Old 03-31-2017, 06:55 PM   #15387
KiP40
Drives: Subaru BRZ Limited
Bought a set of new Bridgestone Potenza S04 Polea Position Tires (stock tire size) and I also purchased weathertech all weather mats. Going to polish and wax it tomorrow!
Sent from my SM-G930T using Tapatalk
KiP40 is offline   Reply With Quote
Old 04-01-2017, 03:04 AM   #15388
ShoGun
ShoGun's Avatar
Drives: 2013 Subaru BRZ SWP 6MT
Install and prelim tune complete! New JDL Garrett dual ball bearing turbo
2013 Subaru BRZ - SWP - 6MT
ShoGun is offline   Reply With Quote
The Following User Says Thank You to ShoGun For This Useful Post:
MJones_RB (04-04-2017)
Old 04-01-2017, 05:31 AM   #15389
Dan37BRZ
Senior Citizen
Drives: 2015 WRB BRZ
Wrapped my mirrors...
Dan37BRZ is offline   Reply With Quote
The Following 3 Users Say Thank You to Dan37BRZ For This Useful Post:
MJones_RB (04-04-2017), OrangeGuitar (04-01-2017), tacos (04-02-2017)
Old 04-02-2017, 01:04 AM   #15390
EnoOnraefi
EnoOnraefi's Avatar
Drives: MY17 Asphalt 86
Looks pretty damn good in the pictures. How does it look in person? I've been debating wrapping a few things myself...
EnoOnraefi is offline   Reply With Quote
Old 04-02-2017, 01:23 AM   #15391
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Installed a new Tanabe Concept G exhaust!
justinco is offline   Reply With Quote
Old 04-03-2017, 10:57 PM   #15392
15limited
15limited's Avatar
Size:  97.4 KBName:  2017-04-03_18.46.35.jpg
Captions for individual parts., installed over the past couple of months
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
The Following User Says Thank You to 15limited For This Useful Post:
Old 04-04-2017, 02:17 PM   #15393
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
How do you like those tires? Quieter than stocks?
MJones_RB is offline   Reply With Quote
Old 04-04-2017, 02:53 PM   #15394
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Originally Posted by Var View Post
Perrin inlet and removed sound tube. Officially this part doesn't fit on the new engine but some stretching and clamps did the job
I just did the same thing on my 2017 BRZ, worked fine for me. Did not seem any different than on my 2013 FRS.
I did find out though that the 2017 MT cars have a different drop-in filter than every other twin out there...
Old 04-04-2017, 02:56 PM   #15395
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
New wheels and rubber for my BRZ.
The Following 6 Users Say Thank You to justinco For This Useful Post:
15limited (04-04-2017), ajaxthebetter (04-04-2017), derekbrz24 (04-04-2017), guybo (04-08-2017), MJones_RB (04-05-2017), sprintertrueno86 (04-08-2017)
Old 04-04-2017, 02:56 PM   #15396
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
Some of the roads that close during the winter have opened up so good times. Rotated the tires, cleaned the brake sticky goo poop of the lugs and ventured to buy real gas for the first time.
Took a midnight run on one of the higher roads (6000') and the car liked running on real fuel and the stock rubber actually heated up enough to somewhat stick.
thomasmryan is offline   Reply With Quote
Old 04-04-2017, 04:59 PM   #15397
Var
Drives: 2017 Subaru BRZ PP
I did actually compare the 2016 and 2017 stock intake tubes. They are different in length (due to the new manifold?). Also confirmed with Perrin that it's different and they are developing a new one, but like you said it fit just fine.
Var is offline   Reply With Quote
Old 04-04-2017, 05:10 PM   #15398
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Must be because of the different airbox design, since those take a different air filter now. Good to know they (Perrin) are making a new one. I didn't think anything of it until I saw your post
Old 04-04-2017, 06:18 PM   #15399
derekbrz24
derekbrz24's Avatar
Drives: 2017 Subaru BRZ WRB PP
what wheels are these?
derekbrz24 is offline   Reply With Quote
Old 04-04-2017, 06:25 PM   #15400
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
They are Rota Titans, 17x9 +42. Basically a Weds TC105N knock-off.
The Following User Says Thank You to justinco For This Useful Post:
Teseo (04-08-2017)
