and command AFR and recorded AFR can differ quite a bit. I've cleaned the MAF sensor but no changes were noticed. any thoughts?
Make a thread on this. High positive fuel trims at idle usually means vacuum leak or a prob with a catch can. But it can be other things like header gaskets. Don't scale your MAF or make tuning changes until you take care of this problem.
guybo is offline   Reply With Quote
Old 04-05-2017, 06:05 AM   #954
steve99
Drives: FT86
Originally Posted by allowe View Post
I still have cat, Evap and oxygen sensors not ready but when I floor it at 6th gear with low revs (very low) the car doesn't go up in speed at all
I tuned it to stage 1 91 yesterday and turned on LC.
yes as Tor said not good to lugg car but the problem you describe can also occurr in 1st gear its due to an error in setting load limits in some tunes.
look at load limit table and make sure its not set all above 1.5 , set them as per a stock tune
allowe (04-05-2017)
Old 04-05-2017, 06:17 AM   #955
steve99
Drives: FT86
The Grimspeed intake is very close to stock maf scaling wise, you should not need to re-scale maf.
Dont worry about STFT it will vary widly with throttle application and load.
Just look at LTFT which is the average of STFT over time.
If you ltft is way positive at low rpm and good averywhere else its usually an indication of a leak in intake or exhaust
as @guybo said if this has just occurred then check for leaks or other issues dont just rescale maf to cover over another possible issue
Old 04-05-2017, 06:25 AM   #956
JW843
JW843's Avatar
Drives: 2013 BRZ Limited
Yeah I've swapped out the gaskets for new ones on the header, assuming the leak would be somewhere on there near the o2 sensors. No changes, still consistently LTFT up to 9%. Checked the intake pretty throughly and can't find any leaks. Any other common suspect areas to check? Also, it's a v1 borla uel which is known to have some issues. I don't see any spots along the header but who knows.
Sent from my SM-G925V using Tapatalk
JW843 is offline   Reply With Quote
Old 04-05-2017, 06:28 AM   #957
steve99
Drives: FT86
is that +9% at idle then whats ltft at higher rpm still positive ?
are you on straight petrol or 10% ethanol ?
Old 04-05-2017, 06:43 AM   #958
JW843
JW843's Avatar
Idle fluctuates a bit usually closer to 3 to 5%, the 9% is pretty consistent at low throttle cruising. I've got a graph of it in the data logs thread that was posted pretty recently
Old 04-05-2017, 07:11 AM   #959
steve99
Drives: FT86
mate if its this log here
http://www.datazap.me/u/jwiggins864/...7?log=0&data=9
it doesnt look like a leak to me usually with leaks you getvthe most effect at low rpm\flow rates then as rpm increases the effect ofcthe leak is less and the ltft trend to normal values.
id expect rearly high ltft at idle and very low rpm if it was a leak
you have +2 at idle then a spike to +9 arround 3000 then back to +2 again at higher rpm.
looks like your safe to just scale the maf if you need too
Old 04-05-2017, 11:15 AM   #960
guybo
Huge E85 fan!
guybo's Avatar
I wouldn't worry too much about +9 LTFT at idle. I thought you meant high as in 20 or more
Old 04-05-2017, 01:01 PM   #961
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
Fuel trims combined shouldn't be any more than +/-5%, if it is, it should be looked into. It's probably okay, but for longetivity and reliability, and to improve performance and mpg, i would look into it.
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Old 04-05-2017, 10:20 PM   #962
allowe
allowe's Avatar
Open Flash Tablet - OFT TIPS Trick’s & FAQ
How can I look at that table? Thru romraider? What would it be under in rom raider, I can't find it.
EDIT: I found it, it's 4 maximum but my stock tune has 0 maximum
allowe is offline   Reply With Quote
Old 04-06-2017, 06:22 AM   #963
steve99
Drives: FT86
arrh no not that one , think you have a bad definition dont change that
its the load limit tables see here not the A01G rom is correct steady rise from about 0.8 to 1.3 and the B01C all very high can cause bogging at low rpm large throttle input
Let me know you rom id and ill send you the correct definition or just post up your rom and ill fix it for you
allowe (04-06-2017)
Old 04-07-2017, 05:58 PM   #964
allowe
allowe's Avatar
Thanks a lot man I just sent you my tune file via pm
Also, could it be that it's driving like crap because my oxygen sensor, Evap and cat systems aren't "ready" yet according to dashcommand
Note: I also have an injen intake. That could also be a factor im guessing. I also unplugged my battery 2 days ago to install my amp.
Old 04-08-2017, 01:00 AM   #965
steve99
Drives: FT86
If your header is stock, then the most likely cause of rough running/bogging is the injern intake. Check for leaks and that maf installed correctly and the gasket under maf is not creased or torn.
but its likely your going to have to scale maf with the injen intake
Old 04-08-2017, 06:02 AM   #966
guybo
Huge E85 fan!
guybo's Avatar
My Injen intake causes rough idling. At idle my LTFT is way off, but as soon as I touch the gad pedal it smooths out and the LTFT is fine. I need to get my MAF rescaled. Right now is a bad time though, so it has to wait and I just keep on the gas a little when I idle in traffic. It's not a big deal really.
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 07:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 02:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
